Question about Kenmore Oasis HE 27082 Top Load Washer
F code My washer stopped after the rinse cycle and now F 51 flashes. I can't find what the F codes mean anywhere. The manual says call for service, but they can't come for a week. Does anyone know what the F codes are and what they mean?
I also had the F 51 code. I was so scared that I was going to have to pay a ton to have my washer fixed, but I took off the back of my washer, and sure enough, just like the above experiences, there was a t-shirt stuck. Mine wasn't so easy to get out, but after LOTS of trial & error, (I actually ended up using a 3 hook fishing hook) my washer is running again! I am so grateful for the above suggestions! THANKS FixYa!
Posted on Feb 03, 2008
I tried all of the suggestions from the first reply. Then I did as the second reply and took the back off and spun the drum. There were a pair of shorts stuck between the drum and plastic wall. I also used a straightened metal coat hanger to remove the garment.
Posted on Jan 27, 2008
I too was getting the f51code. After trying the above remedy, unpugging the power, and disconnecting and reconnecting all other connections,(none of these helped in my problem, however). I took off the back of the washer and manually spun the tub. Lo and behold, a t-shirt had gotten between the tub and the wall, thus creating my error code. It was easily removed with a straighted coat hanger.
Posted on Dec 03, 2007
    President:
  • 878 Answers
Cari, your code means that there is a motor position sensor failure. There has been an issue with the first generation control boards on these washers and I do believe they have revised the board to take care of these issues. It could be just a loose harness going to the board but I would have the tech check it out. If you want you can put it into a manual test mode by doing the following; turn the power button on, choose any button except power,start and stop. Press for 3 seconds, release for 3 seconds, press for 3 seconds, release for 3 seconds, press for 3 seconds. If you entered it correctly, the consol will light up with an 88 showing in the display. While this 88 is showing, press the same key again, this puts you in the manual mode. In this manual mode, press the spin speed key, this will test the motor and possibly home it. To exit the test, just hit cancel/stop. If you can't get into the test mode, you will have to wait for the tech. Catriver..post back
Posted on Sep 18, 2006
I have a Candy CM126 washer. It will not go into the spin cycle. I have cleaned the filter and checked if the pump is ok. They are fine. However when the machine stops the Activa rinse and 90' lights flash...
It could be the NTC ? two small wires between the heat main wiring. Or Possible the heater is leaking to earth. You would need a meter to test , NTC should be about 18kohm
Sep 15, 2017 | Candy Washing Machines
What does it mean if the washer is not draining and has a flashing f where the time shows?
I have the manual for this machine. Under "Code 21" it says the following:
"F21" (Drain Problem) Select STOP twice to cancel the cycle. Unplug washer or disconnect power. Check the following: Is the drain hose kinked? Is the drain hose frozen? Is the drain hose clogged? Is the drain hose more than 96" (2.4 m) above the floor? Plug in washer or reconnect power. Re-select cycle and press START. If the problem remains, call for service.
For "SUDS" code, the following:
"SUD" (Suds Routine) When excessive suds are detected, a suds routine automatically starts. This routine removes extra suds and assures proper rinsing of your garments. "SUD" is displayed during rinsing to inform you that Suds Routine was activated. Use only HE (High Efficiency) detergents.
Here is some more information that may help you as well:
"F" Codes other than F20, F21 and F22 Select STOP twice to cancel the cycle. Select DRAIN & SPIN if there is excessive water in the washer. Re-select cycle and press START. If the problem remains, call for service.
I hope this is of some help to you, Please rate and comment, Thank You
Joe
Sep 07, 2011 | Kenmore HE2 Plus Front Load Washer
A code saying 5d or Sd is coming up on my machine, what is that
The code Sd means that suds were detected. Generally this means you used regular detergent instead of the HE detergent. Less often it indicates that you used more detergent than needed for the load.
Remember to use an HE (high efficiency) detergent and to follow the directions for the amount to use in a wash cycle.
The washer should do a suds correction program to make sure that the clothes are fully rinsed. However, if the code remains and the wash cycle dial is flashing, set your washer to repeat the cycle with cold water without adding additional detergent. (Every portion of the wash cycle will be extra rinses.)
The manual for the washer is available as a PDF from Maytag's support site. http://www.kitchenaid.ca/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%20W10092824.pdf is the manual for the MVWB750WB0. Additional manuals for MVWB750W washers are listed here: http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=MVWB750W&siteCd=MT_EN_US .
I hope this helps.
Jun 02, 2011 | Maytag MVWB750W Top Load Washer
HE2 front loadable washer doesn't move fm wash to rinse to drain
Sounds like the door lock. It will not advance to spin if it thinks the door is open. There is a instruction sheet inside the unit behind the lower panel. That will give the error codes for the flashing lights.
Sep 04, 2009 | Kenmore Elite 45986 Front Load Washer
MAH 2400 AWW flashing error code "dc"
Hi Pepsi,
"dc" means that the control board is trying to ramp up (that is, send a signal to the motor controller), but has encountered an unbalanced load and so shuts down. Specifically, "dc" means "distribute clothes".
I took this opportunity to upload a Tech and Troubleshooting manual for you. Here is the link for it. Read it carefully. You will be required to perform a "board output" test after placing the machine in "Service Mode".
I gotta tell ya, though. Based on my history with these, I highly suspect that the machine control board has failed. Let me know what you find, OK?
(And don't forget to rate this solution as "FixYA!", deal?
SG
Apr 11, 2009 | Maytag MAH2400A Front Load Washer
Stops in middle of wash cycle and F51 codes keeps flashing
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Good news for Oasis F-51 sufferers! Sears will replace the electronic control board (the F51 prob) for free, in warranty or not. Serial #s for the Bad Board are: CS48 - CS52 or CT01-CT49. Call Sears at 800-847-9083.
You hv to rate me ‘very helpful’, or the call won’t get thru!!
Mar 20, 2009 | Kenmore Elite 45986 Front Load Washer
Fisher&Paykel Intuitive eco IWL 16 Auto washer Fault code 51
Our washer did the same but it was after I took the excess drain hose and pushed it into the drain in the wall. I thought it looked "more tidy" In doing so I created a siphon effect. Once I pulled the excess hose back out it was fine.
Jan 23, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Washer stops and must be restarted flashes F51
there is a updated wiring harness and sensor on the the bottom of this tub on the motor. It needs replaced
Nov 13, 2008 | Kenmore 22422 Top Load Washer
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Kenmore Oasis HE 27082 Top Load Washer Logo
289 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
