Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
RCA 52 INCH CONVERGENCE PROBLEM HELP/already replaced the fl231 fuse
I replaced the fl231 fuse because the convergence fuse went out (the option for the convergence in the setup menu was gone)and it fixed the problem for 4 days then it did it again.So then i replaced the same fuse again and the tv worked for a couple of hours then the convergence went out again only this time the option for the convergence in the setup menu is still there but when you click on it it doesnt let you adjust anything and the auto convergence starts to go but then quits after a few seconds and the picture looks the same.
I dont know anything about tvs i just got the idea to change the fuse from this forum. if it is the convergence board where is the board located?
any help would be awsome
  • Anonymous Nov 01, 2008
    problem with yellow lines on the sides of pictures and the edge
  • RCA Master
  • 3,459 Answers
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
RCA 52 INCH CONVERGENCE PROBLEM HELP/already repla - bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Apr 03, 2010
Hi I have a convergence issue. Is there a place in NYC where I can purchase these replacement items: (1) FL231 micro fuse (1) DL231 Diode (1) CL230 radial Capacitor I repaired the initial...
This DLP model RCA tv have convergence menu disappearing is very easy to fix just replaced the convergence fuse FL 231 near the FBT also must be resoldering FBT too.U can buy this FL231 covergence fuse at Ebay.com.No,but u must have to have a soldering iron,a desoring pump or desoldering braids and know how to basic soldering?To replaced this FL231 convergence fuse near the FBT and also must resodering the FBT too for protecting the new FL231 convergence fuse.
Mar 02, 2011 | RCA R52WM24 52" HDTV Projection Television
How do I access the menu to get to the auto convergence setting. My screen has lost its autoconvergence.
Than this RCA DLP tv have convergence fuses.Convergence fuse is dead.U have a soldering iron, desoldering pump or desoldering braid and can u do basic soldering? Replaced convergence fuse FL231 that near the right FBT.The one in the Middle out of the three useally dead.Try Ebay.com to buy the FL231 convergence fuse.
Jan 21, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
I need a convergence kit for a rca 52 inch rear projection tv
what type of problem with convergence? no convergence at all? pitcure bowing? this in the setup menu do you have the convergence option? a convergence ki in a standad porojection has stk ic/s this model does not .you might have the fl231 fuse problem.. generally its board replacement. then the problem becomes alighnment.
Aug 23, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
The convergence on this television has obviously developed a problem. The three colors have completely separated. A picture is still visible. I attempted to apply the convergence option from the set-up...
This RCA tv model use a convergence fuse.The covergence fuse FL231 is dead.U have soldering iron,u can do basic soldering?Try Ebay.com to buy the convergence fuse for the replacement.This FL321 have three fuses,the one in the middle is dead.The FBT,the big black block of plastic,resolder that too.
Aug 20, 2010 | RCA R52WM24 52" HDTV Projection Television
I can find where to line up the pluses for the colors
No,convergence screen set up menu appear,Mean convergence is dead.Replaced the FL231 all three of these caps convergence fuse,near the FBT,big black block of plastic,flyback tranformer.Resolders FBT also.Done this will solved ur convergence problem in this RCA tv model.Ebay.com to buy the FL231 convergence fuse for the replacement.
Mar 22, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA R52WH77 ITC222A chassis convergence problem - FL231 changed!
did you hear an arch before it went if so , one of your crts is arching
and sorry they are not avail anymore
Sep 20, 2009 | RCA Televison & Video
RCA 52 INC MODEL R52WH77
From the symptoms you describe. you have the fl231 fuse problem. Congrations this is a simple fix. please read my article "the fl231 fuse problem" in the tips and tricks section
Apr 13, 2009 | RCA HD52W59 HDTV Projection Television
Rca 52 inch convergence
You have a opened fuse FL231 next to flyback transfomer are 3 Fuses they look like small brown squares/ Fuse in the middle is bad when you do not have convergence listed in menu.You can pull the top off of these fuses .
Nov 06, 2008 | RCA P52960 52" Rear Projection Television
FL231 fuse on RCA hd56w66??
the rca itc222 comes in both 56 and 52 version.. If you do not have the convergence option in the customer menu under setup then there is a high chance that the fuse will be the trouble
Oct 02, 2008 | RCA HD56W66 56" HDTV
RCA HDTV Fuse location
There are 3 small rectangles that are on the right side of the flyback, they are micro fuses FL231 is the center one. I am not sure if radio shack has them, may have to order from RCA
Jun 30, 2008 | RCA R52WM24 52" HDTV Projection Television
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
691 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
