Question about Homelite Consumer Products Backpack Blower/Vac, Carb
Blower runs fine for 30 or 45 mins, then will not come up to speed.
Homelite backpack blower 26 mm
  • sarudajr Nov 01, 2008
    rum fine for 10 to 15 minutes the starts to surge, then will somooth out for a short while then surges again
  • blowernot Nov 24, 2008
    Starts and runs when cold, but bogs down and stops after 20 - 30 minutes. Then on restart will only run for a couple minutes before dying.
  • 4 Answers
There is a fuel filter in the fuel tank that some times gets cloged try that and fresh gas -oil mix
Posted on Feb 05, 2009
I have the homelite mighty lite backpack blower. i don't have a problem starting it. The problem is when i turn the choke to 1/2 and then full running position, i strap it on my back and then this is where...
you have a dirty or blocked carb jets strip down the carb and clean out the running jet
dont poke wire into any of the jets to clean them this will distroy them!!! use car cleaner and cmprest air if you can,,good luck mike
Nov 04, 2010 | Homelite Consumer Products Backpack...
I have a Homelite BackPacker leaf blower. It runs fine until the gas tank is about half empty. Then it sputters. While it's running, I can remove gas cap and replace and it runs fine again for a little...
Great job with the description of the symptoms. What you are describing is a classic case of vapor-lock. In other words, a vacuum is forming in the fuel tank and not allowing the fuel to flow to the carburetor.
Look at the cap, it probably has a small vent built into it. With a little compressed air, blowing from the outside in, try to clear the obstruction. This may not work, but don't worry. Just replace the fuel cap. Your local lawnmower repair shop can probably get a new cap for you. Otherwise, go to www.homelite.com click on the parts tab, enter your model number (starts with a "UT") and order a new one.
Oct 29, 2010 | Homelite Consumer Products Backpack...
Bogs down at full thouldel tryed to adjust carberator
Hi
This is either a clogged muffler or carb. Take the off and see if it will rev. If not you need to clean carb and install a carb repair kit. Do not run long with muffler off.
Sam
Jan 06, 2010 | Homelite Consumer Products Backpack...
I have a Homelite UT08580 26cc MightyLite Backpack Blower. Since new it has run poorly if at all when the choke is in the run position. Normally I have to use it when in the 1/2 choke position. It has caps...
If you have'nt yet you should put a kit in the carborater,if that does'nt fix it{should} then you may have a plugged muffler,.if you can't get rid of exhaust you can't be reved up.
Dec 09, 2009 | Homelite Consumer Products Backpack...
Homelite back pack leaf blower
Close both the high and low speed air screws (clockwise). Reopen each 1 1/2 turns
Mar 20, 2009 | Homelite 'Yard Broom' Leaf Blower
Homelite 26bp backpack won't run up to full throttle
I have let my leaf blower run and warm up before throttling up and still it bogs down and shuts down. There is no air cleaner to clean should I just blow out the carb. and fuel lines?
It runs and idles just no high speed to blow.
Nov 16, 2008 | Homelite Consumer Products Backpack...
Homelite Consumer Products Backpack Blower/Vac, Carb Logo
668 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
