Question about Cobra 29 LTD CB Radio
My Cobra 29 ltd classic
My cb is smoking at the button controls and smells like burning.
    Genius:
  • 1,139 Answers
Hello MyPete,
You have some form of short circuit in your CB, most likley I would suspect the Power supply or the RF Power Output Amplifier. Here are some basic instruction on how to tell wher the smoke is coming from.
1) disconnect and remove your CB from your vehicle and put it on a workbench
2) remove the cover from your CB and expose the circuit board to view
3) connect your CB to an external 12 volt power source and antenna or a dummy load
4) power up the CB and determine where the smoke is coming from then turn off the power supply to the CB
5) At this point you will need a schematic of your CB (get one from www.servicemanuals.com)
6) find the point on the schematic that relates to the point where the smoke is coming from
7) using a ohmmeter determine which component and or components are shorted
8) replace the shorted and or malfunctioning components.
9) test the system (power on, transmit and receive)
10) close the unit back up
11) reinstall into vehicle
12) run tests again.
This should help
Thank you
Shutle832
Posted on Nov 01, 2008
Lx29 blue tut. Locked in 9/10 mode. How do I reset it?
PDF]EIi?tr,iitts - American Radio History
www.americanradiohistory.com/Archive-Radio.../90s/.../EN-1993-11.pdf
Nov 5, 1993 - 64 AUTOPATCH SELECTOR FOR RADIO AMATEURS ..... Memorymodes can store readings while ..... est way to do it is to base the circuit .... width (with increasing values of CB), .... Electronics Engineers' Book Club, Blue Ridge Summit, PA 17294- ...... lock onto the 19 -kHz pilot sub- ...... manually reset.using fgets to read one line at a time - Experts Exchange www.experts-exchange.com > Questions
Nov 11, 2008 - 1: 2: 3: 4: 5: 6: 7: 8: 9: 10: 11: 12: 13: 14: 15: 16: 17: 18: 19: 20: 21: 22: 23: ..... helium viceroy Audrey Isaac provision grammar cobra adrift died Liverpool .....wriggle do carbuncle firebug Elsinore Connally annotate anaconda could ..... pretend quadratic Euphrates RCA amuse CB
Cobra 29 LTD Classic CB Radio - YouTube? 5:42https://www.youtube.com/watch?v=vJle8vlsWLcAug 20, 2013 - Uploaded by C B WorldIn this product review we look at the Cobra 29 LTD Classic CB radio and ... Just like in the manual. most channels are below 3. a few are not.Cobra 29 LTD Classic Troubleshooting - iFixithttps://www.ifixit.com/.../Cobra_29_LTD_Classic_TroubleshootingiFixitCobra 29 LTD Classic is not transmitting or receiving. The Antenna is not tuned correctly; The Radio is not in CB mode; The Radio is on the wrong channel; The ...Marine Radios ' Cobra Electronics Corporation
Jan 07, 2016 | Cobra Radio Communications
How to fix the dimmer light ona cobra 29 nw ltd classic
HI I AM TRYING TO FIX MY 29 COBRA LTD IT WENT OUT ON ME
Feb 04, 2011 | Cobra 29 LTD CB Radio
29 ltd classic wont transmit
Great radio when it works.
If you have your settings on CB - not PA - -be sure that your Cobra has that setting selected.
If CB -is selected and still nothing - be sure you have a working mic. These wires are fragile and can break internally. One easy way to check is to borrow a cobra mic or even drop by a CB repair shop and ask them to do a mic check with the mic - it is free.
If you have a bad mic replace it and all should be well.
If your mic is good and it still doesn't transmit you will need to replace the finals in the unit. It is common that these burn out of you got too close to someone with too powerful a radio. The CB shop will need to look at it further and repairs should not be over about 40.00.
Good luck with your Cobra.
Mar 31, 2010 | Cobra 29 LTD CB Radio
I have a cobra 29 nw ltd classic i cannot hear or be heared
Start with the antenna that you have hooked to it, is it grounded, is the coax in good shape, is the connector in good shape. stuff like that.
Jun 14, 2009 | Cobra 29 LTD CB Radio
Cobra classic 29 ltd
Had fixed the same problem yesterday. My cobra worked when it wanted to, when it didn't it looked like you explained. I found out that on my cobra the blue wire on the mike connector was broken. When it disconnects, no sound. after soldering, everything works fine.
Dec 04, 2008 | Cobra 29 LTD CB Radio
No TX Power
If it is classic it is a 2SC2029 driver transistor.
Nov 18, 2008 | Cobra 29 LTD CB Radio
Shorts my power supply when plugged in
do you have boots powering up the signal that can do it
Sep 27, 2008 | Cobra 29 LTD CB Radio
Cobra 29 LTD Classic Operations Manual
For the operation manual, go to cobraelec.com or:
http://cobra.com/downloads/manuals/29LTDCLA.PDF
Thanks!
Dodgem
http://dodgem250.angelfire.com
May 05, 2008 | Cobra 29 LTD CB Radio
Cobra 29 LTD CB Radio Logo
177 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
