Question about HP LightScribe dvd640i (DVD640I) DVD±RW Dual Layer Burner
DVD/CD Drive Not Recognized
I have Vista (which I hate) and I have lost all recognition to my CD/DVD playing capability. Under "computer" I only show C and D disk drives...no CD/DVD drive. What to do?
  • RobSliter Dec 25, 2008
    I have the same problem and the registry editing fix did not work...
    Sergeant:
  • 264 Answers
This issue would be resolved with a simple step which i have provided below.
Click Start, click Run, type regedit and then click OK. Registry Editor starts.
In Registry Editor, expand My Computer, and then expand and open
HKEY_LOCAL_MACHINE>SYSTEM>CurrentControlSet>Control>Class
Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}
In the right pane (topic area), right click UpperFilter and delete the entry, also right click Lower Filter and delete the entry.
Close the Registry Editor and Restart the computer.
I am sure that this will work for you.
Please do rate the solution.
All The Best
Sammy
Posted on Oct 31, 2008
My cd drive does not recognise cds
Okay. First of all is it a cd drive in your computer as opposed to a DVD drive? If you put a dvd into a cd drive it cannot recognize the dvd. A dvd drive can recognize a cd, but a cd drive cannot recognise a dvd.
Does your computer actually recognize the drive as being present?
If the drive isn't recognized by the computer try:
power off the laptop
Physically remove the cd or dvd drive
power -up the laptop without the cd/dvd drive
power off the latop and refit the dvd/cd drive
power it up again and see if the drive is
recognized
If the drive IS recognized by the laptop but won't play any disk it's probably the drive itself at fault. You can try gently cleaning the inside of the drive - the optic that reads the disk. However, the usual cause is failure of that optic which read the disk information. It cannot be repaired.
The alternative to fitting a new drive is to buy a portable dvd drive. They connect via a usb cable. Have a look on Ebay
Dec 21, 2014 | Computers & Internet
HP dv6745 cd/dvd rom drive isn't recognized in dev. manger but is in my Bios
hi
take your OS CD , insert into CD bay-- when prompted to , select REPAIR
this will correct any corrupted registry errors that my be found in your OS, which is causing the lack of recognition for the CDROM driver
good luck
Jan 03, 2012 | HP Pavilion DV6745US Notebook
The cd drive isn't recognized. it was working fine but now it powers up and i can open tray but wen i try to use it the display says no cd drive. i tried another cd writer in it but same prob. help[!!
does it show up in the my computer? what OS you useing i.e XP / VISTA?
sounds like the drivers are missing.What kind of CD you putting in CD or DVD if it's a DVD try a CD & if it plays then the DVD heads have gone it's common for the DVD heads to go before the CD heads.
Sep 28, 2010 | Computers & Internet
Dvds are not recognized
hi h0tr0dh00dlu
if dvd's are not recognized
try to see if you dvd drive is shown in your os. double click My Computer to see.
Also checked if your disk drive is capable of playing dvd format.
I checked that Dell Dimension 4500 PC only comes with a bundle of cd-rw so dvd's can't be played
If not the best option is to buy a dvd drive @ http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=6463543&Sku=S203-8583%20OEM
Hope it helps, Feedbacks appreciated
Thx
Banaple
Sep 03, 2010 | Dell Dimension 4500 PC Desktop
DVD plays in DVD player is not seen at all by Windows XP
Hi,it's obvious from your problem that the particular disc that cannot be viewed on your computer is of a formatt not supported by the windows XP.some DVDs are of low quality which can be viewed practically on any DVD player but as a result of their low quality and the sensitivity of the Windows they are not recognized by your computer. In as much as other DVDS play on your computer,it means there's no problem with your computer,but an unsupported disc formatt is been trying to be viewed and there's nothing you can do to view a DVD formatt not supported by your computer.please don't be bothered.
Thanks and take care
Apr 21, 2010 | LG SecurDisc 20x Internal Double-Layer DVD...
I lost the drivers what can i do?
well you really don't need drivers for xp+ systems. it should automatically be recognized. you just have to get cd/dvd burning software like Nero.
according to this site that drive won't be recognized by vista with out a firmware update
http://www.cdfreaks.com/review/13311-LG-GSA-H42N-Super-Multi-DVD-Writer-Review/
Oct 13, 2009 | LG GSA-H42N 18x DVD RW DL IDE Drive...
No dvd rom recognition
Go to add hardware in control panel and manually install your drive,(follow the procedures), your drive should be configured automatically.
itJSN
Jul 28, 2008 | E-Machines emachines (emachinees) CD-ROM...
Dvd cd drive
Refer to http://support.microsoft.com/kb/891894 and try it out. Hope that solves the problem.
May 06, 2008 | NEC ND-6650A DVD RW Dual Layer Burner
DVD/CDRW drive not recognising any DVD's
Hi people!!
This fixed my problem. Give it a go, I have access and am using my burner once more.
Good luck!!
Alex
Note: The solution provided requires editing of the registry.
  1. To begin the process, start the Registry Editor.
    • Click Start, click Run, type regedit, and then click OK.
    • On Vista machines, Run is accessible through Accessories.
    • Click the plus sign (+) next to the following folders in the left side of the window pane:
    • HKEY_LOCAL_MACHINE
    • SYSTEM
    • CurrentControlSet
    • Control
    • Class
    • {4D36E965-E325-11CE-BFC1-08002BE10318}
  2. Look for any of the following names in the right side of the window pane:
    • UpperFilters
    • LowerFilters
  3. If any of the items above are listed, right-click on the item and select Delete.
  4. Be sure to restart your computer after you have deleted the files in the registry.
  5. Open My Computer (XP) or Computer (Vista) and check to see if your CD or DVD drives have returned.
  6. In some cases, you may need to reinstall some programs such as CD or DVD burning software, iTunes, or Nero
Mar 13, 2007 | Panasonic (UJDA750) CD-RW/DVD-ROM (Combo)...
HP LightScribe dvd640i (DVD640I) DVD±RW Dual Layer Burner Logo
317 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
