I got to turn on my laptop and it boots to the log on password screen then it freezes and reboots itself, then repeats the same process over again. it is an acer aspire 4220, running vista home basic.
Hi thanks for that but i cant find my recovery cd.... is there any other was of fixing it
Posted on Nov 02, 2008
  • 4,338 Answers
Boot your recovery cd and choose the language, then on the second page , select repair options. Then on then next page, select system restore. Pick an earlier date restore point, and let it finish. It should restore it to where it was working.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 01, 2008
CANNOT LOGIN TO ACER LAPTOP
hi Jo.
an id password is what is needed to let you log on to your laptop.
if you do not know this then you will not be able to use the laptop.
so you will have to try this.
Please do try these troubleshooting steps that may help in solving the issue.
- Do a hard reboot, remove the battery and unplug the AC adapter then press and hold the power button for 20 seconds then try logging in again.
- If it doesn't work do try logging in Safe Mode, while the laptop is booting up repeatedly press on F8 until it loads Advanced Boot Options and select Safe Mode then press Enter.
- If it doesn't work in Safe Mode you may need to reinstall Windows to solve the issue.
Please try this: turn off your computer. Then turn it on, and right after the black screen with white text or the computer company logo disappears, press & release key F8 repeatedly until a menu appears, then you select Safe Mode (note: if there is no menu, then try the same steps again, but this time, press key F8 a bit earlier). Then login and click Start->all programs->accessories->system tools->system restore and restore the computer to any date before this issue has occurred, then wait until system restore finish, then check.
if this does not work you may have to put a new set of windows back on your laptop.
Nov 28, 2017 | Acer Computers & Internet
How to reset admin password with the cmd when you are a standard user
What's your operating system? After logging in as standard user, you have insufficient privileges to change the admin password via cmd. You need to boot with Windows install media, and replace sethc.exe with cmd.exe. When rebooting to the login screen, you can launch a command prompt and reset your password there.
http://www.top-password.com/knowledge/reset-windows-7-password-without-reset-disk.html
Dec 20, 2016 | Computers & Internet
Reset my password on my acer laptop
If you know the current password then click Start/Control Panel/User Accounts. Under user accounts select change password.
If you forgot the password, turn off the laptop then turn it back on and repeatedly hit the F8 key until you see SAFE Mode. Select Safe Mode and let it boot up. You will see a login screen with the Administrator account and the Account of the id that you forgot the password. Select the Administrator account (hopefully it will not be password protected). One you are logged in click Start/Control Panel/User Accounts. Select the account for which you forgot the password and then select Remove Password. Reboot your laptop.
Mar 14, 2012 | Acer Computers & Internet
I don't have a password for the set up utility screen!
BIOS password to enter set up?
When you boot up to the log in screen type in administrator as user to log in if you cant log in
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there
if no luck with this
The most common way that we know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the Cmos battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased.
Hope this helps you
Sep 07, 2011 | HP Computers & Internet
I have a Toshiba NB205, which is a netbook without a CD reader. I have forgotten my log on password and Ctrl+Alt+Delete doesn't do anything when I push it in the log on screen. Is there anyway to...
Try log in as Administrator account from Safe Mode. Reboot, after the first screen bios information, press F8 button repeatedly before the Windows logo come out, after that select Safe Mode At the Top one, after the boot, log in administrator account. Username: Administrator Password: -just leave it blank- When you logged in, go Control Panel, then User Control/User Account, then select the account which you forget the password, now remove the password.(or you can change it) Reboot your system.
Aug 31, 2011 | Computers & Internet
I changed my administrator password and im the only person on this computer and i cant log on
When you boot up to the log in screen type in administrator to log in once you have your computer running again you have to take control (administrator)control panel user accounts on the users tab,click the name of the computer administrator you can change the password there or if your computer has a system restore you can restore it to an earlier date which will have your personal settings
or
Press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there
also
hope this helps
Jan 06, 2011 | Acer Aspire 3680 Laptop
Dont have adnimastraighter password and want to reboot my laptop from manufacture sales
i hope you mean manufacturer (factory default settings)if so
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer)
as for the password
When you boot up to the log in screen type in administrator to log in if you cant log in
also
Hope this helps
Jan 02, 2011 | Computers & Internet
About 2 months ago my P305D-S8900 locked me out with a blue box saying I needed a BIOS password. . I contacted Toshiba and they sent me a box to ship it back to them to be fixed, which they did. Today...
or
hope this helps
Dec 14, 2010 | Computers & Internet
Computer when i turned it on said disk read erroe occured and now when i try to start it in safe mode it just keeps restatring it self
Start up your computer.
Immediately insert your Windows XP install CD. As the computer boots, a boot menu will appear (if you did not insert the CD in time, you will not see the menu; in this event, simply reboot the computer again).
Select the option to boot from the CD. A setup screen will soon appear.
Press the "R" button on your keyboard at the setup screen in order to open the repair console.
5
Type in the administrator account's log in password if you are prompted to do so. If there is no log in password, simply leave the password slot blank and continue. After this step, a command prompt will appear.
6
Type in "chkdsk" (minus the quotation marks) and press "Enter." Allow the operation to run.
7
Type "Exit" (again, minus the quotation marks) when the operation is complete, and press "Enter." If your computer boots correctly, great! If not, move on to the next step.
8
Reboot and repeat Steps 3 through 5.
9
Type "fixboot" (minus the quotation marks) and press "Enter." Once it is complete, repeat Steps 7 to 8.
10
You might need to reinstall your operating system.
Thanks.
Oct 22, 2010 | Dell Computers & Internet
When I turn on my computer it begins the boot then goes black
Try booting into safe mode. That will disable all drivers and use generic windows drivers to send commands to the devices. If that still doesnt work, id say that there is a problem with your OS installation. Backup your files using an external harddrive enclosure and reinstall the OS.
Jun 04, 2009 | Dell Latitude D600 Laptop Computer -...
Computers & Internet Logo
60 people viewed this question
David Payne
David Payne
