Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Frigidaire washer hot water only
No matter how I set my Frigidaire washer, only hot water gets in. For example, I set cold wash/cold rinse, it still runs hot wash/hot rinse. I have checked the water intake valve and found both sides (cold and hot water intakes) work appropriately when I put voltage directly to the solenoids. I am seeking suggestions about what else I should check. Thanks.
  • 1 more comment
  • oldmanpw15 Nov 01, 2008
    Thanks, aborcass. I also suspect the switch, but do not know how to test.
  • Anonymous Mar 16, 2014
    no water feed for main wash.e10 error code.The solenoid valve are ok.But theres no voltage at the main wash solenoid ,both wires are ok thanks for any help.
  • Anonymous Mar 22, 2014
    WHEN SET ON COLD WASH ONLY VERY HOT WATER COMES OUT
    President:
  • Whirlpool Master
  • 2,651 Answers
Sundsas if you have a bad temp select switch. only selecting hot/hot
Posted on Oct 31, 2008
Frigidaire Model # GLTF1670ASO rinse cycle is not working
ARE YOU WASHING IN COLD IF NOT YOUR WATER VALVE MAY BE BAD ONLY GIVING HOT CLOTHES WONT RINSE IN HOT
Jun 16, 2014 | Frigidaire ATF6000ES Front Load Washer
I believe the water temp switch is bad. It will start filling on warm then stop if I put it on hot it will fill with cold water. I have cut the hot water off to achieve this but when it reaches rinse it...
it sounds to me that the hoses are connected to the machine incorrectly. Typically if the plumber ran the water lines behind washer correctly the hot pipe is on the left and the cold pipe is on the right sometimes thats backward and be determined by touching hoses while filling on warm setting and see which hose feels hot. On the back of washer they where they connect hot goes on the bottom and cold on top
Aug 08, 2011 | Estate ETW4400VQ Top Load Washer
Washer will go thru the wash but always stops at
ck the cold water is on / ck the water valve . this would stop it in cycle . it can't get rinse water . maybe pc control but unlikley.mm
Dec 03, 2009 | Frigidaire ATF6000ES Front Load Washer
Hot water doesnt work, switch to warm and warm comes out.
If the cold works on cold wash but the hot don't work on hot wash . Then yes the switch is bad.give What model is it?
Jan 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
All cycles run cold
Hello
Welcome.
Faulty Water Inlet Valve
The water inlet valve is the device that meters water from the supply lines into your wash tub. On domestic washers, there are two lines, one hot the other cold. These valves are susceptible to mineral build-up and sediment deposits. There are two common failure modes:
Failure Mode One: Valve will not open.
If you can verify that the solenoid on the valve body is receiving the requisite voltage and the valve will not open, then it is faulty. Since the solenoids operate independently, it is likely that one side of the valve will work and the other will not. This can produce strand results such as a very hot wash when warm is selected (due to no cold water). Or the reverse in that the wash water is cold when warm is selected. If mineral or hard water deposits are a problem, you may witness a substantial increase in the time required for the tub to fill. This is caused be a decrease in the flow ware of the valve.
Failure Mode Two: Valve opens but will not close.
This is verified by a valve that allows water to flow into the tub even though no power is being supplied to the solenoid. This one is usually quickly diagnosed when the machine begins to overflow and the power plug for the washer is disconnected from the wall. However, this will not stop the water from flowing into the machine. The water must be shut off at the wall. As with the previous failure mode, the variant of this failure mode is that it may take the valve a while to completely bridge the flow of water after the power has been removed from the solenoid.
How to Diagnose?
There are a couple of ways to diagnose a faulty valve. However, there is a simple test that one can perform that will usually let you know if the water inlet valve is faulty.
Scenario:
When set to cold wash and rinse, the unit will not fill. When set to warm wash and cold rinse the washer will fill with hot water only and will fail to rinse. This is a common scenario where the cold water side of the valve does not appear to be contributing to the fill, but the hot water side does. This symptom could be easily reversed where cold water is being supplied, but never hot water.
So, how can the problem be determined? It is as simple as switching the wire harness plugs on the hot and cold side. In the example above where the cold water is never being supplied, the symptoms would be the opposite when the wiring harnesses were switched. So the machine would produce only produce cold when warm or hot is selected. No water should be present when you select cold. This verifies that the timer, wiring and switches are all in working order. Assuming this tests checks out, you simply need to replace the water inlet valve.
Recent Customer Symptoms:
I have a Kenmore Washing Machine. My question is if I set the washer on cold was and cold rinse it will not fill with water but if I set it on hot wash and cold rinse it will fill with Hot water and wash normally but when it comes to rinse with cold no water will fill and will go to the spin cycle assuming that it had filled with water. There is water in the cold water source. Any idea??? I was assuming the timer but not to sure.
Thank you , Huum
Please remember to leave a solved rating before you sign off !
Dec 12, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Maytag washer
It sounds like you have the hot and cold water lines to the washer reversed.  Try turning off the tap for the hot water then setting the washer to just cold wash and then  hot washif you get nothing on the cold and cold water when set to hot they are probably reversed.  Typically if the auto-temp control is broken you will only get hot or cold coming out on any setting.
Oct 01, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Hot water on cold water wash or rinse
hmmm..now that's really interesting..that's a function of the control board..methinks you have an error in the panel and control center.
Mar 09, 2008 | Kenmore 44072 Front Load Washer
Hot water rinse when cold rinse is selected
First off make sure your hoses in the rear are on correctly there is Stamp on the back of the unit H=hot C= Cold if that is ok we will need to look deeper let me know
Jan 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
611 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
