Question about Lands Phones
GE 900 model no 26938GE1-D key pad
Some of the numbers on the key pad are not working (1,2,3,and 6); is there some way to repair this? Is it cost efficient to fix? What would be causing this problem--Thanks---
Ok pop the phone apart and wipe the gew off the back of the pad and board throw it back to gether and its good as new
Posted on Apr 03, 2010
GE JVM1440SH001 f3 error
see the commentaries and repair:
F3--Shorted key panel(touch pad), will occur if a shorted key panel is detected continuously over 60 seconds.
test the following:
1. Door is not closed (some models).
2. You waited to long (open and close door to wake it up).
3. Controller is confused (pull plug for a minute or two to reset).
4. Defective interlock switches.
5. Faulty controller or its power supply.
6. Touchpad or controller board contaminated by overenthusiastic cleaning.
7. Defective/damaged touchpad.
Jul 31, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
900 mhz
You directed this question at me, but unfortunately I'm unable to provide you with a "real" solution at this time. FixYa has informed me that by providing you with this "solution" your question will then be made visible to other experts; hopefully one of them will be able to provide you with a real solution.
It would also help if you ask a question.
Thank you for using FixYa.
Dec 02, 2011 | GE 26938GE1 Cordless Phone
Ge built in 1993 oven shows an F-1 sign and beeps
Hello there:
any time you recieve the f-1 and sometimes a f-o error with the beeping this is from the electronic range controle board or erc for short and this means that that part has fgailed and needs to be replaced if you go to repair clinic.com you can look up you oven model number and get parts from there or if you have a appliance repair center in your home town give them a call and tell them the ovens model number and tell them you need a erc or electronic range controle board ok?
Hope this helps
Best regards Michael
Aug 16, 2010 | GE Ovens
Error Code -F1- and Broken glass door
Welcome to fixya.com f- 1 is the electronic key pad a key is stuck and usually you will need to replace the key pad site to obtain parts is partsselect.com but before you do disconnect power to unit for 15 min then re connect power to see if unit reset its self. And at Parts select.com you can order the glass you need, Regards, Lee Davidian
Apr 19, 2010 | GE Profile JTP56 Electric Double Oven
GE dryer... the soft touch key pad is not working and the repair man said it will cost an arm and a leg to fix it. Can I repair it my self?
NO. this interface(touch pad), cannot be repaired. The only option is to replace it. The repair tech was correct, unfortunately.
Aug 21, 2009 | Dryers
New battery
it should have a programable freq in phone if so change it and see if it helps you could be getting int form new services in the air in your community wireless internet ect,
Oct 26, 2008 | Uniden Cordless Phone
GE 5-8 DIGITAL CORDLESS PHONE - SET VOLUME
If you have call waiting, you can press the flash key to pick up the second call. It puts the first call on hold. Press the flash key again to switch back
Oct 05, 2008 | GE 26938GE1 Cordless Phone
GE cordless model 26928GE2-A
Dial tone is OK, but can't dial out
• Make sure the tone/pulse setting is programmed
correctly.
TONE/PULSE DIALING
1. Make sure the phone is OFF (not in TALK mode).
2. Use the CID/VOL left (-) or right (+) arrow button to
scroll to 1TONE or 2PULSE, or use the touch tone
pad on the handset to enter the desired setting. For
example, to choose TONE dialing, press the number 1
key. 1TONE is the default setting.
3. Press flash/program to store selection. You will hear a
confirmation tone.
Feb 06, 2008 | GE Cordless Phone 900 MHz
2nd handset doesn't work
Hi Rayfatz,
I think your problem might be that the second handset is not registered with the base station. Take the second phone out of it's cradle and place it in the base station (where the first phone is), and leave it there for 20 seconds. Place it back in it's own cradle, and it should start working. Hope this helps! Hal
May 27, 2007 | GE 26938GE1 Cordless Phone
Lands Phones Logo
257 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
