Question about U-Line Icemaker
Lack of water in tray.
U-line ice maker becomes extremely  noisy when the water level in the pump tray is low.  Is there away to increase the water flow.  The inlet filter has been cleaned and the water pressure seems ok, not checked with pressure gauge.
Noise seems to be from pump, and goes away when we add water manually.
Help.
    Problem Solver:
  • 10 Answers
Check and make sure that as it makes ice that no water is spilling over or out of the freeze tray. only a set amount of water comes in to refill resevoir. if you lose water during the freeze cycle the water level gets below the blades of the pump and it will sound like the pump is tearing up.
Posted on Dec 19, 2008
Ice maker won't make ice
most times I see the tray and fill tube ice up its due to a leaky fill valve , this valve should close tight after filling tray , but sometimes they leak just slightly then everything freezes up in a block of ice
fill valves on most all units is located in back lower left corner , just follow the water line in the back of unit
Jan 15, 2016 | True Refrigerators
Ice maker stopped working
Check ice level arm is free to indicate low ice arm should be down also check icemaker position switch if tray is not all the way back icemaker will not run.
Oct 04, 2015 | Whirlpool Refrigerators
Reassembly of ice maker managemylife com
What make and model ice maker?
Jun 17, 2013 | Washing Machines
The ice maker
see this causes and fix it. God bless you
Makes to much ice or won't shut off.
Check shutoff arm. This may be hung up on ice or food item.
Makes no ice.
Check shutoff arm. Check to make sure it is getting water, check water solenoid. Check water supply line it may be frozen or plugged up. Check freezer temperature to low of a temperature could cause the line to freeze up. Check for power at motor. You will need to remove the ice maker. Find the leads that go to the auger and connect a voltmeter. Press the dispenser lever you should have power if not replace the control board or micro switch. Check control switch or microswitch. Put icemaker in test mode. Only some are equipped.
Ice cubes to large or small.
Adjust size by removing cover and turn adjustment screw + or -. Check water solenoid. Check water supply line. Make sure it is level.
Ice tastes bad
Clean ice tray. Check supply line. Check water solenoid. Change filter. Run at least a 3 gallons of water thru the line after replacing filter this will flush all old water.
Ice is discolored.
Check water solenoid. Check supply line. Change filter. Clean ice tray. Run at least a 3 gallons of water thru the line after replacing filter this will flush all old water.
Most ice maker problems require either replacing the ice maker unit or the ice dispenser control board or micro switches.
Sep 28, 2012 | Washing Machines
RS 2545SH ICEMAKER
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Try swapping the wires on the dual water inlet valve. It’s on the back where the water supply comes in. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
Feb 22, 2010 | Samsung Refrigerators
Ice maker is extremely slow. it will take days to
change the cooling contro indicator to freezer max ..... that will increase the speed of cooling in ur freezer ....
Jan 03, 2010 | Kenmore 52632 / 52634 / 52639 Side by Side...
Ice maker is leaking into the tray where the ice is dispensed causing the ice to become embedded into the tray
there is a screw in the ice maker unit that can adjust the water level open the ice maker whit cover and you should see it but turn it gently little by little each time...and see how much you getting :) very EZ good luck
Jun 06, 2008 | GE PDS22SIS Bottom Freezer Refrigerator
Ice maker problem on a Jenn-Air JRSD224W
check your water pressure if it is low then you are not going to get a good fill. you can adjust the fill on many icemakers look for an adjustment screw on the motor head
Apr 20, 2008 | Jenn-Air JCD2295HES Side by Side...
HOW TO ADJUST WATER LEVEL IN ICE MAKING TRAY
Your water pressure is too low. If you live in an area with low water pressure you would have to get a booster pump for you frig. Otherwise you can check the supply line and make sure it has no kinks in it. according to the manufacturer the small ice cubes will not effect the performance of your frig
Jan 24, 2008 | Refrigerators
The ice maker usually is an easily removable assembly, lift and pull or something like that. It may be the little water line has cracked, plastic don't like being cold.
Jan 14, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
U-Line Icemaker Logo
138 people viewed this question
Top U-Line Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
jasbo
jasbo
Are you an U-Line Kitchen Appliances - Other Expert? Answer questions, earn points and help others
