Question about Canon imageRUNNER 5000i Laser Printer
Finishing tray Hello, The printer is saying to check and connect the finishing tray...I'm not sure how to connect that. Thanks, Sarah
0 characters
1 Points
Hello my CanonPIXMA MX410 has been working fine until yesterday It always says paper jam and I check there is no paper I dobn't know what to do please help me
Try disconnecting the printer completely from power and from the PC.
Reboot the PC.
Connect everything again.
Clear any print queues.
Make sure the paper feed tray is not filled to capacity.
Hope it helps.
Feb 23, 2012 | Samsung SCX 4200 All-In-One Laser Printer
Hp j3508 paper jam solution
Try disconnecting both the printer and the PC from power.
Re-connect them again and try printing.
Ensure all connecting cables are working properly.
Check all the paper paths for any stuck papers.
Make sure the rear access door is locked into place.
Load paper correctly into feeding tray.
Hope it helps.Thanks!
Oct 06, 2011 | Printers & Copiers
Printer says 41.3 unexpected size in tray 2. How do I fix this?
A couple of things to check.
1) Make sure the paper guides in the tray are adjusted correctly for width and in particular the length. 2) Remove the tray completely check guides. 3) Make sure the tray is fully seated into the printer. 4) Make sure the paper in the tray matches the size of the guides.
If the guides and paper seem OK, the printer may need servicing by authorized service center.
41.3 UNEXPECTED SIZE IN TRAY [xx] alternates with LOAD TRAY [xx]: [type] [size] Description This is typically caused if two or more sheets stick together in the printer or if the tray is not properly adjusted.
Jan 14, 2011 | HP LaserJet 2420 Printer
My aficio 2035e shows sc 329 and sc 322. what does this mean?
  1. Remove paper from all output trays. Depending upon the options fitted to your device, the output trays are:
  2. Locate the gray cables that are connected between finisher and main unit. Check that they are secure, and that the cables are in good condition.
  3. Switch off the device at the red power switch.
Dec 16, 2010 | Printers & Copiers
C1183 error the trays desent and rise normaly put the stapeling unit coms at the front? this must be in center? thanks if anyone can help bart
Error code C1183 means finishing option elevator drive malfunction. It appears due to tray lift motor failure on the finisher. To trouble shoot the issue turn off the power and open the elevator section to check the elevator motor. Wait for 2-3 minutes and check if the issue is resolved. If this doesn't work then check the alignment of front and rear rollers of the finisher. Also make sure that the finisher exit guide rollers are fine & the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. Sometimes this error may appear due to a broken lower gear by the pin slot. Hope this helps...
Oct 09, 2010 | Konica Minolta Printers & Copiers
Errorcode e000540-8003
do you have inner finisher moldel S-1, or outer finisher?
In cases of S-1 finisher this error means that you have problem with stack tray motor, in most cases the problem isnt stack tray motor but finisher controller pcb.
You should try to replace finisher main pcb.
But be sure to check tray for any damadges.
Hope that helped.
Jul 09, 2010 | Canon imageRUNNER 4570 Copier
COBAO error
Finisher tray lift problem. I have seen this be very simply the top tray on the finisher is not fully inserted into it's holder. So check the trays on the finisher to be sure they are fully installed into their bracket. Then turn the machine off then on again. The finisher just so you know is where your copies come out.
Oct 19, 2009 | Minolta Di3510f Bizhub Copier
Printer problem
Check your paper configuration. Make sure Tray 1 is configured for Plain paper and is showing the right paper size. If it is configured for anything other than Plain Paper, most of your jobs will not print. Also, if the size says something like Univseral, then the printer is not touch that tray unless your print job also specifies Univeral as the size. If is does say Universal, check the paper guide in the tray and make sure it is pointing exactly at the paper size you are using
Dec 12, 2008 | Lexmark T642 Laser Printer
Paper jam problem
Hi, if you are having the paper jam issue , then unplug the power adapter and remove all the papers from the paper tray and if you closely look inside the input paper tray you will find rollers , move the rollers with your finger tips. open the printer cover to the extreme left you will find the cartridge holders , move the holder from left to right a couple of times , behind the cartridge holders you will find a transparent strip which is inch wide and is inch wide and firmly connected at both the ends, use a damp cloth and clean that strip . lift the printer an#d shake it firmly turn the printer upside down and gently tab on the base , look for any obstructions.
Try all these steps and if there is an issue then you have to purchase the new printer.
good luck :), let me know once you perform all these steps
May 01, 2008 | Dell 924 All-in-One InkJet Printer
BH C250 and the Stapler FS-501
Check the 2 covers (one screw on each) where the output elevator tray attaches to the finisher.
Mar 04, 2008 | Konica Minolta bizhub C250 All-In-One...
Canon imageRUNNER 5000i Laser Printer Logo
Top Canon Printers & Copiers Experts
old marine
old marine
Are you a Canon Printer and Copier Expert? Answer questions, earn points and help others
