Question about RCA P52939 52" Rear Projection Television
RCA P52939 TV
I am getting this big screen for free. However they said that the sound card in it doesn't work. Does anyone know what or how much the sound card is and how much it would cost to fix it? I called Sears and the lady couldn't even find a part for a sound card. HELP!!!
  • 4,234 Answers
There is no "card". There is an IC that outputs the sound to the speakers. When you get the set, see if there are any other specifics that you can list and we'll look for a common cause.
Dan
Posted on Nov 01, 2008
Rca big screen model # P52939
I had same problem on rca big screen M #p46734ba it was hi voltage splitter the part # for mine is 40431-090 GE/RCA splitter it was $36. online
Mar 12, 2009 | RCA Televison & Video
I have a rca p52939 that won't turn on.
Failure of the HV splitter was a very common problem when I was doing these big screens on the road. The set won't come on if the splitter shorts. We used to test if that was the cause by pulling the HV input lead out of the splitter (leaving it still inside the plastic cup so it wouldn't arc anywhere) and turning the set on. Most often the set would fire right up (without picture of course).
I believe the RCA part number for the splitter is 205064, and it's available from a number of sources. I'm not home right now so I can't check. If I have the number wrong I'll post a follow-up comment.
Feb 13, 2009 | RCA P52939 52" Rear Projection Television
Rca big screen model p52939
If you cannot get a good convergence then the convergence modules need replacing.
Jun 20, 2017 | RCA P52939 52" Rear Projection Television
Power problem on a RCA big screen TV
Even with the tv turned off, the power supply is still active.It's supplying voltages to the microcontroler, that's why each time you press the power button on remote the tv respond by turning on. First check the power cord to be well connected in the power-bar and if it's ok...well the power supply is defective and due to the high risk of electric shock i suggest you to call a technicien.
P.S. I respond here because I don't know why our chat session got disconected.
Feb 01, 2008 | Televison & Video
Rca p52939
Does the Tv pick up a signal ? ( picture/sound ) If not, you may have a tuner problem as the screen will default to blue with no signal apparent. Could also be a cable problem. Hope this helps
Ed
NC Electronic
Mills, Wyoming
Nov 18, 2007 | RCA P52939 52" Rear Projection Television
Rca big screen want come on
1) Replace IHVT (aka flyback transformer ) Part # 250694
OR
2) Replace HV BLock part # 250671
OR
3) Check for arcing CRT ( red,green or blue )
Please rate this solution.......
Nov 14, 2007 | RCA P52939 52" Rear Projection Television
RCA P52753AT tv will not turn on
the High Voltage splitter needs to be replaced
Oct 06, 2007 | RCA P52939 52" Rear Projection Television
RCA P52939 rear projection TV
Vertical sync is an IC function = shop repair = remove light box
and take it to a quality repair facility for an estimate = beware
of "Free Estimates" = pay for diagnosis, get it in writing.Mainly,
I'm finding bad solder connects in this style chassis,sometimes
I work on two or three at a time in my small repair shop........T.
Please rate this solution........................
Mar 19, 2007 | RCA P52939 52" Rear Projection Television
RCA P52939 52" Rear Projection Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
