Reddy heater pro 110
Plug in ac outlet,fires up and works for 2-3 min. blows large puff of smoke and shuts down
  • 3 more comments
  • tex8 Nov 04, 2008
    Ordered a fuel filter waiting on parts to get here.
  • tex8 Nov 04, 2008
    How do I troubleshoot the circuit board?
  • tex8 Nov 09, 2008
    So far replacing the fuel filter seems to have solved the problem. Therstat controlls seem to be working ok. Thanks again
  • sjohnson188 Dec 05, 2008
    Hi I have a ready heater 70,000 and it starts and runs good for about two minutes then shuts down. I have read others have had this problem and have cleaned the photo cell . I have run it with out the top and runs fine for well over a 1/2 hour but when I put the cover back on, within two minutes it shuts down. Sounds like a heating problem.Any ideas, not sure if this has an overheat system for safety or not.
    Thanks
    Scott Johnson
  • Anonymous Mar 17, 2014
    reddy heater Pro 110 just blows fuel out of the front
  • 232 Answers
Does your heater use the older spark plug technology or the newer Hot Surface Ignitor (HSI) technology?
Without this critical information about all this technician can do is guess.
My best guess at this time would be either water in the fuel or a restricted fuel filter.
Posted on Nov 01, 2008
  • Jerry Magee
    Jerry Magee Nov 04, 2008
    As stated above, I was only taking a wild guess to a solution based on the information provided by you. If the filter does not cure the problem then answer the question that I asked you to answer previously.
    Again, here's the question "Does your heater use the older spark plug technology or the newer Hot Surface Ignitor (HSI) technology?"
    Here's why I asked the question- Spark plug heaters are simple to work on and simple to troubleshoot. The solution that I posted could probably solve your problem.
    On the other hand, if your heater has Hot Surface Ignitor technology, then there is a computer on board and you must troubleshoot to determine whether the problem is fuel related or electronics related.
    Don't just throw parts at the heater, hoping for a fix. Troubleshoot it, then throw the parts.
  • Jerry Magee
    OK. If your heater has a circuit board, then it is an HSI type heater.
    Again, did you check for water in the fuel. You never said. Simply shine a flashlight in the tank- look for water droplets rolling around on the bottom.
    In a hypothetical situation here is what happens. The heater is running good. Then a droplet of water passes through the nozzle. A momentary flameout condition. A big puff of smoke & unburnt fuel. The flame perpetuates itself, but the flame has been extinguished by the water. The photocell sees the lack of flame and directs the board to shut the heater down. The heater has done its job. For safety reasons it can't just continue to pump fuel into a hot combustion chamber.
    Go back to basics and check for water in the fuel before you check the board. You may just get out of this do-it-yourself project for FREE. No parts required.
    From DESA's tech bulletin to test the board
    "Remove fuse cover and check fuse
    (70,000 to 200,000 Btu models only). If
    fuse is blown replace it with a GMA-10
    fuse. Disconnect motor red and white
    wires from control. With Ignitor wires disconnected,
    attach voltmeter leads to the
    ignitor terminals (labeled IGNITOR). Use
    the 0 to 200 V.A.C. scale. Plug power cord
    into a grounded 120V/60 Hz outlet. Meter
    should read 120V(rms) for approximately
    10 seconds. If voltage reads 0 or stays at
    120 for more than 10 seconds, the control
    is defective and should be replaced."
Where is fuel filter pro 110
Posted on Dec 19, 2008
Reddy repair center
There are four possible answers to this problem, if the heater starts normally, runs for a few seconds or minutes and the shuts down but was still running normally at the time of shut down, this could be caused by the photocell, also known as the flame out control. This safety device may be failing, shutting down even though the heater is working normally, check the operation of the photocell. The second cause may be partial fuel filter blockage, the heater is effectively starving itself of fuel, so the flame blows out, hence the puff of smoke, and then shuts down on the safety cut out. Third cause, if this model has a compressor at the rear of the motor, the problem could be low pump pressure, caused by wear or contamination of the carbon blades, this would cause the wrong amount of fuel to be syphoned up, with weak fuel mix the heater may blow itself out and shut down. The fourth cause, perhaps indicated by the puff of white smoke, is contamination of the fuel with water, water will cause the white smoke and also is indecated by white residues or a power like substance on the end plate of the heater which glows red hot when burning.
Jan 24, 2014 | Desa International R40 Utility Heater
I have a reddy heater pro 100 it starts runs for a fwe min then blows a puff of smoke
get new filters check for cracks in lines dirty tip or mixer nozzle all the fun if back or side of unit is up a hair like a 1/4 gap between top and bottom does it run or have the inlet air covered then the nozzle is the problem
Dec 05, 2013 | Heating & Cooling
I have a 60,000 btu Reedy Heater runs 5-10 min then shuts off restarts black puff of smoke bad plug ??
Check the fuel filter on the units as well as the inlet and outlet filters on the back of the motor.
Watch the nose cone and see if the end starts to loose the glowing orange color before it quits.
If the unit slowly looses the color then you have a fuel problem but if the unit just quits at full heat then you could have a electrical problem.
Typically the spark plugs on these heaters don't go bad.
Oct 13, 2010 | Reddy Heating & Cooling
Reddy heater 55 runs about 5 mins the a puff of
This a classic occurance due to low fuel in the tank.
Jan 21, 2010 | Reddy Heater-30-55,000 BTU Variable
Surges then a big puff of smoke and it shuts down
Jan 02, 2010 | Reddy Heater-30-55,000 BTU Variable
Pro 110, runs 10 min., blows white smoke ,shuts off
the first thing you need to do is go back to useing K1 kerosene, diesel fuel not only burns dirty but also has a tendency to gel up in cold weather which could be makeing it hard for the heater to draw the proper amount of fuel. To reset the pressure you will need a gage, it should run at about 6-7 psi. you can order a pressure gage from mr. heater online, they are by far the cheapest I have found as they are the actual manufacturer or call 1-800-251-0001
Feb 05, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy Heater 50'000 BTU - Puffs Smoke and Leaks Out The End
Here are a couple of tips that I wrote that tell you how to troubleshoot aTorpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters Torpedo Heater Pump Pressure Adjustment
heatman101
Jan 30, 2009 | Reddy R60A Utility Heater
Reddy Heater will not ignite flame
Please answer the following questions. There are several folks on the board that can help but we need to know some vital information so we can get started. Answer these, if you can:
  1. Which Pro 110 do you have. We need the exact model number. Pro 110 is a series of heaters.
  2. Does the heater have a spark plug or a glowbar (HSI)?
  3. When the motor runs is it pumping fuel?
  4. When the motor runs is the spark plug firing (or glowbar glowing)?
Nov 13, 2008 | Reddy Heater-170,000 BTU Kerosene Deluxe
My best guess is that you are are connecting to your AC receptacle with an extention cord that is too small. The Reddy Heater contains a computer that will shut the unit off if it cannot pull enough amps from your service. The longer the cord the higher the loss from receptacle to unit. This loss can be reduced by increasing the size of your extention cord. I run a 100' 10/2 cord.
Hope this helps!
Handy Home Guy
Boone, NC
HandyHomeGuy.com
Nov 01, 2008 | Reddy Heater-170,000 BTU Kerosene Deluxe
Troubleshooting reddy heater 115,000btu
runs for awhile shuts down with a big puff of smoke comes out poured diesel 911 thought i had water in diesel fuel cans nothing help need solution ASAP
Oct 30, 2008 | Desa International ReddyHeater® R115DT...
Heating & Cooling Logo
1,884 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
