Question about Dyson DC17 Animal Bagless Upright Cyclonic Vacuum
Brush bar won't turn on
After I start the vacumn and til it in the usual brush on position it will not engage. Note this happened after a very brief altercation with an area rug.
  • 1 more comment
  • ling225 Nov 18, 2008
    Problem happened under almost identical circumstances
  • britishtar Dec 07, 2008
    same problem, same circumstances (area rug). The brush bar spins freely when rotated manually, the belt is intact and engages the rotor of the brushbar motor properly. The brushbar motor is not turning for some reason. There may be a relay or fuse that needs to be reset/replaced in the brushbar motor assembly, but I'm not sure...
  • Anonymous Dec 09, 2008
    My Dyson grabbed a piece of the unravelling berber carpet and wound it around the brush bar. Previously, I have pulled the piece of unravelled carpet out and the Dyson has worked fine. This last time the brush bar quit spinning when the vacuum is turned on.
This is extremely embarrassing, but if I can save you some frustration, I'll gladly swallow the humble pill. I had the same problem, after vacuuming an area rug, the brushbar quit spinning. I let it cool to ambient temperature and tried again, thinking that the auxilliary motor that turns the brushbar may have overheated and tripped a thermal cutout. I even took the unit apart and inspected the brushbar motor to ensure the windings weren't damaged and that the brushes properly engaged the communtator.
Ready for the solution? There's a button right next to the power button that has a picture of a brushbar on it. Guess what it does? It turns the brushbar on and off. I cycled that switch, tried again, and: Ta-dah! It worked.
Posted on Dec 14, 2008
This same thing happened to us. We found out that some of the teeth on the belt were missing. We called Dyson and they sent us a free replacement belt, we put it on, and it fixed the issue. Dyson customer support is GREAT!!
Posted on Dec 12, 2008
  • 43 Answers
Maybe needs new clutch or if bottom panel has been removed at any point belt could be trapped in belt guide
Posted on Nov 10, 2008
I can't get the brush to work or suction or any air flow in the lower part of the vacuum.
Depends on what you mean by 'disconnected the lower part.'
See end of the note for a link to the manual. Dyson doesn't have it directly, and a number of places either want you to download spamware, or only have a non-english copy.
1) If you took the roller all the way out, you will have had to have eased it out of the loop for the drive band, and then eased it back through after cleaning. If it's not through the loop, no drive power. The band is stiff, so it can be a bit of a challenge to pull out far enough to get the roller back through. Use a smooth dowel or other smooth sided lever to pull band out enough to feed the roller back through. (Smooth = not cutting the band)
2) If you didn't take the roller out as in (1), or did feed it back through the belt before closing it all up, then there's a couple of possibilities. A) The brush will not spin if the unit is full-upright. Put your foot on the lower assembly, pull the handle back to the 'I'm about to vacuum something' position, and try again.
B) According to the manual, this model has an 'engage brush' button. The system should start with the brush engaged, but try toggling it with the handle not up-right.
If still not spinning, turn off and unplug. Try spinning the brush by hand. If it spins freely, the clutch to engage the brush isn't engaged. If there is resistance, then it's engaged (unsure if it auto-disengages when powered off. You's want the handle tilted back when you try this).
Manual Link:
http://homeappliance.manualsonline.com/manuals/mfg/dyson/dc18.html
Oct 17, 2015 | Dyson Dc-18 "the Slim" Upright Model...
Vacumn motor does not start with the switch. Light indicates the vacumn is on
check the top area of where the bag goes in.There is a tiny switch that get pushed down by the cardboard top of the bag.This is to protect the motor by not allowing the motor to engage without a bag
Sep 13, 2014 | Electrolux electric hose models 2100
How to repair windtunnel hoover agitator that will not turn
Likely a broken belt. Also check the agitator brush roll bearings (in either end under the end caps) for hair, strong, thread, etc. as this will make the brush roll harder to turn and wear/break belts prematurely. If all these check okay, then observe the tensioning roller that causes the V belt (runs from the idler pulley to the brush roller) to be sure it is swinging down when the handle is released to hold tension on the belt, causing it to rotate. These tensioning rollers can break, but often are locked into the "Bare Floor" setting without the user noticing. Slide the carpet brush roll selector (located on top, next to the floor height slide adjustment) back and forth and make certain it is all the way into the "Carpet" setting to allow the tensioning roller to engage. [Note: The tensioning roller is always retracted (in the neutral or off position) when the handle is in the upright position. You must release the handle to allow this tensioing assembly to engage.]
Sep 05, 2014 | Hoover Model U6485900 Upright Vacuum...
Rotary brush does not spin when using on carpet
The brushes are usually belt-driven. You may need to replace the belt.
Dec 16, 2017 | Dyson DC29 Animal Vacuum
Brush is not engaging when vacuuming. If lifted
therre are usually aprings that hold the brush in position or a spacer thaqt turns when you adjust the height. turn the vacuum over and remove the plate covering verything. make sure your unplugged first. it usually takes about 5-6 phillips head screws. look for loose ,broken or missing parts. make the the roller is taken out and is carefully cleaned of all hair etc esp that just at the edge of the roller where it meets the monting devices. the hair and debris often gets stuck there and once removed works much better. also make sure the belt is not stretched and is slipping on the brush. if it is replace it. good luck.carefully reassemle the parts you removed being very aware of what postiotn everything was in when you took it apart. make sure everything has proper clearance and then test your vacuum. if you find broken or missing parts replace them first ofcoarse.
May 14, 2010 | Hoover Tempo Widepath Upright Vacuum -...
I have a Model U57809RM Hoover Cyclonic which started making a very loud noise. Changed both belts on it but the noise persists. It seems to happen when I put the handle in the 'engage to vacuum' mode. The...
You could have a broken fan in the motor and need to replace the fan. If the noise is coming from the brush area of the vacuum, you probably have a broken bearing in your brush roller and would need to replace the brush itself.
Hope this helps.
Jan 29, 2010 | Hoover Vacuums
Brush will not turn
The most common problem is the handle isn't screwed in tight enough when the machine was assembled. Try tightening it down all the was and the electrical connections will then seat properly.
Jul 05, 2009 | Bissell Healthy Home HEPA Bagless Upright...
Fantom twister wont work light is on
When you say, "just stopped", did the MOTOR stop operating and there's no sound from it at all? Or, is the motor still working or sounds like it does, and it stopped vacumning?
If the MOTOR stopped, most likely there is a short somewhere in the connection at the motor. Think 'repair shop'.
If the motor still runs and there's no VACUMN ACTION, think Roller Brush which operates by virtue of a rubber belt. Turn the machine on its side and turn it ON, keeping FINGERS !AWAY! from the roller area. If the Roller Brush is not moving it may be that the belt has slipped off or is broken or simply too loose to turn the Roller. Also sometimes debris such as strings, long hair, carpet strands/fibers will become wrapped around the roller especially next to the roller bearing/brace points, to the point of binding so tightly that the roller will no longer be able to actually roll which would now prevent it from 'Vacumning' or sweeping dirt and such up into the vortex of the vacumn chamber. In which case, !!UNPLUG!! the machine, use small scissors to cut away the material wrapped around the roller paying particular attention to the brace point areas.
Apr 20, 2009 | Fantom Vacums FM780 Twister 700LX Upright...
No vacumn action
Is the roller turning, if not you may need a new belt and/or brush roll. Did you check the inlet by the brush roll?
Feb 09, 2008 | Eureka 2961AVZ Bagless Upright Vacuum
Dyson DC17 Animal Bagless Upright Cyclonic Vacuum Logo
486 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
