Question about GE Washing Machines
GE Washer error code B3
I have a GE Front Loading washer - WSSH300GWW.  It stops in the middle of the cycle - I don't know where, but when I come to the washer the start light blinks, and when I push start, it continues to blink.  I have put the washer in the diagnostic mode and error code B3 came up.  What is error code B3?  It is not on my code list.
Thanks!
cnybeth
SOURCE: My Ge wssh300gww will
Thank you for responding. I did fix the problem. This washer does not say anything about cleaning a filter inside the rubber drain boot between the washer drum and the pump. I took it appart and found a plastic filter which was clogged with lint, change, and a sock. After cleanning this out the washer works great. Thanks for responding.
Posted on Feb 17, 2008
jsrock516
  • 5911 Answers
SOURCE: Error code F09/Whirlpool Duet front loading washer
"F09" is an Overflow Condition error. This is usually attributed to a malfunctioning pressure switch, loose or broken connector between the Pressure Switch, Drain Pump and Central Control Unit (CCU), or...a drain pump or drain line that has become clogged.
Since this problem occurs periodically during the wash cycle, I would check your drain pump filter for obstructions first. It could be that you have debris lodged in the pump causing it not to drain properly. To access the pump:
1. Unplug the washer.
2. Remove the lower kick panel under the door by removing the screws under the bottom edge. HINT: Placing a couple of blocks of wood under the front feet of the washer will make access much easier.
3. The drain pump is located under the wash tub in the center. HINT: If you own a shop vac, remove the drain line from the standpipe at the wall and pull a vacuum through the drain line. This will remove all residual water from the washer and make clean up later a lot less messy. Now, remove the cover on the drain pump and remove. Clean out the pump filter and check the pump impeller for obstructions.
If you do not own a shop vac, place a bunch of towels around the drain pump BEFORE you open it. There's about a gallon or so of water in the tub, drain line and pump.
Try this first, and let me know if this corrects your problem. If not, you may need to check the pressure switch and wiring. I hope this helps you.
Posted on Apr 14, 2008
SOURCE: Kenmore Elite HE3 front loading washer
Before you go crazy trying to solve the F2 code make sure the filter is clear. Disconnect the power cord, PLEASE. Remove the kick plate on the bottom front by removing the 3 screws below it. You will need a hex socket and extension or a torx screw driver. If there is water in the machine and it will not drain you will need a shop vac and some old towels to catch the water when you open the filter. Now, you will see the filter in front of you. Have the towels ready and vac turned on. Quickly unscrew the filter cap and stick the vac hose right in the filter to catch the water. Clean the filter cap. Did you find any socks, money or other debree ? If yes that may have been your problem. Put the filter back on and HAND tighten well. Test the machine. From now on empty all pockets before you do the laundry. You just saved yourself a big repair charge. Be proud of yourself.
Posted on Apr 17, 2008
  • 5 Answers
SOURCE: GE Energy Star WCVH6260F Front Load Washer: door locking problem
http://www.instructables.com/id/GE-Adora-Lint-Filter-Cleanout/?download=pdf
Had the same problem, this fixed it!
Posted on Oct 31, 2008
SOURCE: Bra wire stuck inside washer between drums - WSSH300GWW
If you are unable to remove the wires from inside using needle nose pliers, then my advise is to call in a professional. Taking out the inner tub on a front load machine is involved, and you open yourself up to several potential leaks as well as bearing damage.
Posted on May 04, 2009
Kenmore washer error codes
Appliance Repair Forums
Near top of page click on Thread "HE Error Codes"
Even blonde can do it Quick fix repair for Kenmore He2 front loading...
Search youtube for he2 washer for other help videos
Aug 18, 2014 | Kenmore HE2 Washing Machines
Ge frontload washer pausing in the middle of cycle
as to the not draining properly check the pump Ive had to change many of these pumps on this type of front loader or you can go into the diagnostic of the machine. if you remove the bottom panel theres a technician sheet there it tells how to go into the diagnostic menu: first unplug the machine for about 30 seconds then replug the machine then hold in signal then delay then signal then delay after which you willhear the door lock click then ull get a t-01 number use the dial to scroll to t-02 then push start this will give you the error code and tell you whats wrong with your machine compare the code to the technical sheet provided inside your machine remember to clear out the error code when you fix the problem
Apr 29, 2010 | GE Energy Star WCVH6260F Front Load Washer
GE front load washer WSSH300GWW moves in spin cycle
the machine is off level. open up your installation guide, and it will provide instructions on how to properly level the machine.
if you have any questions, feel free to email me at thadoggma420@hotmail.com
Jan 22, 2009 | General Electric WSSH300G Front Load...
Washer stops during middle of cycle and post 02 F
f 02 is the error code for taking too long to drain the water disconnect power remove 3 torex 20 screws from lower front panel revove cap from pump asm to check for any obstructions beware there will be water in the pump
Dec 15, 2008 | Whirlpool GHW9100L Front Load Washer
CONTROL LOCK and Can't start the GE front load washer - WSSH300GWW
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 5 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
May 23, 2008 | GE WSXH208A Front Load Washer
Washing Machines Logo
47 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
