Question about Frigidaire GLTR1670A Front Load Washer
GLTR1679 WASHER MAKES BANGING NOISE ON SPIN CYCLE.
IT WORKED FINE FOR 4 YEARS BUT SUDDENLY IT WENT BESERK.
ON NORMAL SPEED IT SEEMS LIKE IT WOULD EXPLODE!
  • 3 more comments
  • RONZARD Nov 01, 2008
    SHOCK ABSORBERS/ STRUTS ARE SECURE & RESPOND TO TUB MOVEMENT AS I EXPECTED. MACHINE BEHAVES AS IF A FIXED IMBALANCED WEIGH WERE IN TUB.
  • RONZARD Nov 07, 2008
    SHOCKS ARE OK
    Drive belt looks & behaves like new. Pulley has about 2 mm axial play, but no transverse play [bearing seems OK]
    WHEN ROTATING DRUM BY HAND, A CLUNKING NOISE IS HEARD ONCE EVERY REVOLUTION.
    NOTHING IS STUCK IN INNER BASKET HOLES.
  • 905 Answers
Either springs have lost strength and form , thus not holding in place well
or it is bouncing on the bottom from touching
what is the position that it is in when sitting still and how stable is the range of motion that is has?
Posted on Nov 07, 2008
  • jason Nov 07, 2008
    if you hear a clunking sound , you will need to pin point the sound , but this could be a bearing
    where is the clunk comming from?
    Scholar:
  • 44 Answers
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
  • vinodh umaiayar
    vinodh umaiayar Nov 07, 2008
    The rear legs are usually self adjusting after tilting forward to
    release and then placed back on the rear legs. The front adjustable
    legs should be as close as possible fully screwed to the washer base
    while levelling. Levelling is important both side to side and front to
    back (use a spirit level) but even more important is diagonally. This
    means grasping the left rear (avoid grasping the plastic controls
    cover) and the right front and trying to rock the washer. Adjust the
    right front leg to eliminate any rocking and repeat for right rear to
    left front diagonal. I would be interested to find out where your
    washer is located and if you have any success with this levelling
    procedure. Good luck
    Sergeant:
    Novelist:
  • 196 Answers
Check anything stuck in one of the inner basket holes and make a scrapping noise, they can actually make there way into the pump and jam the pump, or make a terrible noise when the pump is running. Grab a flash light and have a peek inside the washer for this. Front load washers seem very common to this happen!
thanks.
    Genius:
  • 1,239 Answers
Hi The drive belt (or belts) of a washing machine may become worn or damaged, causing noisy operation or stopping the washer entirely. A damaged drive belt is easy to replace. Remove the back panel of the washer to gain access to the belt. To remove the belt:
Step 1: Loosen the bolt on the motor bracket and move the motor to put slack in the belt.
Step 2: Remove the old belt and stretch a new one into place on the pulleys.
Step 3: To put tension on the new belt, use a hammer handle or a short pry bar to push the motor into position while you tighten the bolt in the adjustable bracket. The belt should have about 1/2 inch deflection when you press on it at the center point, midway between the pulleys. If the belt is too loose, it will slip on the pulleys, causing the machine to malfunction. If the belt is too tight, it will wear very quickly and will probably become so hot that it will start to smoke or smell.
Loose pulleys can also cause problems. Most pulleys are fastened to shafts with setscrews around the hub of the pulley. These screws must be tight or else the pulley or belt will slip. The resulting malfunction may seem to be caused by a faulty motor, but it can be corrected by tightening the pulleys and adjusting the belt. For this reason, always check the belts and pulleys before working on the motor.
  • ABHISHEK.C
    ABHISHEK.C Nov 07, 2008
    The washing machine tub, or basket, generally doesn't cause problems. However, at times it may cause damage to the laundry, make a lot of noise, vibrate, or stop completely.
    If laundry is torn during the wash cycle, feel around the tub. If you find a rough spot, you may be able to smooth it with an emery board. Sand the spot lightly. If this doesn't work -- or if you have to cut to bare metal to remove the roughness -- the tub should be replaced. In this case, it's probably much wiser to replace the entire washer.
    The agitator -- the finned part that fits on the tub shaft -- can also tear laundry if the fins are cracked or broken. You may be able to solve the problem temporarily by pinching off the splinters with pliers and lightly filing the plastic smooth, but this is just a stopgap measure; the agitator should be replaced. Replace a damaged agitator with a new one of the same type. To do this, unscrew the cap on top of the agitator. With the cap off, pull straight up on the agitator; it should lift off. If it doesn't move, rap its side with a hammer. If it still won't lift off, drive wedges under the bottom rim of the agitator to dislodge it. Then set the new agitator into place and replace the agitator cap.
    Damage to the snubber, a padlike device sometimes located under the agitator cap, can cause the machine to vibrate excessively. The snubber may have a suspension spring in it. Lift off the agitator cap and examine the snubber. If the spring is broken, or if the pad is visibly worn, replace the entire snubber. Snubbers might also be found at the splash guard at the top of the tub, under the transmission, or as part of the water pump housing. Look around until you see it.
    If the machine doesn't have a snubber, listen for noise at the suspension unit between the tub and the machine cabinet. The suspension unit has fins or pads that may need replacement. In some cases, the entire unit may have to be replaced. Another noise point is the basket support nut. Tighten the nut or, if you can't tighten it, replace it.
  • Frigidaire Master
  • 19,396 Answers
Check the strut assembly. also a bad bearing can make banging noise.
Posted on Oct 31, 2008
  • Ginko
    Ginko Nov 01, 2008
    See here a diagrams of a washing machine: Front Load Frigidaire/GE/Kenmore Style
    Check all the shock absorbers and the springs. One of them is probablu lose or broken , and for that reason the machine is banging.
    You can find replacements here
  • Ginko
    Ginko Nov 07, 2008
    Check that this is not caused just by foreign objects stuck inside.
    If struts and springs are ok, then it is the main bearing thant must be replaced.
Whirlpool washer does not spin
Try taking some of the wet clothes out maybe to heavy
Jan 15, 2016 | Whirlpool Washing Machines
Final high speed spin very noisey
Something is causing the drum to be way out of balance. Does it bang and make noise when it's spinning empty? Probably not. Is something stuck on the side (inside of course) of the drum, causing it to shake when spinning? If not, a spring or shock absorber (connecting drum to sides, bottom or top of machine) has broken or come loose.
Nov 23, 2013 | Malber WD1000 Front Load Washer/Dryer
Bangs when spin cycle is going
sounds like the washer is not level, underneath the washer are 4 legs that are adjustable, you just turn them up or down. one of them may be to high.
Jan 15, 2012 | Kenmore Washing Machines
I'VE GOT A WHIRLPOOL STACKING WASHER DRYER COMBO BOUGHT APPROX 2002. wASHER WORKS FINE, pUMPS WATER OUT FINE BUT ON SPIN CYCLE SEEMS OFF BALANCE AND MAKES ALL KIND OF BANGING NOISES. i EVEN TRYED SPIN...
Transmission bearing has failed. The transmission has to be replaced as a unit.
The transmissions are relatively inexpensive (around 150 to 175 dollars) I have replaced 3
of these and they are rather difficult.
Apr 12, 2011 | Whirlpool LTE6234D Top Load Stacked...
Hard bang on spin with my frigidaire gallery frontload washer
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
Apr 15, 2010 | Frigidaire GLTF1040A Front Load Washer
Kenmore 80 series has loud banging sound during the spin cycle
I had a washer that at the beginning of the spin cycle it was fine, but when the water was half drained it would begin making a banging noise. When the draining reach the bottom and the spin speed increased it was fine. Finally found the problem - What happened was the tabs that hold the control arms for the brake had loosened. During the spin cycle especially in the middle of the cycle (when torque was at the maximum and speed was at medium. The brake spring would flex out due to compression and hit the some extended metal tab on the brake housing. Once the speed increased and the torque reduced the spring no longer hit the housing tabs. Fix the problem by bending the tabs that hold the brake control arms in place to better hold the control arms in the proper location.
Jan 19, 2010 | Kenmore Washing Machines
Chugging like noise during certain cycles
your clutch need to be replaced as does the tub shaft bearings i;m sorry this is not a do-it-yourself job, try to make a deal to trade in your washer
Apr 22, 2009 | GE Washing Machines
Model 110 washer will not go into a final high speed spin.
hi, i would suggest the timer/programmer is faultyas it is ok on the other cycles, the noises you have described may have caused some damage,
Feb 10, 2009 | Washing Machines
Noisy clothes washer
I am thinking there may be an object caught between the inner and outer tubs...perhaps something came out of a pants pocket and was "flung" overboard into the outer tub. If you remove the top, and push the inner tub (moving tub) to one side, look with a flashlight for a foreign object. the noise will be fine until high speed kicks in and begins to disturb the sleeping object into a frenzy.
Jul 25, 2007 | GE WHRE5260E Top Load Washer
Frigidaire GLTR1670A Front Load Washer Logo
144 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
