Question about Canon Office Equipment & Supplies
Printer/scanner indicates a paper jam . cnone can be found
  • 2,785 Answers
You open the printer manually and check for any broken or damaged part or you can send it for near by repair shop
Posted on Nov 01, 2008
Canon 3010 problem jam indecate
If the error indicator light is lit, then the Canon printer is jammed. To fix a paper jam you must remove the paper tray, disconnect the AC power adapter, wait 5 seconds, then plug the printer back in. If the jammed paper does not automatically eject, carefully remove the paper manually. To help prevent further jamming, fan the paper in the paper tray to prevent the paper sticking together.
Great people delivering a superior customer experience. Canon Printer offers a complete line of printers, scanners, all-in-one office machines and paper jammed problem. Facing the problem with Bother printer, Scanners, Call our technical expert and get quick help. Dial Canon Printer tech Support Phone Number (18777788969) and fix your problem. For more information visit us:
Sep 02, 2016 | Canon Office Equipment & Supplies
Printer displays alarm and indicates there is a paper jam. However, there is no paper jammed. What can be the problem?
Could be dirt blocking a sensor, damaged sensor, or paper pieces where the sensor can pick them up.
Mar 03, 2016 | Canon Pixma Mx310 Office All-in-one...
Paper jams after pulled in skew
Mine did this ages ago. I found a staple had accidentally fallen into the printer and jammed on one side causing the paper to go in skewed and then jam up. Get a torch and have a really close look inside where the rollers are for staples, paper clips or bits of paper stuck on the rollers.
Aug 28, 2015 | Canon Pixma MP250 All-in-One Color InkJet...
I get a warning message for a paper jam, but there is no jam and the paper will not feed through the printer.
Still you have to check all places paper has to move through. If only one sensor indicates the rolls are not moving correct you gat this message. Also make sure you closed all doors and flaps correct.
Jun 29, 2014 | Epson Pro Wp-4530 All-in-1 Inkjet Wireless...
I have a Brother Printer HL-240D that gives me a constant paper jam inside indication even though the paper goes completely through the printer, and there is no actual paper jam. What switch causes the...
Have you tried shutting it down completely? Also, double check to see if the inside of the printer is completely clean. I had the paper jam indicator showing because there a small piece of paper stuck inside. Also, found a helpful manual for a similar printer, you can see it here - Brother HL-2240 manual
Sep 29, 2013 | Brother HL-2040 Laser Printer
Message reads:-Paper is jammed in the product. Turn off the product, open the scanner unit, and remove the paper. See documentation.' I have checked for any paper jammed, but finds none. I have even u
Did you try unplugging the power cord and waiting a couple of minutes, then plug back in and see if the printer resets itself. Also try checking all the paths that the paper travels through the machine for any scraps of paper that may have torn off during the jam up. Sometimes a very small scrap will prevent printers from resetting themselves. Also disconnect the printer from the computer before unplugging so the printer doesn't receive any signal from the computer. It may not mean anything.
Dec 28, 2011 | Epson WorkForce 600 All-In-One InkJet...
Kyocera 3900dn says paper jam in rear but no jam evident
Usually a printer doesn't lie when it indicates a paper jam, if you have checked as thoroughly as possible and no paper can be found. It is possible that the paper just isn't feeding and a printer will sometimes indicate a paper jam when paper doesn't feed. But if this isn't the case and a jam is indicated as soon as you turn the printer on, one of the plastic jam sensing actuators may be broken or hung up.
Aug 05, 2009 | Kyocera FS-3900DN Laser Printer
HP 4L printer indicates no paper when the tray has
When you removed the paper jam, was the paper torn? If so, did you ensure that you found all the pieces. (Put the piece of paper back together like a puzzle to verify). There could be a piece of paper stuck in the printer that is causing the paper sensor to fail.
The other possibility is that when you removed the paper jam, something became dislodged in the printer. Forcefully removing paper from the printer can cause this.
Jul 16, 2009 | HP LaserJet 4L Printer
Rear Paper Jam - No paper present.
Look for a small piece of paper that may be stuck in the switch indicating a paper jam.
Jun 01, 2009 | Canon PIXMA MP610 InkJet Printer
24 people viewed this question
old marine
old marine
