Question about Dell 1600n All-In-One Laser Printer
Line prints down page when you copy
Everytime we try to make a copy, it prints a line down the middle of the page. If we print, it works fine. Any ideas? I have run the clean drum process and this does not seem to be helping it.
  • Anonymous Aug 21, 2008
    Thanks for the advise. I had the same problem. Your advice fixed it in less than 5 minutes on two separate machines.
It worked! There was a bit of ink or something stuck on the smaller glass plate. Once I cleaned that off, badabing!
I love this site!
Posted on Jul 03, 2008
No promise that this will work for everyone, but I just fixed one with the same problem. I figured either there was something on the scanner sensor itself or on the glass. If you look to the left of the large glass scan area, you will see a smaller glass strip. When you use the auto document feeder, the scanner stays under that piece of glass. To narrow the problem down, I tried copying a sheet on the large glass (not using the ADF). No line. So, it wasn't the sensor itself, it had to be something on the small glass. That piece of glass is held down with double-sided tape. Dell tries to keep dust and dirt out of the interior of the unit, but it isn't hermetically sealed. So, when something gets underneath the glass, it can stick and create a permanent spot where the sensor only sees darkness. First, try cleaning the top. Look very carefully at the glass about where that line is appearing on the paper (if the line is 2 inches from the side, look about two inches in on the glass. If you are lucky, there's some whiteout (famous for screwing up scanners) or something else stuck to the top. Clean it. Gently. If you scratch it, you're going to hate your scans and copies forever. If it's on the bottom, prepare to void your warranty if Dell finds out, but carefully and slowly pry the piece of plastic holding the small piece of glass out of the machine. It's just sticky tape, but it is on all sides of the piece and it covers the large piece of glass, too. That's where I started, using a very small knife edge to slowly pry up the plastic from the large piece of glass. Little by little, the piece came up. Again, be careful. If you pry too hard, you can break the large scan glass or the piece of plastic you are removing. Once it's out, don't get any dirt on the tape that held it in place - it needs to work when you finish. Now, gently clean the glass. I used a lintfree cotton rag and some glass cleaner. In about a minute, I was able to remove all traces of dirt from both sides and put it gently back into the printer. I haven't had a problem since and hope you have the same luck!
Posted on Oct 14, 2006
Had the same problem with two printers. Cleaned both in less than 5 minutes. No more lines. Thanks.
Posted on Aug 21, 2008
The screen on the printer is showing for fax, I tried to change it because I am unable to print, I got the manual out, and it tells me to refer to my manual (huh?)
Posted on Jun 12, 2008
My printer is not printing all the horizontal lines
First try to copy and if copy works fine, means the hardware is fine and issue with the driver.
Do right-click on printer icon and select delete.
Once deleted, run the installation disc and click on add a device, follow onscreen instructions to complete the installation. Open printers and faxes window and then do right click on printer icon and select properties, click on print test page.
Check if it prints fine, if yes try to print from other application. I hope it will work.
May 26, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
HP Laserjet 3330 printed dark page especially around the middle
Does this happen both when copying and printing?
For printing solution, try another toner cartridge.
If lines continue to appear when copying (primarily through the automatic feeder) then lift the auto feeder, and clean the glass -mainly the narrow piece on the left side.
please rate solution :)
Apr 07, 2009 | HP LaserJet 3330 All-In-One Printer
Whenever I scan a picture or document I get a line going down the middle of the page. When I print the same document the line prints down the page. THIS only happens on the scan not when I print from the...
first of all try to make a copy..when you make a copy if you get lines..then clean the scanner glass and the rollers..if its still the same..connect the printer directlu to the wall outlet and then check
Mar 09, 2009 | HP OfficeJet 7410 All-In-One InkJet...
HP 2600N PRINTS A BLACK LINE VERTICALLY ACROSS THE PAGE (FROM TOP TO BOTTOM) RIGHT IN THE MIDDLE EVERYTIME YOU PRINT SOMETHING . WHAT COULD THIS BE? I HAVE CLEANED EVERY DRUM, THE FILM ETC AND IT KEEPS...
You either have a defective black toner, a bad fuser or transfer belt. From my experence it is usually a bad toner cartridge. After you print a couple of pages, pull the black toner and see if there is anything on the drum. If there is try shaking the toner, sometimes toner does like dirt and clogs up. If you still have problem you will have to try another toner. I know that is not cheep, but I don't know any other way.
Mar 02, 2009 | HP Color LaserJet 2600n Printer
Line on paper after page prints
This seems to be a common theme. I just posted a response to someone here with a similar problem. HP.com has a web page that can help you go through a series of diagnostic tasks designed to track down this problem:
Streaks or Lines in the Printed Page
There's also a help page that talks about lines on pages when you use the Copy feature. Not quite your problem, but it may help:
White Lines Through Copies
Hope some of this helps. Good luck.
Oct 09, 2008 | HP Officejet 5610 All-In-One InkJet...
Thick Black Line on my copies and faxes
Can't image it being anything but scan glass, if prints are fine, are you sure you cleaning scan glass(inside of where originals are fed)?
If so then scanner lamp faulty, but I've never come across it myself on this model.
Oct 26, 2007 | Brother MFC 8500 All-In-One Laser Printer
Dell 1600n All-In-One Laser Printer Logo
325 people viewed this question
Top Dell Office Equipment & Supplies Experts
David Patricia James
Marvin
Marvin
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
