Question about Logitech 967437-0403 Keyboard
LOGITECH KEYBOARD DOES NOT WORK
Hello! I havbe an 'old model ' of wireless keyboard and mouse and I want to transfer them to my new computer. The mouse works but the keyboard doesn;t when I move them both over to the new computer.
Thank you so much for any help that you can provide.
Cheers, and greetings from Canada!
/Murray
kevin000
  • 1847 Answers
SOURCE: Mouse does connect but keyboard does not, vice versa
reinstall the logitech cd which came with keyboard and mouse, with the mouse pluged in. once reinstalled restart and while restart plug the keyboard in..... this should resolve the issue.
Posted on May 29, 2008
yooperbud
  • 8637 Answers
SOURCE: Logitech wireless mouse and keyboard
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
If the MOUSE isn’t working, push the small RESET/CONNECT button on the back of the mouse to connect to the receiver. Then they should work okay.
Hope this helps. Bud
Posted on Jan 19, 2009
cpenzes
  • 1102 Answers
SOURCE: Logitech Wireless CE 0682 Keyboard won't work but mouse does
did this come with software
and you might need to do a uninstall reinstall
if it worked on same pc before it should work now.
if you have a reset button on transmitter try resetting it.
Posted on Jan 20, 2009
SOURCE: Logitech MX3200 Wireless keyboard works but mouse does not
i have the same wireless keyboard. i suggest that u redothe setup process and setup the mouse first. if the problem persist then move the wireless scanner.
Posted on Apr 10, 2009
  • 2678 Answers
SOURCE: M305 Logitech Wireless mouse with nano stopped working on Laptop
This is a difficult one to answer so lets go through it.
You have a M305 thatrefuses to work and your OS says is returning an error.
You've quite rightly checked the Logitech site and found out that it appears to be a common fault as many people are reporting the same issue.
Logitech have not resolved the issue.
All the above are valid reason for retun to the vendor for replacement/refund.
However you WANT to replace a M305 (a model with know issues) with ANOTHER M305 which will have the same issues as Logitech have not resolved the problem.
I will have to think long and hard before giving a definative reply.
Posted on Dec 29, 2009
Why does my brand new, just unpacked wireless Logitech wireless keyboard and mouse (unit mk550) doesn't work? When I received the unit, both off/on switches were on. The keyboard was 'dead' nothing
You can change the batteries, then push the connection button on the back of the keyboard, also, download the logitech software to help get it set up.
Jul 03, 2014 | Logitech Computers & Internet
Will a Logitech Wireless Keyboard/Mouse (Y-RQ57) work with a USB-to-Keyboard/Mouse bus adaptor?
Hello Marecha--it can be a bit of a needle in a haystack situation when trying to use adapters to make older hardware work with the newer and faster things available these days. I've tried similar scenarios and with some I"ve had success and with others not so much. If at all possible I would recommend obtaining the adapter from Logitech themselves as many of the cheaper, generic imports are only manufactured to mimic a certain prototype and many aren't even tested. At the very least, just be sure that wherever you purchase the adapter is willing to exchange or refund for an incompatibility issue. Trying one (or several) won't hurt the hardware in any way. Good luck!
Apr 28, 2014 | Logitech Y-RQ53 Cordless Keyboard Wireless...
If I have an existing logitech cordless mouse with keyboard but need to change to a new mouse because it doesn't work any more can I just change the mouse or do I need to change both mouse and keyboard?
you have to buy a new wireless kit. Your little usb receiver for wireless signal will only work with the keyboard and mouse included in the package.
Hope this helps!
Feb 19, 2011 | Logitech Cordless Mouse
The wireless keyboard and mouse are not working.
  • Check to ensure that the wireless receiver is plugged into your computer. Press the "Connect" button on the bottom of the receiver to attempt reconnecting your mouse and keyboard to the computer. If your mouse and keyboard use Bluetooth, ensure that your computer's Bluetooth is active and detects the mouse and keyboard.
  • Check to see if the keyboard and mouse are turned on. If the power indicator lights on the keyboard and mouse are not green, press the "Power" button to turn the keyboard and mouse on.
  • Check the batteries of the mouse and keyboard. If the batteries are dead, replace them with fresh batteries and reconnect the mouse and keyboard to the computer by pressing the "Connect" button on the bottom of the wireless receiver attached to the computer. If your mouse and keyboard use rechargeable batteries, let the batteries recharge before using the device again.
  • Uninstall and reinstall your wireless keyboard and mouse drivers. Sometimes, the Logitech drivers are at fault for a bad connection. Use the Control Panel to uninstall the old drivers, then visit the Logitech website and install the latest drivers for your keyboard and mouse.
  • Search the Logitech Support Database. If your keyboard and mouse are still failing to function properly, visit the Logitech Support website and browse the support page for your product for specific solutions.
Feb 04, 2011 | Logitech Computers & Internet
Wireless mouse does not work after changing batteries.it always has in the past The Dell computer and mouse is probably 8 years old but has always worked.
Try moving the mouse receivers usb plug in to another port. Unplug any new devices and restart computer. Then replug in any new usb devices.
If still not working.......
Look at Office Depot and other office stores for a replacement wireless mouse. I have seen them as low a $9.99 on up. You might even want to upgrade and get a wireless mouse and keyboard set.
Mar 08, 2010 | Logitech WIRELESS OPTICAL CORDLESS MOUSE...
Logitech MX 5000 Wireless Laser Keyboard & Mouse Combo
HELLO, ALL YOU HAVE TO DO IS TO DOWN LOAD THE SOFT WARE THEN PLUG IN THE USB AND AFTER THAT ON YOUR RECIEVER CLICK THE CONNECT BUTTON ON THE RECIEVER TILL IT RECONIZES BOTH KEY BOARD AND MOUSE I HAVE THE LOGITECH WIRELESS SYSTEM AND I LOVE IT TILL THE BATTERIES GO OUT ON THE MOUSE OR KEY BOARD LOL THEN RESTART YOUR COMPUTER.
Apr 05, 2009 | Logitech Cordless Mouse
Keyboard error
I am assuming that the logitech is a usb keyboard and your old keyboard is PS/2 (round connector) if so you can get a usb to ps/2 adapter and that should solve your problem. If your computer is newer in your bios there should be an option to enable legacy usb keyboard and mouse support. Make sure thats on or enabled.
Apr 04, 2009 | Logitech diNovo Edge 9676850403 Keyboard
Logitech Wireless Keyboard/Mouse & Windows Vista
hello kgrifffin
you might want to look here for the answers from logitec number 6 might give you some guide .
Logitech > Support > Find Answers
riz.
Mar 30, 2008 | Logitech Cordless Desktop MX 5000 Laser
Logitech 967437-0403 Keyboard Logo
48 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
