Question about RCA F27628 27" TV
Channel selection Recently our cable company upgraded to digital service and discontinued the old analog cable boxes, rendering the box on this tv useless. I plugged the cable directly into the tv on all of our other tv sets in the house and was able to use the remote AND the tv's manual changer to change channels. However on the RCA tv, only Channel 3 comes on and it will not allow me to change channels, either via remote or manually. Any ideas what causes this? THANKS!
  • Joseph Polino Mar 30, 2013
    I have same problem. Only get channel 3. When i go into the menu it shows all my channels checked marked in analog except channel 3 no check mark and thats the only one I get. Tried unchecking all channels but it keeps defaulting back ??
  • Anonymous Mar 21, 2014
    since the digital change over I cannot get TV channels
    President:
  • 3,130 Answers
What you need to do is take the remote, go into the menu, find channel scan and do a channel scan to find all the available stations available on this system. Make sure the TV set is in the cable mode and not antenna mode or you wont get any stations above channel 13.
Posted on Sep 18, 2006
My ematic converter box was working just fine. Now it won't pick up any channels even after I channel search. Please help
I had a similar problem in DEC 2017. Curiously the cable company stopped by in a week or so. (I did not call them for service.) It was a "SPECTRUM" truck and not an "OCEANIC" truck. Apparently Oceanic got bought out and the Technician was going around the neighborhood (Honolulu) searching for "Home Broadcasts" I remember reading about WW2 military was looking for homes with RF signals (looking for spys) I'm a retired Army Signal Corps. The Spectrum tech installed a filter on my cable line to prevent our home from producing stray signals. He also told me that my 'analog' TV won't work in JAN 2018 as they are switching to all digital by then. Says my cable will work for a while but expect the company to switch all the cable boxes out to digital. Sure enough my TV stopped working (on analog channel 3) and my cable box stopped sending the analog signal to my analog set. I found out that some of the other outputs worked (HDMI, Optical, etc.) I got the Bedroom TV (bought 2017) to work on HDMI. Picture is crisp BUT I don't seem to have the picture size right. It's smaller than normal (on analog) and changing screen from normal, wide, zoom, etc. really makes it worse. Panoramic is the best so far. Now I notice our older 'Monitor' 42" Plazma (2010?) still works on Chan 3 analog signal. I didn't have another HDMI ($30) cable so I tried using my old DVD Yellow-White-Red RCA cables and found it did not work.
* So.. Short answer; you need to get your TV hooked up to the HDMI output of the cable box. But I would check with your cable company first to see if they can resolve your issue. Now days, they can use a computer (from their end) to correct the problem or send out a service tech.
Aloha, ukeboy57
Jul 01, 2018 | Televison & Video
How do I change Channel default on start up
Use your remote. Press menu and look up initial set up or reset to factory settings.
* Note that as of Jan 2018 most cable companies do not provide analog outputs to TV sets. If your still using Channel 3 for an input to your TV then it won't work or will stop working some time this year.
* Hook up your TV using the old RCA video/audio jacks; Yellow plug is video, Red is audio right, White is audio left.
* You can also use an HDMI cable (best) for High Def picture which is all the rage for HD TV.
* You may also connect using the DVD style cable hook up which uses 4-5 separate cables (3 for colors and 2 for audio)
* Once you have some sort of video or message on the TV screen then you can proceed to setting up the cable box. Have the cable box hooked up and on for at least 15 mins. Look at the cable box display till the correct time is displayed. Power up the cable box till you see the power on indicator. Now use your TV remote to select the correct input you hooked your cables t. (probably HDMI) The display should show you your cable service. Now use the cable remote to select your channel.
* If you don't have a cable box but still have digital service (usually called basic cable - no premium) then use the analog/digital input on the TV remote and select initial set up. There should be an automatic channel search and set up to scan all the channels available on the line your connected to. This will take up to 15mins. If you know the specific channel you can cancel the scan and pick each channel for you own list. Letting the scan run may help you find other channels you are unaware of.
* Final; if your still having problems then call you TV MFR support line and they will talk you through to check your set.
* You can also check the cable company support line if the TV check out okay. The cable company may or may not be able to supply you service for really old Tube style TV sets as most if not all TV's are digital now.
Aloha, ukeboy57
May 29, 2018 | Computers & Internet
Tv problem- I have a LG model47lb5800. when I turn on the TV it shows a picture and sound for about 3-10 minutes. The TV then goes black flashes a picture intermittently. What's failing?
Aloha, ukeboy57
PS Try rescanning for channels. You will need channel 3 (sometimes #4) If it shows vertical bars then your set can't tune to the cable box. (Just like the old days of "Outer Limits") They do control the horizontal and vertical. You can try to hook your TV directly to the cable without the cable box to get some of the analog and digital channels if your set is less than 10 years old. But the channels are weird and hard to browse. You will need to write down the channels to remember your favorites. Cable remote won't work. But this is just a short term fix. You will end up subscribing to a cable or internet TV service.
Mar 21, 2018 | LG Televison & Video
Cable company switched to digital, now my Ant A port on the vs-50603 does not receive signals. I can somewhat view the analog signals through my PIP only. other tv's in the house came back with signal 5...
When the cable company offers you digital cable, you typically need a cable box to unscramble the digital channels. Therefore you need to connect either a coaxial cable from the cable box's RF output, if it has one, or connect 3 RCA cables from the yellow, white and red jacks on the rear panel of the cable box to the TV. Analog channels only (if available) will go straight thru over the coaxial RF hookup. They are not scrambled. Select the proper input source on the TV for the cable box.
Aug 26, 2010 | Mitsubishi VS-50603 50" Rear Projection...
How do i tune in my digital cable on my analog tv?
You'll need a digital cable box for that, I'm afraid. The analog tuner in the set isn't compatible with the digital cable signal. The cable company in my city just dropped their analog service. Now you either need a digital converter box, or a "cable box lite" called a digital transport adapter. For digital off-the-air broadcasting you need a digital tuner and probably an amplified or outdoor antenna. The analog TV is rapidly becoming pretty useless except as a display device as analog channels disappear.
Mar 11, 2010 | Curtis-Mathis CM19011 TV
Trying to set up Digital Labs 19''LCD TV/DVD combo and only gets limited cable channels (old tv on same cable gets lot more). Have completed auto scan and pick cable as reciever however only gets limited...
The remote control that came with my Digital Labs tv/dvd combo worked for about 2 seconds and never really worked correctly. Now, I'm trying to find a universal remote that will be compatible. Please help.
Dec 26, 2009 | Televison & Video
Can I watch tv on 1 channel while recording another?
Unfortunately no, unless you get a second converter box. You're using the converter box to select channels, and it can only be on one channel at a time. With a second converter box, you might find you need a second antenna too (so you can get a signal on both channels). And you can't program your VCR to record on different channels (since it can't control the coverter box to change channels).
(This is a case of history repeating itself. When cable TV was new, and most TV's and VCR's weren't cable-ready, you needed to use the cable company's converter box. The same problems came up then too!)
Nov 30, 2008 | Insignia Digital-to-Analog Converter for...
Hooking actual live coaxial from Cable Co. to Insignia Converter Box ...
Based on the specs that I have read I am going to say you cannot hook up cable to the converter. Best thing to do would be to call cable company that provides service there and see if it was turned off on the billing side they probably just didn't come out and disconnect from the pole. That might give you service but missing some features such as tv guide channel. Now some tv's have tv guide built into them and maybe in the move that feature on the tv was turned off it they were using it that way before. Here is what the specs say about that converter:
Use this digital-to-analog converter to convert digital TV broadcast signals to analog signals on analog TVs with antenna-based reception.
I’m happy to help further over the phone at https://www.6ya.com/expert/brandon_60dfebff379d64bd
Nov 08, 2008 | Insignia Digital-to-Analog Converter for...
Tuning to pick up sky feed
Sounds like from discription the sky feed is set up for analog channel 6. With my TV-HVR-1600 card, there is an option in the wintv application when you click the menu button in the application that says channel suite. If you select this option, you should find and option for analog source. Select analog source in this screen and you should be able to manually add channel 6 in the box at the top of the analog souce screen. Also if you have the sky feed connected and you you click the scan button on this screen, it should detect automatically is the sky feed is on.
Aug 20, 2008 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
HDTV Cable box conflict
This set does not support 480I in the DTV mode, only 480P and 1080I is supported. Try setting the analog setting in the cable box to 480p and that should take care of watching the set in DTV. Most cable boxes have a setting for format changes in the customer menu, depending on the type of box. If you are able to change the format, then the other inputs will not work since they need a 480I signal, as well as VCRs. Another setup could be to use the S-Video cable or Video input jacks to get a better picture in 480I instead of using the cable input. However, when changing from HD to Analog, you will have to change to the correct input on the set as well. Hope this helps.
Dec 24, 2006 | Samsung HCJ655W TV
RCA F27628 27" TV Logo
425 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
