Question about Linksys WRT160N Wireless Router
Vonage Phone Adapter and Motorola DSL Modem and Linksys NUltra
I have a Vonage phone adapter and a Motorola DSL modem. I am trying to add a NUltra Linksys wireless router however when I connect the lan cable from computer to the router and the other lan cable from the router to the vonage adapter I loose internet connection. I have even tried the reverse way and still the same results. Does anybody have any ideas or suggestions?
  • sweetypetiti Nov 01, 2008
    Thanks I will try that.
  • 1,269 Answers
Your connection should be from DSL modem > internet port of Linksys router > Vonage phone adapter to port 1 of the router.
Posted on Nov 01, 2008
How do I install my Belkin wirless router with my existing modem and vonage phone adapter
I am not sure of the specific information you are asking, but my Vonage adapter is plugged into my modem and the router is plugged into the Vonage adapter.
This way the Vonage adapter can throttle the bandwidth used by other devices while in a call state.
Hope this helps, if not please ask more..
Sep 08, 2009 | Belkin F5D8236-4 Router
Setup router with vonage device and dsl modem
For the best call quality, I suggest you connect the Vonage router to the DSL modem, and if necessary, connect the Linksys router behind that. Why are you using a second router, though - you probably just need a switch or hub, if you're trying to connect more machines. Small networks rarely require more than one router. may be able to provide additional support if you can give us more details about your installation.
Jul 20, 2009 | Computers & Internet
How to connect Wireless router to Cabel Modem and Vonage Modem?
First of all: it would be good to know which devices you are using. This would help to be more specific.
But anyways:
  1. Connect a normal Ethernet cable from your DSL or Cable modem to the Internet (or WAN) port of your vonage router.
  2. Then connect another Ethernet cable from one of theLAN ports of the vonage device to the Internet (or WAN) port of your Linksys (The one that is separated from the 4 LAN ports.)
  3. Make sure that the Linksys is set to DHCP (Dynamic IP Address), soit can get it's IP address from the vonage router! (Look at your manual. If you don't have one, you can get it here. Choose the right version number - you can find that on a sticker at the bottom of the router - and download the user guide)
  4. Connect your computer to one of the LAN ports on the Linksys.
If you have any more questions or this desciption is not clear to you,just come back here and leave a comment - I'm happy to help.
May 22, 2009 | Linksys Wireless-G WRT54G Router
DSL loses signal during VOIP call.
i worked for verizon for two years and I encounter this problem many times,to tell you honestly,its not with you internet connection since if you'll notice,while you are connected to the internet and you make a call or call someone,its interrupted... Obviously,its the phone itslelf,the signal comng from the phone is different from the signal of the internet...thats the reason why you need a modem to convert the signal coming from the phone line to make it work for internet,,,what I suggest is you change the DSL plan from the Dry Loop to the regular dsl with the phone...
thanks and God Bless
Mar 20, 2009 | Westell Wirespeed LiteLine 6100...
My cable modem is not recognizing my router/phone adapter.
Try turning all items off including PC, unplugging all including PC. turn on modem, turn on router then boot PC
Jan 04, 2009 | Arris SURFboard Cable Modem
Wireless network broken, access to WRT54G & Motorola 2210-02 via http.. denied
I have att yahoo dsl which I installed about a year ago. The process required bridging the ADSL Modem (in my case a speedstream 4100) and accepting dynamic IP addresses and configuring PPPoE on the WAN side of my Linksys router. The ATT support person walked me through the entire process over the phone even though I was comfortable with making the Linksys configuration changes as I had to do the same in China without technical support. The modem configuration was no more difficult than the router configuration as it was performed from a web browser too. The biggest warning was that to reverse the modem change (if desired) required use of a reset button because the web interface was disabled as a result of the configuration change. My advice to you especially if you are willing to attach the Linksys router to the telco modem is to contact the ATT highspeed DSL support line and see if they will walk you through it like they walked me through it. Reviewing your Linksys User's Guide and understanding the configuration of that device would probably be appreciated by the ATT Support person as well as assuring you can access the Linksys router to configure it during the call.
Dec 08, 2007 | Linksys Wireless-G WRT54G Router
Not able to connect my voip adapter to internet
hello sir iam working for voip and iam a tech?
and u r using linksys pap2 which is not a router its just a phone adapter so it will work through a router so try this first
is ur modem is a modem router and u have 4 ether net port on it and u can able to access inter net through hard wired and connect this pap 2 adapter through one of the ether net jack on the modem router (ut starcom)>an dit has a fire wall which block ur voice signals so u need to open some ports on it try this link to open all ports and u need to try this with a pc which connected through hard wired on the modem router go to through this link
and also disable the fire wall on the router screen and reboot the linksys pap2 and ur ut star com modem router also and connect ur phone directly to phone jack 1 on the pap 2 device if u have any issues let me know
and rate me solved if its helps thx
Dec 04, 2007 | Linksys VOIP VONAGE PHONE ADPTR 2-PORT...
Hookup with Vonage device
I am going to attempt to give you a solution here. But you must understand a few things before I begin.
First, I would like to clarify that if you have Time Warner internet service, you are on Cable Internet. Not DSL. (This makes a world of difference when it comes to using a router.)
Secondly, you did not specify model numbers of your devices. Therefore I am assuming that you are using the following devices:
If this is not the correct equipment, continue to follow the instructions but be dynamic and adapt my instructions to the equipment you have. It should be similar enough that you shouldn't have any problem easily doing this.
This instruction set is going to begin from a point that is assuming that we're installing all of this equipment from the standpoint of a completely new installation. From the ground up.
Let's begin.
UNPLUG AND POWER DOWN ALL OF YOUR EQUIPMENT INCLUDING THE CABLE MODEM, ROUTER, PC AND VONAGE BOX. Do not power on any of the devices until instructed to do so.
1.) Connect your cable modem to the cable from the wall.
2.) Find the ethernet port on your cable modem. Connect the blue ethernet (CAT5) cable to the ethernet port.
3.) Plug the other end of the blue ethernet cable into the "Internet" port of the router. (Older routers used to also call this a "WAN" port.) It is the only port that is seperated from the rest of them.
4.) Connect another ethernet cable to port 1 of the router.
5.) Connect the other end of the ethernet cable to the network port of your PC.
6.) Connect yet another ethernet cable to port 2 of the router.
7.) Connect the other end of this ethernet cable to the ethernet port of the Vonage box.
8.) Plug in the power adapter of the cable modem. Wait 1 minute for the cable modem to acquire it's signal and set up the connection to Time Warner.
9.) Plug in the power adapter of the Linksys router. It should only take 15-20 seconds to set itself up. (If you have made any configurations to the router prior to this, I recommend pressing and holding the RESET button for at least 10 seconds to give you a fresh configuration state to start with.)
10.) Plug in the power adapter to the Linksys PAP2 VOIP Phone Adapter.
11.) Power on your PC. You should have an internet connection with it.
You see... As I read the configuration you described, I don't think that you're using a PAP2 phone adapter. You said that you connected the "vonage device" to both your modem and your PC. This is not possible with the PAP2 adapter as it only has ONE ethernet port.
I am led to believe that you are actually using the Linksys WRTP54G which is essentially the same thing as the WRT54G, but with Vonage support built-in.
If that is the case, then you will not need to use the WRT54G router. Instead, follow the instructions that I gave you assuming that the router and the phone device are combined into one device. (The ports will still be labeled the same.)
Download the installation guide for the WRTP54G from the product page link I just gave you. You'll find the link to the User Guide on the right-side panel. This will make everything clearer for you if you do indeed have that router instead of the PAP2 phone adapter.
If you continue to be confused, please let me know. DO NOT just give me a poor rating without asking more questions. I am here to help you solve your issue. Not have my rating decreased just because someone is too confused or lazy to ask more questions.
I'm happy to help you. :)
Good luck and let me know what the outcome is. (And please be sure to list your exact model numbers in the future!)
Nov 11, 2007 | Linksys Wireless-G Broadband Router
Linksys WRT160N Wireless Router  Logo
289 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
