Question about Fujitsu Siemens AMILO D-7830 Notebook
Restart When I turn my laptop on, it appears as though windows is about to start (the blue login screen appears and says 'windows is starting up...'), then the laptop restarts. If I left it alone it would keep on restarting. The same thing happens in Safe Mode. I think the problem may be because I updated my java. Is there any way I can turn on the laptop without going to get it fixed? Thanks, Harry
  • 97 Answers
- Let me know what is your Operating System?
- Its like XP problem, you should be run using your Windows XP installation CD and follow the steps.
Posted on Sep 25, 2008
Dugiehowsa could be right but it sound to me that another reason might be that the laptop is overheated and the fan is dusty
Posted on Jun 27, 2007
This may be late... but I just diagnosed the same problem. In safe mode, go into the display driver and uninstall it. This forces the standard windows driver to load. If this fixes the problem, reload the driver, but set the hardware acceleration to NONE -- this is in the troubleshooting tab for the display adapter. The cause of the problem is probably the video chipset, which is unfortunately on the motherboard. However, disabling the hardware acceleration does make the laptop usable.
Posted on Mar 31, 2007
    Novelist:
  • 114 Answers
It sounds like you may have some corrupted system files. You should be able to repair them using your Windows XP installation CD and the steps out-lined in this article. http://www.short-media.com/review.php?r=313
Posted on Sep 18, 2006
4 Suggested Answers
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
acdr
  • 1913 Answers
SOURCE: FLASH DISK ERASED
when upower up the laptop press DEl or F5 or F12 to wnter in bios or which is right for enter in bios .
then if u r not ab;e to enter in bios.
u have to reset your bios settings.
remove your cmos cell for 15 minutes it is back side of your laptop.u have to open back side of your laptop.then try to start.if again same problem then u must have to upgrade again your bios .
let me kniow .please.
Posted on Dec 30, 2008
  • 85 Answers
SOURCE: Hi, laptop will not start
Seems like your Operation System crashed. Find your reinstall CDs and reload windows.
If you find someone who can pull the hard drive and hook it to another machine and run a check disk that might save you from reloading it and losing all your data.
Posted on Apr 15, 2010
techresolve
  • 109 Answers
SOURCE: Having trouble turning my laptop on at the moment
problem must be with the fan or HDD because these are only two internal devices which does mecanical job inside.
Sometime overheating of CPU or the malfuntioning of RAM make noise thrugh the system speakers.
Posted on Apr 20, 2010
Testimonial: "Thanks very much,that has helped narrow the problem down which should make it easier to resolve"
Dm4-1165dx
HI, if you press F8 during start up, before you see the Windows logo appear you should get advanced start-up options appear. Select "disable automatic restart on system failure", when the system blue screens again make a note of the text displayed and post it here. I should then be able to offer further advise.
Mar 18, 2014 | HP Pavilion Computers & Internet
My Compaq Presario V3000 has a problem with the wireless on it. Whenever the wireless side-switch is turned on before I turn on my laptop, before it shows the login screen a blue-screen message shows...
you should reinstall the wireless drivers on your laptop go to the hp support site and type in the model number (it can be found on the white service tag under the laptop)
Jun 14, 2011 | Computers & Internet
On start up computer will not display log in window, unable to get to login screen. Blank screen
AS YOU ON THE SYSTEM BEFORE WINDOWS STARTS KEEP PRESSING THE F8 KEY CONTINUEOUSLY. A MENU WILL APPEAR. SELECT SAFE MODE AND ENTER. WINDOWS WILL LOAD IN SAFE MODE. THIS WILL SOLVE SOME OF YOUR PROBLEMS. NOW RESTART THE SYSTEM IN NORMAL MODE.
IF THIS DOES NOT WORK SELECT "LOAD WINDOWS WITH LAST KNOWN GOOD CONFIGURATION " AND THEN RESTART. THIS WILL SURELY SORT OUT YOUR PROBLEM.
PLS REPLY OR COMMENT. THANKS
May 15, 2011 | Dell Vostro 1000 Laptop Computer (AMD...
The laptop starts then windows says loading then a blank screen. battery light was orange and after 3 hours plugging it in now it is blue. could it be the battery?
try doing this step.
-turn off the laptop completely
-turn on the computer and go to Safe Mode by tapping on F8 once you press the power button
-once you were able to login to Safemode, click on start>run>type msconfig.
it should show you a picture just like this:
-go to the Startup tab then click on Disable All
-then click on Services tab
-put a check on "hide microsoft services"
-Click Disable All
-Click Apply then OK
-it will prompt a message that says you need you to restart the computer, click restart now
-see if you will be able to login to Windows normally
Mar 17, 2011 | Lenovo IdeaPad S10e Netbook
I turn on my laptop and it beings to load. Once the loading windows screen appears, the logo doesnt show, only the loading box at the bottom. The nothing else happens and the computer stays this...
Welcome to Fixya Support
I am Michelle, and i will be assisting you regarding the issue
please restart the system and tap the F8 key on initial system logo.
in the advanced menu select the safe mode option.
login as an administrator
if you are able to login, perform a system restore
click start...in the search box type system restore
in the window that appears, restore computer to earlier date and time and click next
select a date may be a week or 2 back when system was running fine and click next
follow the onscreen steps
in case you are not able to logon then you need to perform a repair of windows.
Please let me know the operating system you are using xp,vista or windows 7 so that i can accordingly share the repair steps with you.
Nov 29, 2010 | Dell Inspiron 1525 Notebook
Lenvo blue screen error message when computer starts up
Please try to unplug the laptop from power and remove the battery for over 10 seconds. Then start it up again. There are other things we can try if this does not work.
Mar 19, 2009 | Lenovo 3000 N200 Notebook
Error window when starting windows xp
restart in setup or bios options
then choose to set to default
then f10 to save and exit
you may have had a virus
let me know
you may need to format
if you can't start in safemode
Feb 02, 2009 | Toshiba Satellite M50 Notebook
My HP Notebook first showed a black screen and then after a hard shutdown and restart it only shows a black screen with colored lines. It seems that it is starting up even though I can't see the screen.
Try this,Start in VGA mode.Once started,update your video drivers
To use a Safe Boot option, follow these steps:
  1. Restart your computer and start pressing the F8 key on your keyboard. On a computer that is configured for booting to multiple operating systems, you can press the F8 key when the Boot Menu appears.
  2. Select an option when the Windows Advanced Options menu appears, and then press ENTER.
  3. When the Boot menu appears again, and the words "Safe Mode" appear in blue at the bottom, select the installation that you want to start, and then press ENTER.
Safe Boot options loadTOCNode(2, 'moreinformation');
  • Safe Mode (SAFEBOOT_OPTION=Minimal): This option uses a minimal set of device drivers and services to start Windows.
  • Safe Mode with Networking (SAFEBOOT_OPTION=Network): This option uses a minimal set of device drivers and services to start Windows together with the drivers that you must have to load networking.
  • Safe Mode with Command Prompt (SAFEBOOT_OPTION=Minimal(AlternateShell)): This option is the same as Safe mode, except that Cmd.exe starts instead of Windows Explorer.
  • Enable VGA Mode: This option starts Windows in 640 x 480 mode by using the current video driver (not Vga.sys). This mode is useful if the display is configured for a setting that the monitor cannot display.
Please rate this a fixa
Feb 01, 2009 | Microsoft HP Pavilion DV6276US Notebook PC
User profile
Hello
the user profile is corrupted
try to login on a other account.
if you dont have a account try to login in safe mode
press F8 before windows starts(after bios screen)
and login to your account.
in safe mode try to create a new account and restart your computer.
what os does he have?
good luck
Oct 13, 2008 | HP Compaq Presario 2200 Notebook
Startup
hi,
you should have specified about your laptop. but you can try the following steps.
1. check the powercord and battery.
2. check screen brightness and contrast.
3. assuming that you login . click start-> run ..( msconfig ) -> and press ok-> in the window that appears click the startup tab. now click disable all. this will probably help..
4. or you might be running Vista in a 512 ram.
5. or you can try to insert the windows installation disk and start the laptop. and if the blue screen appears continue reinstalling the OS. this would probably help.
Dec 30, 2007 | Sony (B99860307) for VAIO PCG-K series...
Fujitsu Siemens AMILO D-7830 Notebook Logo
862 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
