Question about Durabrand DVD-1002 DVD Player
Need hook-up information to tv
Need hook-up to tv
I am trying to hook up the gxp to a samsung vcr
Posted on Feb 16, 2009
I need information on operation and hook-up.
Posted on Nov 18, 2008
I need the code for Panasonic DVD player for Lil leaps can some1 help me
Posted on Nov 08, 2008
How do I attach a flat leaf antenna to an older Phillips TV
The old style TV's need a converter box. You cannot just hook up an antenna directly to the TV. The TV signal in the air is now digital. Your old style TV has an analogue TV station tuner. The converter box transforms the digital signal into a usable analogue signal. Just do a online search to find out any information that you need.
Oct 18, 2015 | Televison & Video
Boise
What model of TV are you hooking the Bose system pls? Alternately, determine if the TV you are hooking it into has a pair of white and red RCA connector marked Audio OUT.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 14, 2008 | Bose 3 2 1 GSX System
Hook up pc tv
Need more information. Are you using VGA, HDMI S-Video?
Apr 29, 2013 | eMachines ET1161-07 Desktop PC
Trying to hook this tv up to my dish network box but do not know what channel is the a/v for this tv. do not have a remote for the tv.
Hello
Please consult your user manual to get the required information you need,but if you look at your remote,you will see a button that has video written on it or AV.Your user manual should contain the required information anyway so do consult it
Jun 12, 2011 | Toshiba 36AF61 36" TV
How do u hook up a kerookie machine to a tv
The methods of hooking up a karaoke with a TV varies depending on the make and model of the TV.
You can get the information on how to do that if you go through the manual that comes with your TV also, you post me the name and the model of the TV and i would give you a step by step guide on hoe to hook up your karaoke.
Hope this solution was helpful to you? Please comment for more information and thank you for using fixya.
Jan 10, 2011 | Audio Players & Recorders
Hook it up to the tv
If your hooking it directly to the tv depending on how old the tv is use one of the inputs. Hook the two red and white to red and white and the yellow to the video in input. If it's an older tv you will need whats called an rhf adapter. Hook your color codes together and use a cable cord to go from the antenna out to the tv's uhf input. I hope this information was helpful........... : )
May 10, 2009 | Televison & Video
Trying to hook up having problems with connication ,need manual
Okay... with limited information I'll give it a shot...
Depending on the age of your tv, sometimes they have multiple input options. Since you are referring to hooking it up with cable, I'm guessing that you are using a coaxle for your super nintendo. The easiest way to get it hooked up it to upgrade to a 3-prong AV cable. You can find them on ebay for about $2.
If you don't have any open inputs on your tv you will need to either continuously change what is connected to the tv (unlikely) or buy an RF switch from any store that sells electronics. I think they are running $20 or less now adays. (They are worth the cost because they allow you to connect DVD player, VCR, game component, etc all using one input on TV.)
Mar 13, 2009 | Nintendo Super NES Console
Adding vcr & rec to a '93
Please hook up VCR with TV through RF cable and check picture of VCR playback in TV.
Now you can hook DVD player video-audio out in VCR input and can have dvd playback picture in TV via VCR modulator.
If you want to listen sound via receiver then hook audio red-white cable between VCR audio out and receiver audio in terminals.
Let me know exact model numbers of units to help you out more.
Thank you.
Jan 13, 2009 | Televison & Video
Hook-up
first you do connect cable to your > combo VCR / DVD player & recorder then connect to > to your TV:
cable coax output or if that cable have video/audio ouput is going to INPUT >to combo VCR / DVD player video / audio output is going to INPUT > to TV,.that's the time you can record and playback;
click below for more information in hooking up:
DVD Players/Recorders: Home Theater Setup, Installation & Hook Up ...If i have helped,please click fixya,it is the only way i get paid for my work ,also please consider leaving feedback...
Good luck ,and Thank you in advance:
Jul 15, 2008 | Televison & Video
HOOK UP INFORMATION
The cable should be on the Input to RF connector. Then you should reprogram tv for cable channels. If you have dvd then it should go to the inputs for 1/2/3 A/V inputs yellow for video, red for right audio and white for left audio. Color coded! Hope this helps!
Aug 31, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Durabrand DVD-1002 DVD Player Logo
172 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
