Question about BenQ PE8700 Multimedia Projector
Projector shut down
During use, screen returned to "searching RGB input" box in corner; tried wiggling connection cables at which time lamp went off; both ried & green lights remained on on top of projector; turned unit off at switch, now will not come back on; unplugged, plugged back in, still absolutely nothing. wall plug does have power
  • PhilatCBS Nov 01, 2008
    Will have to try this later, my dinner party is starting (where of course I wanted to use the projector)
    We did all that and sadly it didnt help. Somewhere a user comment describing similar circumstances reported the main board may be fried and need replacement. Oh, joy. Now to find someone who services this equipment.
    Genius:
  • 1,447 Answers
Hi
Replace the lamp, or better yet try removing and reinstalling the lamp.;
Hope this helps
Posted on Nov 01, 2008
Sony Wega TV lost color now only B/W KDF-42A10 born 6/06
Sounds like it's something more than the lamp. Double check all your connections...it might be something as simple as needing a new cord (RGB, HDMI, Component Video, etc) Does the problem exist with all inputs? (For example, DVD player, cable, etc) If the problem is only from ONE input source, try replacing that cable. If it's on all input sources...might be something more internal on your TV.
Good luck
Jason
Oct 04, 2014 | Televison & Video
I tried to hook my wii to the new hd led flat screen but its black and white I tried doing the yello cable to green but it doesnt work and all the other inputs dont have ac jacks its just hdmi hookups
The yellow cable is RCA component and it sould not be connected to the Green port. Why not get a HDMi cable to make the hook up easier? Component RGB connection requires a RGB cable along with a stereo audio cable where as HDMI requires just one.
Jun 10, 2011 | Nintendo Wii Console
How to turn on rgb from lap top to tv.
In order to connect your laptop to your TV using RGB, you need an RGB adapter. RGB is also known as component video; it breaks up a video signal into red, green and blue. laptops do not have RGB outputs. However, many laptops have VGA, DVI or HDMI outputs. An RGB adapter connects the single VGA, DVI, or HDMI cable to an RGB cable, which is actually three different cables tied together. INSTRUCTIONS:
1. Connect either the VGA, DVI or HDMI (in the order of increasing video quality) cable to the VGA, DVI or HDMI port on your laptop, depending on what is available. 2. Connect the other end of the cable to the side of the RGB adapter with the single input. 3. Connect the RGB cables to the red, green and blue ports on the other side of the RGB adapter. 4. Connect the other end of the RGB cables to an available component input on the back of the TV. 5. Tune the TV to the component video input you used through your television's menu. 6. Turn on your laptop. The laptop should now display on your TV screen.
May 30, 2011 | Computers & Internet
The TV works fine but the screen is green. Color
R G B circuit transistor to be checked. This is located in the picture
tube connecting end PCB. ( Neck ) Check the transistor and its components.
Can be dry solder also!!
Jul 28, 2010 | Hitachi 50V500 50 in. HD-Ready LCD...
Green screen using HDMI input
Try using the RGB component input and see what happens. If it's normal, then you might have a software issue in the set. You'll get the same quality out of RGB as you would HDMI.
Dec 18, 2009 | Insignia 19 in. Widescreen Flat-Panel LCD...
Connecting hd cable box to philips 60 rear projection
So, You have Five cable leads, The rgb get plugged into there corresponding colors and the other two are your Red and White Audio Input ------Correct? You do not use the in4, that is for a pc with horiz and vert sync. You use input 1 rgb and plug the red and white into the audio input.....your done!
Jun 06, 2009 | Philips 60PW9363 60" Rear Projection...
How to eliminate error screen:"your tv does not allow display of this program through the dvi input source. please chose another tv input source."
"cable box to tv is hdmi cable"
Everything I've read on the web says cable box to tv connection must also use component (rgb) cables. The error is coming from the cable box (STB). All the Scientific Atlanta (SA) cable boxes seem have this Digital Rights Management (DRM) bug and the only way to be totally rid of the error is to replace the digital connection from box to the TV with an analog connection.
May 06, 2009 | Televison & Video
TV Picture is green
is your RGB cables are the same output from your tv...are you connecting from where dvd cable box sattelite box, if you are connecting from a box exs output of cable box is what colour are you using? for your your output to your tv and what input are you using of your tv set.[input 1is it video input 1,] or comp? let me know...
Jan 10, 2009 | Televison & Video
BenQ PE8700 Multimedia Projector Logo
109 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
