Question about Konica Minolta Di1610 Copier
Error codes bizhub c 252 write error codes C-DC00,C-DC10
Error Code C13FO
Posted on Feb 25, 2009
  • 145 Answers
Poor connection or there are bent pins on the copier-to-scanner interface cable. Inpect the cable and straighten the pins on the male side and then check that the female connector holes are round in shape and not oval. If the holes are oval-shaped, insert a small pin to reform the hole to mostly round. Reseat the scanner cable connection to mainbody.
hope that help
Posted on Nov 01, 2008
How to delete malfunction code c-3751 on bizhub c-252?
What error code do you get when you try to print or copy?
Jul 02, 2014 | gmail.com
Bizhub 353 error C-DC00
Sir/Mam,
You hit a serious code, noting can be done, this code requires a tech to come out and remove a chip inside the machine, which is then sent to Konica Minolta, then on to the US SECRET SERVICE since some one attempted to counter fit US currency!!!!!!!!!!!, until the US Secret Service determines what was done the machine stays inop, once what happen is determined tech will come out reinstall the chip reload firmware, and .NEVER EVER PLACE ANY CURRENCY ON A COPIER all the machine down a day have Bank Note chips..
Apr 19, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
Error code c-dc10
Sir/Mam,
You hit a serious code, noting can be done, this code requires a tech to come out and remove a chip inside the machine, which is then sent to Konica Minolta, then on to the US SECRET SERVICE since someone attempted to counter fit US currency!!!!!!!!!!!, until the US Secret Service determines what was done the machine stays inoperative , once what happen is determined tech will come out reinstall the chip reload firmware, and .NEVER EVER PLACE ANY CURRENCY ON A COPIER all the machine now a day have Bank Note chips.
Jan 23, 2014 | Konica Minolta bizhub C250 All-In-One...
Error code ca20
toshiba estudio 232 errr ca20 wt problems?
May 25, 2013 | Toshiba e-Studio 232 Black and White...
C dc00 konica minolta c351
CDCXX-trouble related to security.Try to reset:
Turn OFF the copier.Press and keep pressed the Utility key and turn ON the copier.Keep pressed the utility key and wait to Trouble reset message appaire on the display.(1-2 minutes.).Release the utility key and touch the message.Turn OFF the copier,wait 1 minutes and turn ON.If the error code displayed call the technical rep. from Konica Minolta.
Apr 06, 2013 | Konica Minolta bizhub C351 All-In-One...
Konica minolta bizhub c250 error C-2AO3
magenta toner cartridge EEPROM access error, cleaned the connection between the toner cartridge and the machine once cleaned if the issue persists remove the toner cartridge and put back in again if again the error persists replace the toner cartridge with a new one and last resort if the issue is still not fixed then replace the mechanical control board.
Oct 04, 2012 | Konica Minolta Minolta Konica Bizhub C250...
Paper will not lift. error code dc00
Remove any paper you find jammed. When pulling from the front there will be resistance from the paper feeder. Pull slowly - the paper will rip ..
Video 1 -
then clean the rubbers which picks the paper with the spirit
Jan 03, 2010 | Canon SELPHY DS810 InkJet Photo Printer
When I put a disc into the camcorder it reads "disc error"
My DC10 Camcorder is now coming up with error message 'replace battery pack'. Have done this and not solved problem, will not turn on at all?
Mar 17, 2009 | Canon DC10 DVD Camcorder
Konika minolta
CDC##  Appears to be trouble related to security.
The only solution is to contact Konica Minolta to find out what needs to be done to resolve the problem.
That is only solution the service manual has provided.
Nov 01, 2008 | Office Equipment & Supplies
Konica Minolta Di1610 Copier Logo
551 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
