Question about Whirlpool 24 in. DU910PFG Built-in Dishwasher
Whirlpool dishwasher model du910pfgg1
Dish washer does not appear to be using any water. systems seems to cycle but no water is showing up? can you give me an idea what to look at or what steps i need to do thru before i go out and buy a new one...please help
jsrock516
  • 5911 Answers
SOURCE: Whirlpool Gold Dishwasher Model GU2400XTP
There should be a thermal fuse located inside the console on the control board. Most dishwashers have them mounted this way. It's a white square plastic piece, or silver component with two wires connected to it. If the thermal fuse is bad it will give the same symptoms you are describing. To check, you need to turn off the circuit breaker to the dishwasher and remove the screws holding the console in place. This should be the four or five screws at the top of the door (with the door open). Carefully lift the console off the door (support the wires) and flip it over so you can see the control board. The thermal fuse should be mounted somewhere on the control board. The fuse will read a SHORT if good, an OPEN if bad. The fuse is not resettable (meaning you can't reuse it) and must be replaced. If you need further assistance let me know. I hope this helps you. PS There should be a tech sheet located inside the lower kick panel under the door. This includes all the schematics and troubleshooting tips. You may use this as a reference too.
Posted on Jul 18, 2007
SOURCE: Kenmore Ultra Wash Dishwasher; Model 665.17539
I have a Kenmore 665 about 3 years old
Over the last couple months the touch pads have stopped working and I am now down to one control the water miser!
Do I need a new control pad and is that easy to install ?
Thank you for any sudgetstions
KC
Posted on Feb 08, 2008
Skill Will
  • 53 Answers
SOURCE: dishwasher will not wash
hi
so many possibilities here, a couple possible solutions.. check the sprayer arms to see if they move and check to see if all the holes on the sprayer are clear. check the drain lines they may be clogged or the motor may be clogged or broken.
Posted on Mar 30, 2008
amgm
  • 32 Answers
SOURCE: philips/whirlpool turbo silent 256 , no water through the cycle
Hi, if the motor is working then the spring arms are blocked. Pull them out and rinse them on the sink, then put them back on. Simple
Posted on Feb 12, 2009
  • 244 Answers
SOURCE: dishwasher throws food
check for filter on botton around pump and clean it
Posted on Feb 16, 2009
Why does it beep through the entire. Wash cycle. No code showing.
Whirlpool Duet GHW9150P Front Load Washer Beeping ...
www.fixya.com > ... > Whirlpool Duet GHW9150P Front Load Washer
Question about Whirlpool duet Washing Machines ... my front loader is not workingwhirlpool washer flashes and beeps will not finish a cycle 1 Beep/E10--Error: Water... It beeps through the wash and rinse cycle every couple of minutes. ... Cycle signal which tells you that the cycle is complete beeps through the entire cycle.
[PDF]front-loading automatic washer use and care ... - Whirlpool
www.whirlpool.com/.../U...
Translate this page Whirlpool Home AppliancesWash. This is the main portion of the wash cycle. You will see the washer tumble the load. ... Spin cycle. If the laundry is still wet, take half of the load out of the washer and try again. .... Using recommended AFFRESH® washer cleaner, add.
[PDF]DISHWASHER USER INSTRUCTIONS - Whirlpool
https://www.whirlpool.co...
Translate this page Whirlpool Home AppliancesThe first cycle using the sensor will run longer to calibrate the optical sensor. Rinse Aid. Using rinse aid will optimize your drying and wash performance. This dishwasher is ...... laundry detergent, hand soap, or dish detergent for hand washing .... models) you will experience more starts and stops throughout the entire cycle.
Continuous Beeping - Whirlpool Duet Sport Washer - The ...
appliantology.org > ... > The Laundry Appliance Repair Forum
Jan 25, 2016 | Whirlpool Washing Machines
My whirlpool dishwasher (GU980SCGB3)will not drain. Wash cycle works fine. Water will not drain when the cycle is finished.
Whirlpool Dishwasher Won't Drain - Model GU980SCGB3 ...
www.repairclinic.com/...Dishwasher/...-/Whirlpool-Dishwasher-won-t-dr...
My Orders. Login · Order History · My ... Whirlpool Dishwasher Won't Drain.GU980SCGB3 ... Dishwasher not draining, wont' start or not cleaning dishes properly? This video provides ... how to access... Show all parts for model GU980SCGB3 ...
Nov 04, 2015 | Whirlpool 24 in. GU980SCG Built-in...
I have a whirlpool quiet lll and it will fill with water but after that it just hums and does not cycle the water through to clean the dishes.... what should I do?
Are you shure that it is a dishwasher ??, because only a cloth washer "fills with water". Could you give the model #.
Sep 01, 2011 | Whirlpool Dishwashers
The water does not get hot enough. I think it's the reason why dishes are not coming out clean. In normal conditions do I need to wash the dishes (like the manager of this apt. complex suggests) before I...
No you need not wash the dishes but just cleaning of the debris and then putting it in the dishwasher for proper cleaning will help you to prevent the drain from getting blocked.
First perform a vinegar cycle wash in the dishwasher. Pour a cup of vinegar into the bottom of the dishwasher. Keep the temperature at the highest setting possible and perform a wash cycle.Then start using a dishwasher most probably that would solve the problem. If this does not solve the problem then there must be some parts worn out or faulty creating the problem.
There are many probable causes of failure .
To clean the dishes the water temperature is essential.It the water is not hot then the dishes will not be cleaned properly.So check the water temperature.
Also check the filter in your dishwasher.Clean the filter if there is accumulation of debris in the filter.
Feb 22, 2011 | Whirlpool Dishwashers
My Bosch Dishwasher is not drying my dishes now. The model number is SHE44C05UC.
Unfortunately, it seems that the heating element has failed. The dishwasher uses steam to heat the tub to dry the dishes. I suspect your dishes are also being washed in cold water.
To check this, please run a regular full wash cycle. Allow the washer to fill with water and run for about 10 minutes, then open the door and feel the water temperature in the bottom of the washer. If the water is cold, it's more than likely the heating element has failed.
There are other possible faults which would cause the element not to heat, but these often prevent the dishwasher from completing the cycle. If the water is cold but the dishwasher still drains the water at the end - and completes the cycle - the heating element has probably failed.
Please try this simple test for water temperature and let me know if you need further assistance.
Regards,
BElectric
Feb 18, 2011 | Bosch 24 in. SHE44C05UC Stainless Steel...
Hi, My whirlpool dish washer does not clean the dishes. Robin
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it’s kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound. If it seems as a low water pressure then check the fill valve.
Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush.
The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes.
Daniel
Aug 07, 2010 | Whirlpool Dishwashers
Not cleaning dishes.
check if some dirt got in the arms of the washer as sometime this will slow the flow of water and not allow the pressure to clean the dishes well
May 24, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
The dishes coming out dirty on my Whirlpool Gold Quiet Partner IV. Cycle seems to complete. The soap is being used. Not sure how old it is ... it came with a house I just bought. Any suggestions?
Clean the jets on the unit. Jets are the small openings the water comes out of. Contact Whirlpool, follow their recomondations, or add some CLR or Lime Away to the washer without a load of dishes. Both products remove Calcium Lime and Rust deposits which impede the flow of water, causing your dishes to come out dirty
May 16, 2010 | Dishwashers
I have model DU810SWPU3 Whirlpool dishwasher that is 1 yr old. Plastic dishes appear to have a film on them when cycle is complete. The water also seems to drain slowly. I assume that what appears to be...
The problem is hard water. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info.
May 03, 2010 | Tappan 18 in. MDR251RE Built-in Dishwasher
Have a trouble: dish-washer will not drain.
I just moved into a new house and builder had provided a dish washer drain just below my kitchen drain line.
DIsh washer install was done by me, every thing worked out OK except dish washer would not drain after a wash cycle.
Cause: drain provided by builder was blocked and needed a circular small cut before mounting drain hose over it.
Mar 21, 2007 | Electrolux 24 in. ESI6220X Free-standing...
Whirlpool 24 in. DU910PFG Built-in Dishwasher Logo
210 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
