Question about Dell Inspiron 5100 Notebook
Inspiron 5100 bios a32, keyboard
Some keys on my dell inspiron 5100 don't want to work. the delete and left and right arrow are not working at all
  • Anonymous Dec 06, 2008
    I have the same problem with my 5100 keyboard.. I bought a brand new keyboard online and replace the old one, but the problem remained. If you press the defective keys very hard, they sometimes work.
    This appears to be a problem with some other hardware component in the laptop (motherboard?). I just use an external keyboard now.
  • Anonymous Mar 27, 2009
    I also have this problem with my "I" key, I must hit it fairy hard to use it. Tried dusting out underneath and all that, however, it seems the only solution is an external keyboard.
  • Dell Master
  • 998 Answers
You can try reseating the keyboard connector. If that doesn’t work, the keyboard needs to be replaced. To reseat the keyboard connector, follow this link: http://support.dell.com/support/edocs/systems/ins5100/en/sm/keyboard.htm#1084976
Be sure to remove AC power and the Battery.
Posted on Nov 01, 2008
Remove hdd password
You can change it but not 'remove' it. Simplest is to use '00000' as the default password.
Instructions
1 Shut down your computer.
2 Press the power button on your computer. While it is booting, press F2 repeatedly (do not just hold it down) until you arrive at a system screen showing a series of
options. This screen is called the BIOS Setup.
How to change the password on a Dell computer hard drive
Password Vault
Secure, centralized password vault for enterprises. Try now. manageengine.com/PasswordManagerPro
3 Use the down arrow key on your keyboard to scroll down to "Security" in the left-hand column.
4 Arrow right to display a sub-menu under Security in the left-hand column.
5 Arrow down to "Internal HD PW" in the left-hand column. (That stands for Internal Hard Drive Password.)
6 Delete the old password (if any) and, in the same box, enter a new password of at least four characters in length in the main screen at right.
7 Write the password down and keep it in a safe place.
8 Hit Enter.
9 Hit the Escape button on your keyboard to exit the Internal HD PW menu, then hit Escape again to proceed to the Exit screen of the BIOS Setup.
10 Arrow right to save the changes you made to the password, then hit Enter on your keyboard to exit the BIOS Setup.
11 Restart your computer and use the password you created in the BIOS Setup to gain access to your hard drive.
Apr 17, 2014 | Dell Dimension Computers & Internet
Won't read keyboard
usb or ps2 keyboard ? might need to be enabled in BIOS
If you want to use a USB keyboard to access Windows command prompt options, make changes in the BIOS (Basic Input/Output System), or to operate legacy operating systems, you must enable support for the device inside the BIOS.
Shut down the computer and disconnect the USB keyboard. Connect a PS/2 keyboard to the PS/2 connector port on the rear of the computer. Turn on the computer and press the "Delete" key several times as soon as you see the initial boot or company logo screen. Wait for the main BIOS setup screen to appear. Press the right or left arrow keys to move the cursor to the "Advanced" or "Advanced Settings" menu option. Press the "Enter" key. Move the cursor to the "Integrated Peripherals" or "Peripheral Configuration" menu option. Press the "Enter" key. Press the down-arrow key to navigate to the "USB Controllers" option. Press the "+" or "-" key to change the menu option to "Enabled." Move the cursor to the "USB Legacy Support" or "USB Legacy Function" field. Press the "+" key repeatedly until the value option changes to "Enabled." Press the "F10" key to save changes to the BIOS settings and exit the setup utility. Wait until the computer begins to restart and then press the power button and hold it for approximately four or five seconds. The computer shuts down completely. Unplug the PS/2 keyboard from the computer and set it aside. Reconnect the USB keyboard restart the computer. As soon as you see the initial boot screen, tap the "Delete" key several times and wait for the BIOS setup screen to appear. If you are able to access the BIOS setup screen with the USB keyboard, USB support is active in the BIOS.
Feb 15, 2013 | Dell OptiPlex GX110 PC Desktop
Start menu does not appear when clicked.
what occured for this to happen did move your laptop while it was working ?
scroll to bottom toolbar right click select toolbars at the top of a list select desktop
this will give a desktop icon in the toolbar
select it then select control panel all contol items look for keyboard hardware make sure you have the right keyboard selected
select properties you will see driver and driver details
or
restart your computer press and hold the delete or f2 key to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
Nov 12, 2011 | Dell Inspiron Mini 10 Notebook
I am using Dell Inspiron 1525 Vista Home basic,64-bit Os. I am facing problem with Keyborad keys - Space bar,Arrow Keys,B and N keys are not working.Kindly suggest the solution.
Try an external keyboard and see if that works.
Device manager and find keyboard
open that up and delete standard keyboard info and hard boot
Aug 25, 2010 | Computers & Internet
Left and right arrow keys not functioning
check the arrow keys it it's also not functioning in the BIOS:
- restart the system and press F2 five times during the splash screen of the big blue DELL logo to go to the BIOS (System Setup). Then test the arrow keys.
- if arrow keys are also not functioning within the BIOS the the keyboard assembly needs to be replaced.
- if arrow keys are working within the BIOS then reinstall the chipset drivers and keyboard driver found in the Drivers CD/DVD that came with the computer.
Dec 26, 2009 | Dell Inspiron 5150 Notebook
Keyboard keys share functions. Right shift key inserts a z and then shifts. z key does the same thing . Left shift key tabs and then shifts. 9 key and = key both give =9. Other keys also share...
1. try to do system restore first from the time system was working fine. reboot system. if fails.
2. update your anti virus then run a full system scan. reboot system. if fails.
3. update the bios. download the latest bios for your system from the dell support drivers and download section. reboot system. if fails.
4. reseat the keyboard cable. if fails.
5. reinstall the OS. if fails
6. replace keyboard.
Oct 25, 2009 | Dell Inspiron 2200 Notebook
My dell keyboard had the right arrow key come off, how do i fix it it iis an inspiron e1 505
Did you try just pshing it back in place? That worked when my key board lost the Escape key.
Oct 03, 2009 | Dell Inspiron 6000 Laptop Keyboard 0H5639
Dell Inspiron 8000 when I go into cmos(setup)F2, there is no control working. arrow keys do not work
Dell Laptop with bios or hard drive password set ? Unlock your dell laptop using the link below if it display a message that says "this computer system is protected by a password authentication system, you cannot access the data on this computer without the primary or administrator password, when you turn on the computer. This message is what you get if the BIOS is protected by a password. or you get system disabled
Go to: http://dell-inspiron-630m-bios-password.biospwd.com to get your dell bios password authentication and get full access to your dell computer, they can unlock almost all dell laptop such as dell inspiron, xps, latitude, precision, studio, vostro
Oct 02, 2009 | Dell Inspiron 8000 Notebook
Arrow keys do not work in Bios
try the page up and page down keys
Sep 23, 2008 | Dell Latitude D600 Notebook
Arrow keys do not function in bios
Arrow keys move the cursor into fields + or - keys change the values of the fields.
Dell Inspiron 5100 Notebook Logo
895 people viewed this question
Alun Cox
