Question about Nikon Cameras
I am confused with the picture control on a d90 slr .how do i set it like for example ,the sharpening?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
Create a new picture control by copying one that's close to what you want. Then go and change the various parameters.
Posted on Dec 30, 2009
What is the relation of lense maximum apertures and camera settings?
You have not stated which model camera body you have so I can only give you general Nikon information. There is a range over which the automatic settings will work for each camera. In addition, Nikon bodies have multiple sensitivity ranges. On the D90 for example, go into the "Shooting Menu" and open the "ISO sensitivity settings." You will see "maximum sensitivity" and "minimum shutter speed" menus along with the "ISO sensitivity auto control" options. Turn off the auto control option and manually set the maximum (ISO) sensitivity and minimum shutter speed. Also, the Shooting Menu also has "High ISO NR" settings that can be used to accommodate most lighting situations. You need to look in your camera's manual for all the details. The Nikon website has manuals available for all the Nikon products.
Sep 19, 2012 | Nikon D3, D40, D40X, D50, D60, D70, D80,...
Can you use a velbon videomate 500 tripod with a Nikon D90 SLR camera?
yes you can use a velbon videomate 500 tripod with a Nikon D90 SLR camera good luck!! :)
Apr 02, 2010 | Velbon VIDEOMATE 507 Tripod
I got and fEE... and figuered out it means error!!
This might be a long shot, but on the lens section of the guide shown below, it notes ,,,,
Non-G lenses will have an aperture ring on the base of the lens where it's attached to the camera. Set this this ring to the smallest aperture (largest number), usually in orange and 16, 22 or 32. There usually is a lock to keep this ring set there, since if it comes off that setting you'll get an error message (fEE) from most cameras.
Full guide is here:
http://www.kenrockwell.com/nikon/d90/users-guide/index.htm
Hope this helps
Mar 06, 2010 | Nikon N60 35mm SLR Camera
WHICH LENS WILL GIVE THE SAME RESULT OF 50 MM LENS IN FILM MODEL
To figure the equivalent coverage comparable to a film camera, multiply the number of mm by 1.5. Example: a 50mm lens will be like a 75mm lens on a digital camera.
Sep 08, 2009 | Nikon DSLR D90 Digital Camera
Why is there a delay?? Nikon D90
Sounds like you turned on Exposure delay mode (menu d10). This is similar to the "locking up the mirror" (or somethign) feature on canons.
YOu only need it when you doing a tripod shot with long exposure and you want to minimise absolutly all possibility of shake from the camera its self. Lifting the SLR mirror will cause small shake. Generally you can turn this off (i've felt it ona few times my accident and been confused for a second)
Aug 19, 2009 | Nikon D90 Digital Camera with 18-105mm...
Pictures taken are not sharp
If you are upgrading from a previous "point and shoot" digital camera, the pictures from your digital SLR may seem "soft" by comparison. This is simply a difference in the built-in processing performed by the camera. Most DSLRs output images with less sharpening applied. I believe the philosophy is that the sharpening algorithm causes data loss, so less of it is used on the high-end cameras with the assumption that you can apply more later on your PC.
You can try shooting a picture using the RAW capture mode, then editing it using a program on your PC. By applying sharpening to the RAW image, you will most likely be able to produce a very sharp image.
You can also take a JPEG image with the camera and apply additional sharpening on the PC, but this process is more lossy with regards to the original data.
May 20, 2009 | Canon EOS 40D Digital SLR Camera Digital...
I'm planning to buy a DSLR but confused what to buy
You have named several excellent digital SLR cameras aimed at the top end of the amateur/semi professional market.
I have the Nikon D200 and have been very pleased with it.
As stated by JCDill, you must really decide what you want and can afford. The camera body you choose will commit you down one path or another. For example, if you choose Canon, only Canon or OEM (Other Equipment Manufacturers) such as Sigma lenses will fit your camera body. Canon have a good reputation for their auto-focus, while Nikon make lenses that are the envy of others.
If this is your first digital SLR then you might be best buying an entry level body with a multi-purpose zoom lens such as the Nikon D40. There is a lot to learn.
If you are converting from film SLR and already have a set of lenses, then the cameras you mentioned will probably be able to use your existing lenses (but this is less so with Canon than Nikon). I was ecstatic to disover that my old Nikon 500mm mirror lens works in manual mode (with metering displayed) on my Nikon D200 but would not work properly on my Nikon D70.
I hope this helps.
Jan 01, 2009 | Nikon D200 Digital Camera with 18-200mm...
Lense will not work with SLR Nikon D90
This lens is too old for the D90, it has not got the electronics for metering and autofocus.
You can use it manually in M mode but you will have to set the aperture and shutter yourself.
The D90 manual has a section on compatible lenses, page 228 in my version.
This recommends CPU lenses for the D90, type G and D.
Dec 25, 2008 | Nikon Zoom 80-200mm f/4.0 AIS Lens
Cameras Logo
35 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
