You need to isolate the problem. Try connecting the Sandisk M2 into another phone or computer (using an adapter). If this memory card is detected by other phone or computer, then you may want to insert another memory card into the problem phone to test it.
If the problem phone works using another memory card, but the problem memory card also works using another phone, then you may want to format first your Sandisk M2 before using it.
Memory stick flash memory is tricky. If it is too small, DO NOT INSERT IT. I made this mistake and was lucky enough to have some tools handy to get it back out. You'll need a different adapter to use it in the memory card reader that you have.
As for "guest" 's conundrum. You will need to use either needle nose pliers or tweezers to VERY CAREFULLY remove it. It won't be easy and you have to be careful so as not to push it farther in (which eventually it will stop going in, but still makes it that much harder to get it out)
Plug the duo card into adapter labels need to face same direction. Plug adapter into camera or other device label facing you. Once card is installed make sure you format it for the device. My memory stick is 8GB and I use it in my P200 cybershot camera. 2400 high quality 7mega pixel images and 42min-3hrs of mpeg video.
I have a Toshiba Satellite laptop and I have the Sony's MemoryStick Duo Adapter the MSAC M2.
I try many times putting it in the port and nothing happens. I click on the "My Computer"; to see if I can click on the "Memory Disk (E)" to open; but it says "Application Not Found".
What does that mean? When I try to eject the Memory Disk (E); it says, "An Error Has Occurred While Ejecting the Memory Disk (E)." Then when I try to "Safely Remove the Hardware"; it says, "Window can't stop your MemoryStick0 Device; because, it is in use. Close any programs or windows that might be using the device, and then try again." I am confuse; what programs or windows that can be using the device?
