Question about Sony VPL-VW100 (Ruby) Multimedia Projector
SONY Projector Unplugged it and plugged it back in: two clicks When I do press the on button: 10 green standby lights on orange lampcover light. Then, every 30 seconds or so, it will click 4 to 5 times, apparently trying to come on. When it does come on, it just did again after trying all day long, then it does make a metallic click like some relay just did what its been trying all day. As soon as the metallic click is heard the light comes on. I appreciate your feedback Thanks Hubert
  • racer60 Nov 01, 2008
    The lamp is 1800 hours the unit is 2 1/2 years old with moderate use.
  • Anonymous Jan 12, 2009
    This sounds very much the same as my problem. My lamp/cover light came on and I had a very dark picture if any on the screen. The lamp had between 1700 & 1800 hrs. I didn't notice any of the other warnings about lamp life but I changed the bulb anyway without further investigation to see if it actually was a bulb problem. There was still a bright light shining inside but the lamp light was on. After replacing th bulb, all I would get was a blue screen and only the menus would come up and these were still very dark and dim. The lamp/cover light was no longer on. I couldn't get a picture from any of my connections (S-cable, video, component or hdmi. The picture menu also would not activate and there were no Vhz or Hhz numbers displayed. When I plugged the component cables in it displayed an "out of frequency" message. No such message with my video cable connection. (sorry, I'm trying to go by memory because my projector is at the repair shop) I just received a call from the Sony repair shop and they said it needed a new Q board. The board would cost me C$2500 at this shop plus labour. I'm not sure if I should get it fixed or buy a good big screen TV for that price. I love the projector and I just got a HD receiver to use it with a week before it went down.
  • 320 Answers
Two clicks is good, it means both parts of the supply are initializing, so they are PROBABLY OK. The lamp cover LED flashing could be a simple fix. Be sure the lamp cover and filter cover are securely seated. If necessary, take them off and reseat and latch them again. There is also a sensing switch on the cabinet that will cause this if the main cabinet cover is not seated properly. Be sure all cabinet screws are securely tightened. Beyond that, Sony says there is an outside chance it is the Q board, which is the main microprocessor board, but I've never seen one fail. It's more likely to have an intermittent switch on the lamp cover, the filter cover or the cabinet (the all have little microswitches that sense when the are closed) OR a bad or intermittent connection to one of the microswitch boards (all of the sensing switches are mounted on little circuit boards and that is the way Sony supplies them as a part) OR a connection problem to the Q board where the switch lines go into the microprocessor. If I had to make a guess at this point, the covers first (make sure they are closed and not warped in any way) the switches and then the wiring and connectors. Hope this helps. I would like to hear back from you to see how it goes.
Posted on Nov 01, 2008
  • 1 more comment
  • Any Guy
    Any Guy Nov 01, 2008
    Just for argument's sake, how old is the lamp in the set?
  • Any Guy
    You should get somewhere between 4000-8000 hours from a lamp. There are 3 factors that affect lamp life. They are (in order of importance)
    1) Number of lamp cycles. How many times the lamp is turned on greatlt effects lamp life. Every time the lamp is fired, some life is lost. My general rule of thumb is: if you are going to be back to the TV within 30 minutes (give or take) LEAVE IT ON.
    2) Ventilation. Proper ventilation is esssential for longer lamp life.
    3) Power consistency. If power is interrupted while the projector is on, you don't get a proper cool down cycle, which can shorten lamp life. If you experience frequent power outages, buy a UPS so that the cool down cycle can be completed.
    I don't think it's a lamp issue, but I have seen lamps fail earlier and look perfectly good. Stick with an original Sony lamp, as the aftermarkets are known trouble makers. The only after market lamp maker I would trust is OSRAM, as they have years of experience in lighting.
  • Any Guy
    if you have any further questions, feel free to contact me and I will get back to you at my earliest convenience.
NEC lt240 lamp light stays off and power light is orange, no Image
COULD HAVE HOUR COUNT LAMP LOCKUP YOU WILL NEED TO RESET HOUR COUNTER BY USING BUTTON CONFIG AND MAINS.
john
www.jvsvisual.com
Apr 15, 2013 | NEC LT 240 Multimedia Projector
Vizio vw37l hdtv20a standby light on but wont turn on
you either have a faulty power supply or faulty main board. Vizio power supplies on the older sets are pretty decent. It's usually the main boards that go. These older main boards tend to be pricey so it may be better to buy a new set.
Mar 27, 2013 | Vizio VW37L 37 in. LCD HDTV
I have a nec vt560 and the power light stays orange and the status light is off until buttons are pressed. bottom line is...i cant get the projector to come on...the power light never turns green.
The projector is in standby mode, which is a good sign.
When you press the ON button for "at least 2 seconds or more", what happens.
Do any lights come on at all?
Mar 20, 2011 | NEC VT560 Multimedia Projector
I my projector is new one used for 4 hrs, when i try to turn it on it just has a blinking green light. Please help Solve It! .
The blinking green light means the unit is either Powering On (Warming Up) or Powering Off (Cooling Down).
Powering On the Projector
1. Remove the lens cap.
2. Securely connect the power cord and signal cable. When connected, the ON/STANDBY LED will turn Amber.
3. Turn on the lamp by pressing " " button either on the top of the projector or on the remote. The ON/STANDBY LED will now turn Green. The startup screen will display in approximately 10 seconds. The first time you use the projector, you can select your preferred language from quick menu after the startup screen displays.
4. Turn on and connect the source that you want to display on the screen (computer, notebook, video player, etc). The projector will detect the source automatically. If not, push menu button and go to "SETUP". Make sure that the "Source Lock" has been set to "Off". If you connect multiple sources at the same time, press the "SOURCE" button on the control panel or direct source keys on the remote control to switch between inputs.
If you are still unable to get the unit to turn on, try unplugging it for 10 minutes and plugging it back in. If it still ceases to work, contact Optoma here: http://www.optomausa.com/rma_policy.asp
Their Technical Support line is 1-888-887-5001
Feb 25, 2011 | Optoma HD20 DLP Projector
What does it mean when that blinking green light turns to orange one in lp 350?
Hi
This would be "Standby"
When you press standby, the display and audio turn off and a blank screen is displayed for 15 minutes.
You can change the amount of time the projector stays in standby mode; see “Standby Time” on page 27 for details.
The LED lights orange while the projector is in standby.
• If you press standby again within 15 minutes, the projector returns to normal operations immediately. The LED changes from orange to green.
• If you press standby again after 15 minutes, there is about a 60 second delay before the lamp turns back on. The LED flashes green while the lamp is re-lighting.
• If you don’t press standby again, the lamp turns off after 15 minutes. The LED lights orange while the projector is in standby.
The full manual can be found here:
Infocus customer support
Infocus LP350 Manual
I hope these help
Mike
Sep 18, 2009 | InFocus LP350 Multimedia Projector
Lamp will not come on
try pressing and holding the enter button on the projector for about 30 seconds - this resets it. It worked for me!!
Feb 10, 2008 | NEC VT460 Multimedia Projector
Orange light on lamp icon on Optoma EP732H Projector
This same thing happened to me, I removed the bulb and put it back in, it reset something and I was able to use the projector again.
Nov 12, 2007 | Optoma EP732H EZPRO DIGITAL PROJECTOR...
Sony VPL-VW100 (Ruby) Multimedia Projector Logo
260 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
