Pinouts for Hirose 41 pin connector on panasonic LCD DL3DE0127BAA
  • 11 more comments
  • jccalhoun Nov 01, 2008
    Since the first reply was a question to restate the problem, I will be more specific. LCDs have a connector which brings the video signal, power and synch signals to the LCD. For the Panasonic LCD that I referenced the connector is a 41 pin Hirose connector. I am interested in obtaining the list of signals on a pin by pin basis for this connector on the Panasonic LCD I quoted.
    Close but no cigar. There is a VESA standard which I have. Unfortunately most manufacturers ignore this and choose a different pinout, so if I don't have anything which references the Panasonic model I have I do not trust what Sharp or any other manufacturer does since they do not follow the standard.
    This was not useful. These are websites where I can order the part. They have no information on the parts. They just sell them.
    Ok I got one more reference to the Wikipedia page on TFT panels which are not panasonic. This is not helpful. also a reference to the hirose catalog page. also not useful
    Please stop sending useless information. If you do not know the answer please do not post anything.
    What is the reference to your posting Fonehacker. I have several 41 pin mappings but how do I know that this is the right one. This looks suspiciously like the Wikipedia table for a different LCD.
    This is the same pinout as posted by Fonehacker above, but my question remains what is the reference for this? So far it is just another 41 pin pinout. Without a reference to the Panasonic LCD I have i have little confidence that this solution is any better than the 4 0r 5 other pinouts I have.
    Not sure what this posting says since the issue is not a repair issue.
    Not sure why the last posting was posted.
    You are absolutely right about this being the standard. However if you note the two postings by Fonehacker and ? they agree on a pinout but it is different than the pinout you sent. I already had this pinout directly from the VESA standard. The problem is that it is only a guideline, not a requirement.
    This post does nothing
    This post is for 31 pin not 41 pin and for Sharp not Panasonic
    I am officially calling off the request for information. I received no knowledge I did not already have and instead got a lot of useless posts.
    Master:
  • 505 Answers
I am attaching the image. This is standard 41 PIN Hirose connector for the LCD TV. It doesnt matter who is the manufacturer because all LCD TV has to abide with the Industry architecture. For more information click this link :
http://www.geocities.com/p9019/lcd/LCD_Panel_Pinout.html
Posted on Nov 01, 2008
  • Indrajit Roy
    Indrajit Roy Nov 01, 2008
    Hope this answer your query.
    Thanks
  • 89 Answers
Here are the pinouts for your lcd
    Genius:
  • 1,011 Answers
    Sergeant:
  • 213 Answers
Sharp - 31-pin Hirose DF9 version 2 Modules:
  • Sharp LQ10D131 (DF9L-31P-1V)
  • Sharp LQ9D03B (DF9B-31PA-1V)
  • Sharp LQ9D161 (DF9BA-31P-1V)
Pinout:
pin function remarks
1 R0 Red data signal (LSB)
2 GND
3 R1 Red data signal
4 Vsync Vertical sync signal
5 R2 Red data signal
6 Hsync Horizontal sync signal
7 R3 Red data signal (MSB)
8 GND
9 GND
10 CLK Clock signal for sampling each data signal
11 G0 Green data signal (LSB)
12 GND
13 G1 Green data signal
14 TEST - (do not connect)
15 GND
16 TEST - (do not connect)
17 G2 Green data signal
18 TEST/GND - (do not connect) (GND on LQ9D03B module)
19 G3 Green data signal (MSB)
20 GND
21 GND
22 Vcc +3,3V or +5V (see below)
23 B0 Blue data signal (LSB)
24 Vcc +3,3V or +5V (see below)
25 B1 Blue data signal
26 TEST - (do not connect)
27 GND
28 ENAB Data enable signal
29 B2 Blue data signal
30 GND
31 B3 Blue data signal (MSB)
http://events.pcm411.com/sid07/Data/EC/Event/Exhibitors/58/dfe0dbd9-d2d8-47ec-9dce-9e273f96c281.pdf
thanks golu_fixya
  • shivam raj
    shivam raj Nov 01, 2008
    2 GND
    8 GND
    9 GND
    12 GND
    15 GND
    20 GND
    21 GND
    27 GND
    30 GND
    Novelist:
  • 124 Answers
Wow i hope ac and ref never get this complicated looks like phone hacker is on traqck to me but wow this is outta my leaguegood luck
    Guru:
  • 558 Answers
You need to buy a new LCD now, as it could not be reparied..
  • 507 Answers
Try these to get that pinout parts
http://www.analogic.co.uk/LCD/AU_Optronics_B141EW01_V3_LCD.html
http://www.pinnaclemicro.com/computer/parts.php
http://www.laptoplcdweb.co.uk/p/panasonic_lcd_by_part_number.html
http://www.ezsystems.com/newcart/search.php?g=DL3DE0127BAA&SA10X
  • 19,396 Answers
    Genius:
  • 1,550 Answers
Can you restate your problem .
I cant clearly understand what is your problem .
  • SAM ANDERSON Nov 01, 2008
    Pin No. Signal Description Pin No. Signal Description
    1 GND Ground 22 GND Ground
    2 LCD_CLOCK Dot Clock 23 LCD_D9 LCD Data Bit 9
    3 GND Ground 24 LCD_D14 LCD Data Bit 14
    4 LCD_HS Horizontal Sync 25 LCD_D17 LCD Data Bit 17
    5 LCD_VS Vertical Sync 26 GND Ground
    6 GND Ground 27 GND Ground
    7 GND Ground 28 GND Ground
    8 GND Ground 29 LCD_D5 LCD Data Bit 5
    9 LCD_D3 LCD Data Bit 3 30 LCD_D4 LCD Data Bit 4
    10 LCD_D2 LCD Data Bit 2 31 LCD_D11 LCD Data Bit 11
    11 LCD_D1 LCD Data Bit 1 32 GND Ground
    12 GND Ground 33 LCD_D8 LCD Data Bit 8
    13 LCD_D10 LCD Data Bit 10 34 LCD_D13 LCD Data Bit 13
    14 LCD_D15 LCD Data Bit 15 35 LCD_D16 LCD Data Bit 16
    15 LCD_D12 LCD Data Bit 12 36 GND Ground
    16 GND Ground 37 LCD_BLNK LCD Blank/AC Timing
    17 GND Ground 38 DISPON DSTN Display On Control
    18 GND Ground 39 LCDVCC LCD +3.3V Power
    19 LCD_D0 LCD Data Bit 0 40 LCDVVC LCD +3.3V power
    20 LCD_D7 LCD Data Bit 7 41 (NC)
    21 LCD_D6 LCD Data Bit 6
SOURCE:
2 WIRES FOR 12V SUPPLY. PIN NOs 2 WIRES for Signal PIN Nos. ??
How PC Fans Work - PCB Heaven
pcbheaven.com/wikipages/How_PC_Fans_Work/
Mar 29, 2010 - The connector of a 2-wire fan has a red and a black cable. ... The firsttwo wires are the power supply of the fan. ... This fan is designed to be controlled with a PWM signal and .... I have a four-wire (red black yellow blue) 12v fan out of an old .... My case has a number of 2 pin outputs for multiple case fans, ...
Motherboard Power Connectors ' PC Repair and ... - InformIT
www.informit.com > Articles > Hardware
InformITFeb 28, 2003 - Table 3.3 ATX Main Power Supply Connector Pinout (Wire Side View) .... The auxiliary connector has no +12v leads at all, so that is no help. Pulling up to ...Pin. Signal. Color. Yellow. +12V. 3. 1. Gnd. Black. Yellow. +12V. 4. 2.
ATX 24 pin power supply connector pinout diagram ...
pinouts.ru/Power/atx_v2_pinout.shtml
Rating: 52/60 - ‎60 votes
Jan 28, 2014 - Pinout of ATX (ATX12V) 24 pin power supply connector and layout of ... and later (ATX12V 2) is common ATX standard, 24 pin connector. ... Power Ok is a status signal generated by the power supply to notify ... 10, 12V, Yellow, +12 VDC ... 18 AWG is recommended for all wires except pin 11, which should ...
ATX power supply connector pinout diagram @ pino
Dec 16, 2015 | Cars & Trucks
Want to connect 40 pin LCD ribbon cable to the 15 pin D type VGA
VGA pinout?
Not a prob,
http://pinouts.ru/Video/VGA15_pinout.shtml
Pinout of that 40 wire LCD ribbon cable in your hand?
Dunno
Each manufacturer is different.
IF, you find the pinout of JUST THAT LCD cable you have, LET ME KNOW.
Post back in a Comment, or click on Reply at the end of this solution.
Regards,
joecoolvette
May 12, 2013 | Computers & Internet
The 8 pin connector to the cluster got accidentally dismantled and all the 7 wires in the sockets popped out. I do not how to put them back as the wires do not have numbers corresponding to the plug.
Hi.
The pinout depends on year and model of the Mercedes. Models between 1988-1993 used the following 8-pin diagnostic.
8 pins diagnostic.
There are also several 8 pin connectors used in Mercedes radio and CD. Here the pinouts.
Regarding the connector at the back of the dash, to find pinout I will need year and model of the car.
Jun 08, 2011 | Mercedes-Benz 560-Series Cars & Trucks
What is the pin layout for the rs232 connector on the F5U409v1 adapter from belkin.
The pinouts are in numerical order
1 2 3 4 5
6 7 8 9
Pin signals:
1.Data Carrier detect
2.Rx
3.Tx
4.Data Terminal Ready
5.Signal Ground
6.Data Set Ready
7.Request to Send
8.Clear to Send
9.Ring Indicator
Dec 20, 2010 | Computers & Internet
VGA connector on a Dell e770s 17 inch monitor has been cut. Need to know where the wires go on a 15 pin db connector?? Can anyone help...Thanks gvp
Found out the information thru this page. Its a diagram of the 15 pin VGA Pinout and where the pins are supposed to go and what there fuctions are, hope this helps. Page is courtesy of pinouts.ru
Aug 29, 2009 | Computers & Internet
Need wiring diagram or pinout
try tracing the user manual on the web punch in the model no ect .this should give you the answers.good luck farr64
May 08, 2009 | Televison & Video
Cable end chopped off need to know pinout mapping to reattach a new cable end to attach to computer.
All VGA connectors use the same pinout. Here's a link that shows you the VGA Pinout,
http://www.interfacebus.com/Design_VGA_PinOuts.html
More monitor pinouts,
http://www.montest.com/technote.html
Apr 21, 2009 | KDS K717s 17" LCD Monitor
Need pinouts
I have an old pc chips M575 motherboard that also uses the J3 ATX Form card. I can only assume the pinouts are the same so here they are from the manual.
Pins 1-4 and 10- 13 are USB connectors
USB USB
Pin Description Pin Description
1 +5v 10 +5v
2 data- 11 data-
3 data+ 12 data+
4 ground 13 ground
Pins 5-6 and 15-16 are PS/2 Mouse Connector
Pin description
5 +5v
6 Mouse CLK
15 Mouse Data
16 ground
Pins 7-9 and 17-18 are Infrared connector
Pin description
7 Ground
8 Reserved
9 +5v
17 IR in
18 IR out
hope that helps
Nov 18, 2008 | Pc Ware M748LMRT Motherboard
Power connection pinout
Here is a pin connection specification for the ac power supply (dual voltage adaptor)
>socket/plug for a Compaq TFT450 LCD Monitor that she
>supplied (edited for further clarity).
>The pins of the male connector (a PS2 mouse type connector) should be connected like this:
> 1 2
> 3 I 4
> 5 ^ 6
> GND GND
> 5V I 12V
> 5V ^ 12V
>For clarification - the male will be the end of your cable, and not the socket on the monitor.
>The I is the central polarising bar of the connector, and the ^ is the notch.
Jun 16, 2008 | Compaq TFT450 14" LCD Monitor
Computers & Internet Logo
2,637 people viewed this question
Alun Cox
