Car turns off at idle or when accelerating from a stop as if the key had been turned off. Starts again in neutral and will do it 2 or 3 times in a row then runs fine. Will run fine for a few days then do it again.
SOURCE: changing fuel filter on 2004 chrysler town and country
SOURCE: low speed fan relay for the 2005 chrysler town and country
If you are talking about the cooling fan relay for the radiator there is no low speed and high speed relay. There is only one relay and it is behind the grill revitted to the bumper rail. It is doesnt look like you typical relay.
SOURCE: radiator fan relay,2001 chrysler town country
the relay is located in the power distribution box under the hood the relay will be a square black or gray cube just pull out and make sure you rerplace it with the same type relay. refer to your owners manual for any questions regarding the fuses and relays
SOURCE: Chrysler trouble code U110C on 2005 chrysler town
encrypted software ,dealer only----yes i know you are showing a reading but it doesnt mean anything or if it does it shows a different code .so your snap on or mac tools scanner is a waste of time and money.Nearly all new motors from 2005 are using encrypted software to stop general mechanics like me from working
SOURCE: 2001 Chrysler town and Country tire size
the sticker on the drivers door or door jamb will have that info. plus it is on the side of the tire, starting with P___-__-__
