Question about HP Pavilion dv9000z Notebook
Sound is coming out like broken speakers when using stereo input
I'm a court reporter. The software I use has to run with stereo input. I have a separate box that a live mic plugs into, as well as a USB cable which also connects to the computer We've been able to get it to record but the sound comes out staticky and like broken speakers. When testing the sound, everything else sounds normal. The owner of the software suggested I get an external sound card, Audigy 2 ZS notebook which is discontinued. Any suggestions?
    Novelist:
  • 137 Answers
The sound card would almost certainly fix the problem. One thing to do is to try a program like Audacity which will help you determine where the problem is. Then try it with your mic setup as it is.
Posted on Nov 12, 2008
Stereo only playbacks in mono. it used to play stereo
Stereo is actually two identical amplifiers which when the left and right of a stereo signal is fed into the respective inputs will reproduce the stereo sound through the left and right speakers.
Mostly there is a mono/stereo switch so if only a mono signal is available it is reproduced through both speakers.
You don't make it clear whether the playback is in mono or half a stereo?
If playback is in mono it will emerge from both speakers but the directional element will be absent. If the playback is in half a stereo the sound will emerge from one speaker only or mostly one speaker.
Most common problem is the failure of one of the amplifiers which could be electronic or the failure of any of the various switching usually used in such things.
The amplifiers can be tested by injecting a signal into each amplifier input and will be found satisfactory if the sound emerges from each speaker in turn at a similar volume.
Sep 01, 2017 | Audio Players & Recorders
Looking for a list of receivers will run 901 Series 4 speakers with external equalizer for home theater use
The key to running the Bose 901s is to have the equalizer inserted into the tape monitor loop. Most 'old school' stereo receivers have tape monitor inputs. On an AV receiver, the VCR or CD analog inputs/outputs could be used but you will be limiting your listening to stereo sources. Please be aware that some AV receivers will not allow you to select different audio and video sources. The Marantz NR15xx, SRx004 receivers are pretty flexible, and allow you to pair up a component audio input with an HDMI (or other) video input. (No surround sound in this type of setup...)
Jan 19, 2015 | Audio Players & Recorders
I am trying to get the rear speakers for my clarion stereo to work. I found where they were wired to an amp at one point. I put in a new amp and the input is through the speaker wires, not RCA input. The...
Are you using the factory speaker wires or did you run brand new ones ?
That could make a big difference
this may sound dumb but....
is there an input switch on the amp?
And is the polarity correct on the input wires?
Jun 02, 2011 | Clarion Car Audio & Video
I have a stock stereo and two subs with an amp in the trunk. Also two alpine speakers in the rear. Whenever I turn my balance to the left my subs don't play. What's wrong?
Hello.... I am sorry to hear you are having problems. The reason for this is that since you have a stock stereo, the shop (or person) whom installed the amp and subs used a line out converter. What this part does is allows the connection of RCA cables to the factory head unit. Almost all bass signals are always in stereo, so since you were only hooking an amplifier for just subs, you can actually just connect to just one of the rear speakers instead of connecting to the right and left. Just makes the install a little quicker. There is nothing wrong with this as I usually do the same thing in our shop. However, if you are going to be using the balance control, then you will need to go back to the shop and have them hook the converter up in stereo (to both rear speakers). Hope this helps!
20 year car audio/video installer
Bay manager
Mar 15, 2011 | Alpine Car Audio & Video
Hello...I have an issue with my speakers. My husband ran our speaker wires from our computer to our stereo and I can't get it to produce sound please help!!!
Be sure you plugged the plugs into the right ports on the back of the stereo.
From the computer: ensure you plugged the cables into the Auxilary Out, or Out jacks of the sound card.
On the stereo: ensure you plugged the cables into any open set of Auxilary In jacks.
Once you verify your cables are plugged in correctly, verify the input on the stereo is set properly. Set your stereo's source or input to "Auxilary" or "Auxilary 1 or 2." This allows the stereo to pull input from the cables running into the appropriately selected Auxilary source.
That should help hopefully.
If you still can't get sound, double check your computer's sound card settings and be sure the sound card is working properly.
Jan 10, 2011 | YouTube Videos
What's the best way to connect a PC (with DJ software) to a Fender PAssport 500 PRO (I want stereo input)?
Best way is to use a 1/8 TRS (stereo) to 1/4 TRS (stereo) cable from the PC into the Stereo 1/4 inch jacks right below the RCA stereo input jacks.
TRS stands for tip-ring-sleeve which means the jacks have the extra "ring" over a mono jack.
Jan 28, 2010 | Fender Passport Deluxe 500watt Sound...
Only sound from Direct and Stereo settings on Denon AVR 788
Other listening modes (dolby, dts, neo6) are decoded from digital signals.
Direct will relay your only your discrete analog inputs - so if you want to use your AVR as an amplifier for those channels, you'll need to supply an input signal in a different manner.
Nov 16, 2008 | Audio Players & Recorders
Pc connection
yes,,,i think it will on run 2 speakers,,, get y cables
Jul 11, 2008 | Celestion S10 Subwoofer
Stereo to 5.1?
When you switch your Sound Field to 2 Channel it should use all the speakers (although you'll notice it doesn't sound as loud as normal coming out of the center speaker). Auto Deco actually sounds good in this mode, in my opinion.
Jan 04, 2008 | Sony DAV-C770 System
Can't get B Speakers to work
Use the remote and switch it to be in the sub mode (top right corner of remote) It is here (in the sub mode) that you can change volume and inputs.
May 29, 2007 | Onkyo TX-DS555 Receiver
HP Pavilion dv9000z Notebook Logo
75 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
