DVD jammed in player - Televison & Video
  • 2,427 Answers
Hi,,
Ok here is what you do,,
1. Unplug the player
2.) Remove the Top of the player by taking out the screws at the back and sides
3.) With the player opened up look for the disc drive , there should be a cover above it that can be removed by removeing the crews and then lifing it up
4.) with the cover off remove the disc
5.) re-assemble your player.
Posted on Nov 01, 2008
Jammed DVD PLAYER DVP 1000 what can I do?
take top off and try to retrieve it
Jul 27, 2015 | Polaroid DVP-1000
Dvd player is jammed and wont open can you help
try taking the outside cover off then you might be able to manually open it .
Jan 28, 2015 | Philips DVDR3440H DVD Recorder/HDD...
Jammed dvd player
Sounds like there is a disc stuck inside. Try undoing screws all around side of player and take off cover (make sure this dos'nt void warranty) Find disc and reverse procedure.Hope it helps.
Nov 26, 2013 | Televison & Video
Sony Ns575p wont eject DVD
Someone is going to have to open the unit to look to see if mechanism is jammed or out of alignment or if the disc is not in the proper position---either mechanism or a jam is most common here.
Oct 21, 2012 | Sony DVP-NS575P DVD Player
GO VIDEO model 1030....VCR works fine...DVD..nothing happens...door won't even open?
Combo units have this essential flaw--if one half fails you are usually done especially if the DVD side fails.
If Door does not open either a disc is jammed inside the mechanism or the mechanism is out of alignment or damaged.
Good argument against buying these units--DVD individual parts are rarely sold--only (if available) would be the entire DVD unit itself--not cost effective to repair.
DVD players are now real cheap (see some for as little as $20) so if not a simple jammed disc or something like that buy a DVD player.
Apr 05, 2012 | GoVideo Go Video DVD/VCR Combo
My disc is jammed and won't come out.
hello,
the reason the disc is jammed is because the player did not sit the disc properly.
what you will have to do is;
get a screw driver, open the dvd player, you will find a mechanism that presses the cd down to the lens, you unscrew it too and remove the disc that is jammed in it.
press open to see if it would open up, if it does, then you can screw it back together, but if it does not open then there is a fault with the mechanism that open and closes the player. so you carefully check it out and put it back in order and it would start working.
goodluck
Feb 04, 2010 | Zenith DVB412 DVD Player
Dvd jammed within the dvd player
There should be a small pin hole located on the front of the DVD tray. Gently push the end of a paper clip or something similar into the hole to release the tray.
Sep 27, 2009 | Grundig GU19WDVDPCX 19 in. LCD TV
Why doesnt the cd/dvd stay in the VALOR player?
The dvd drive coud be jamming on something inside, or the dvd tray belt could be slipping or the disk could be jamming on something inside which is preventing the draw from sliding all the way in.
jon
Aug 10, 2009 | Valor Televison & Video
Jammed tray
try checking the tray for something that jams the tray.
May 27, 2009 | Yamaha DV-C6660 Multi-disc DVD Player
Televison & Video Logo
209 people viewed this question
Top Televison & Video Experts
