Question about Technics SL-1210 Turntable
I have got 2 technic 1210 mk2 decks and was wondering how much it would cost to get them serviced.
  • 515 Answers
This is a VERY GENERAL Question. It's like asking, how much to service my car? Not an easy answer.
There are many factors to consider. First.. what is wrong with them? What do you mean by service?
To give you an idea, our company, based in NYC, will charge $40 for a basic cleaning, lubrication, and calibration of your Technics 1200s back to original factory specs. However, if you need the tonearm replaced, the price jumps up to $130 for parts, labor, and the tune up. So as you can see, prices do range.
If you could be more specific, it would help greatly.
Also, it all depends on where your located. If your near a major metro area, prices will be cheaper, and you'll find more service centers familiar with the unit. In rural areas, you run the chance of the technician not having any sort of experience with the 1200s, and thus, possibly damaging your unit, or not doing much to them.
Hope this helps some.
- OPTiC.
Digital Analog Therapy
www.djprolab.com
www.1200s.com
Posted on Nov 04, 2008
Pitch wobble 1210
i had my decks fixed by these guys they are in london.
thier websites is www.technics1210repair.co.uk
they do technics turntable servicing
check them out.
im only spreading the word due it i had my decks fixed their and i am so pleased im telling everyone so they can get the same service i did, rather than paying over the odds at some **** toster repair shop.
alan
Apr 23, 2010 | Technics SL-1210 Turntable
Technics 1210 MK2 - unstable/uneven speed problem
Since this is a direct-drive turntable, it isn't a slipping or stretched belt. You will need a technician with a couple pieces of equipment and some experience/training to find the source of the problem. I suspect the part(s) will be the minor cost of the repair.
Sep 07, 2009 | Technics SL-1210 Turntable
1210 mk2 speeds up on its own
hi ,,,the pitch control is good dont chance it ..you have a problem on the main board ...of your turntable...check the cold solder of your main board of your deck....maybe some of them are loose that why you got a wiggle platter.. u...then fidbk me wat happend? u
Jun 18, 2009 | Technics SL-1210 Turntable
Help for technics 1200 MK2 and 1210 Speed is too fast
On the 1200MK2 the pitch control slider is for just that purpose. Disregard the 0 setting and use the illuminated strobe marks on the platter to adjust to nominal speed. When they appear to be motionless you are there. The control on the 1210 may be a knob but the same principles apply.
http://en.wikipedia.org/wiki/Technics_SL-1200
Apr 04, 2009 | Technics SL-1210 Turntable
No sound out of deck
If you've already replaced the RCA /Phono cables, then the only other item that would cause this kind of problem is your tonearm, and it will need to be replaced.
- OPTiC
DJ Turntable Repair Expert
A DJ Pro Audio Co.
Dec 05, 2008 | Technics SL-1200 Turntable
1210 mk5g pitch adjustor
switch off for a will and see.
if still bad. check the circuit board under.
with old electronic devices, capacitors are commly the ones that may go wrong/dry. which would cause oscillatory circuit to generate wrong signals or strobe or feebacks. if you know how to take out the circuit board, check it starting from capacitors.
Jan 22, 2008 | Technics SL-1210M5G Turntable
Pitch problem
check it.
http://www.repairnyc.com/
These guys are authorized technics service.
Jan 05, 2008 | Technics SL-1210 Turntable
Technics 1210 mk2 problem with pitch and lights
Check that your voltage settings are set correctly. This is located underneath your turntable platter. If you remove the slipmat, you will see 2 holes on the metal platter. Rotate the platter till you see the voltage switch, located @ the 9'o'clock position. Make sure it's set to your correct settings (N.America = 115V / Euro = 220V). If not, you will need a flat head screw driver to switch it. Before you switch it, make sure your unit is off and unplugged. After you swich it, it should be ok.
If your still having issues with the speed and the pop-up light, then there is something seriously wrong, and will need to be checked by a technician. Sometimes a resistor or IC will go bad, causing the speed issue, but for the pop-up light - that's usually faulty wiring generally caused by an incorrect replacement.
Did you buy this new or used? Have you had this serviced recently?
- TWEAK AV LAB
The ORIGINAL TURNTABLE Technicians
Nov 30, 2007 | Technics SL-1210 Turntable
Technics SL-1210 Turntable Logo
146 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
