Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Washer - "Door Locked"
Our duet washer appears to be locked up with the "door locked" light on, but the door is not locked. I am uable to reset. I have tried to unplug and start up... nothing appears to resest this. Any ideas?
  • sr-smith Nov 01, 2008
    amelisdad... what do you mean to check the wiring to the switch? How?
    sorry.. not the door locked light, but the "control locked" light. Have never seen this light come one.
Same problem here, Dl error, took the door lock unit out few times, disassembled, looks good,
still problem, tired to unplug it to erase error, such a headache....
The main controller board seem to be a problem, relay is not functioning right, it is about 180$ ;-(
Posted on Nov 01, 2008
    Sergeant:
    Champion:
  • 324 Answers
Check wiring to switch.
  • Unplug the machine,then take the top of with the 3 screws towards the back. remove top and you will see the wires going to the switch,make sure they are all connected..
  • o ok that is easy. push the litle lock symbol for about 10 seconds. can you see a little lock there?
Control lock light
control lock light ? have you got any blockages or dirty filters you may have to clean them.
Jul 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
My washer says that the conroles are locked. How doi fix this?
Put clothes in washer like always and pushed control button to start the cycle. No lights appeared on for any cycle or the digital timer window. The only light that remains on is the "controls locked" in the verticle status row leds on the left side of control panel. The door was closed. I unplugged and re-plugged the machine for possible reset and there is no change.
Feb 17, 2011 | Whirlpool Duet GHW9150P Front Load Washer
The load appears to have finished, but the CONTROL LOCKED light is on. The door is not locked and the washer is still full of water. Pushing cancel does not reset it.
Hello
This whirlpool duet front load washer needs a reset to resolve the control lock problem. Press and hold the END OF CYCLE button for 15 seconds to reset the control. Please get back to me if you have any other questions.
Kevin
Nov 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My washer is locked. I unplugged and plugged bach
holding the end of cycle button is the control lock,not the door lock. Check to be sure that the control lock light is off--if not, hold end of cycle button again till control lock light goes off.
I've given up on the door lock after a few years fighting it, and researching. There is a solution on fix-it that may work--if it is computer(mother board I think they call it)--and not door lock mechanism. I've read many posts from duet owners that replaced door lock mechanism just to have it be a soldering problem with the "mother-board" that makes the machine "think" there is a door lock failure.
Here is link to a fix-it post I used today to get my machine open and retrive clothes it has held hostage for several days:
http://www.fixya.com/support/r622155-kenmore_elite_whirlpool_duet_door_jammed
Oct 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My duet washer is locked and will not reset
To open the door,remove the bottom panel. Teach up inside on the lock side and find the pull ring. Pull on the ring while putting pressure on the door. It will open. Have the door lock wax motor and mechanism replaced.
Jul 17, 2009 | Kenmore Elite 45986 Front Load Washer
The control lock light is on. The machine will not work. I tried unplugging it for 1/2 hour hoping it would reset. Whirlpool Duet Washing machine
The door will have to pried open and door switch will have to be tested or replaced. You can use a multi-meter or ohmmeter.
Worst possible cause is faulty eprom or control board but usually is faulty switch or door sensor.
Jun 27, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet HT Washer
I guess electric door lock just stacked. To prevent door breakage call to your local appliance repair company.
_______________________________________
http://www.allstarsappliance.com
Aug 04, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Control lock light
someone has enable the child lock feature. One of the buttons should say hold 3 secs for control lock under its normal function description. Hope this helps
Jan 01, 2008 | Washing Machines
Whirlpol duet
sounds like your door lock switch may not engage.try opening and closeing the door. unplug the unit wait a few minutes plug back in and see if you can open the door. check to see if the door lock lights up.. hope this helps..
Aug 25, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
783 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
