Question about Samsung PCJ534RF 53" Rear Projection Television
Colors bright pink and green triple halos around all objects on screen
  • walkthebridg Jan 11, 2009
    GREEN HALO'S ON ALL OBJECTS,BLURRY PICTURE,GREEN BLURR LINES 2 ABOUT 4 INCES THICK DOWN CENTRE OF SCREEN,AND GREEN SPOTS IN UPPER LEFT OF SCREEN
    Genius:
  • 1,139 Answers
Hello giveitup,
This sounds like a convergence problem which means that your convergence amps have malfunctioned. You can change these out yourself, however you will also have to change out all of the biasing resistors connected to the amplifiers. To do this:
1) Unplug the TV and then get a schematic of the TV I use http://www.servicemanuals.net or http://www.manualsparadise.com
2) On the schematic locate the STK329-xxx series IC packs (usually attached to a large heat sink)
3) determine if the STK329s are 110, 120 or 150.
4) if the STK329-xxx's are 110s replace with 110s (forget that upgrade stuff it is a hit or miss game that I don't believe you want to get into), if they are 120s replace with 120s and so on.
5) Now to replace the STKs: remove the module from the TV and unsolder the old STKs along with the bias resistors, and replace them with the new ones (be sure to apply heat sink paste to the STKs when attaching them to the heatsink)
6) make sure there are no short circuits form your soldering job.
7) Reinstall the module and then turn on the TV.
8) do an auto-convergence test and then things should be back to normal.
Now if you think you can do this have at it, if not I would suggest that you have it done by a qualified TV technician.
Thank you,
I hope this helps,
Shuttle83
Posted on Nov 01, 2008
Double images and bright pink and green colors
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded over.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Dec 21, 2010 | Hitachi 43F300 43" Rear Projection...
My tv looks like 3D and has blue ang green colors how can i fix my tv
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 12, 2010 | Philips 46PP9302 46" Rear Projection...
GREEN AND PINK COLORS ARE SEPERATED PICTURE IS ARCHED TOP AND BOTTOM. HOW DO I REPAIR THIS??
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Red/Orange looking video
You can see some examples and find a fix here...
Dec 09, 2009 | Sony KP-57WS510 57" Rear Projection HDTV
The red and green convergence are not in sync
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
Example Photo:
Symptoms
Example Photo:
Nov 26, 2009 | Hitachi 43FDX01B TV
The tv picture looks like should be wachting it whith 3d glasse
This is a very common failure on Projection TV sets. Its called a convergence failure. Here are some common symptoms.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
The other common problem is cloudy lens fluid. After many years the coolant in the blue and green lens will become cloudy and cause the screen to look dull, red/orange, bright white, etc. You may even see halos around objects on the screen.
You can see some example photos and find a solution here on Fixya.
Nov 15, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Green wavy images on the screen? Convergence is fine but there is a warped green image of everything on the screen.
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
Example Photo:
Symptoms
Example Photo:
Sep 27, 2009 | Toshiba 65H82 65" Rear Projection...
My TV looks like if i was watghing a 3D Movie.
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
Example Photo:
Symptoms
Example Photo:
Jan 26, 2009 | Philips 55PP9401 55" Rear Projection...
My Philips 51PW9363 has pink and green colors only!!!!
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
Jan 05, 2009 | Philips 51PP9200D Television
Convergence toshiba 50a62
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
Example Photo:
Symptoms
Example Photo:
Nov 20, 2008 | Apex Digital GB5108 51" Rear Projection...
Arched pink lines across screen. Now green and pink double stacked wording.
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 25, 2008 | Sony KP-57WS500 57" Rear Projection...
Samsung PCJ534RF 53" Rear Projection Television Logo
80 people viewed this question
Henry  Thomas
Henry Thomas
