Question about Kenmore 22422 Top Load Washer
Kenmore 70 series will not rinse pleave advise how to fix this problem
  • dmab273 May 11, 2010
    changed clutch brought to repair shop they said nothing was wrong. It has to be the switch. HOW DO I REPLACE THE SWITCH. Is this a DIY project?
  • 261 Answers
If the machine agitates, spins and drain ok I would try different cycles and if some work and some don't change the timer. Timer is model 3951166 and runs for around 112 dollars Availible here only: WASHER, COMPACT A/W&diagramPageId=00002&componentDescription=CONTROL PANEL&documentId=P0102319&backToLink=Return to Sub Components list
Posted on Nov 01, 2008
Kenmore Heavy Duty Series 70 washing machine gets stuck in cycle.
Either your timing motor has broken or the gears that it drives are stripped. The timing motor is easy to replace but if the gears are stripped you will need a whole new dial assembly.
May 09, 2017 | Kenmore Washing Machines
I got kenmore 70 series. it doesnot spin but it
You have a bad lid switch . This is the piece , the lid actuator piece , goes down onto , in the hole on the top . Try putting a screwdriver into the hole , to activate the switch , to drain the water and to spin the clothes dry enough to remove , until the switch can be replaced .
Nov 26, 2009 | Kenmore Washing Machines
Kenmore series 70 washer leaks during rinse?
the was exhaust hose is either plugged or cracked. also check the drain it is put into as this sometimes will be puleeged with fabric from the clothes you wash
Jul 10, 2009 | Kenmore 22422 Top Load Washer
What is the date of manufacturing based on the serial number of my Kenmore 70 series washer?
It came off of the Clyde, OH production line the 26'th week of 2001.
Amazing, ain't it? Seriously... the info is embedded in the serial number. Here's the link to the code sheet.
Please remember to rate this solution as "FixYa", OK?
May 02, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore 20722990 series 70 will not drain
I have the same problem right now. I found a dime in the discharge but it still does it. I am going at it from the front side of the pump now. I need disassembly instructions for the upper sections to get to it. It was really nasty dirty and stinks.
Mar 18, 2009 | Kenmore 20722
Kenmore series 70 washer won't stop agitating when lid Is lifted.
I have a Series 80 and when I lift the lid it does not stop aggitating when in wash mode. When I lift the lid it does stop spinning when in rinse mode. As designed.
To stop wash-mode aggitation at lid-lift, using the existing lid switch and other electrical components, is not easy and not recommended. I can think of a way to do it (triple-pole lid switch) but I will not detail the idea .. for safety concerns.
To stop aggitation, simply use the main settings dial control. You'll save money and possibly prevent a fire hazard!
Jan 23, 2009 | Kenmore 22422 Top Load Washer
Kenmore 70 series model #11020712990 won't rinse
The TIMER is what is bad in this case.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 13, 2009 | Kenmore 20172 Top Load Washer
Kenmore series 70 washer doesn't fill
check your incoming water supply, the buzzing sound is coming fromthe waterinlet valve , soundslikke its trying to fill. possible that the valve is no good as well,
Nov 23, 2008 | Kenmore 22422 Top Load Washer
Kenmore 22422 Top Load Washer Logo
288 people viewed this question
Sal De
 Brian Main
Brian Main
