Question about Panasonic TX-15AT1 15" TV
No power Please help me.....my 16" panasonic had no power. when i check out the problem, found that horizontal ic (D1541)was short all three pin, and flyback transformer make a sound. But after i changed new horizontal ic, there's no sound of flyback transformer, and the tv on as per normal.....but after a few second, the horizontal ic was short again. what should i do now?
  • azhar mohammad Sep 19, 2006
    yes, you're so preety right.....i already changed a new FBT, and its work! Thank you....
    President:
  • 3,130 Answers
The D1541 is a horizontal output transistor, not an IC. Your problem is definatly a bad flyback transformer.
Posted on Sep 18, 2006
    Novelist:
    Champion:
  • 275 Answers
Check the FBT and the Horizontal Output Transistor also.
Where is horizontal output ic in my t.v?
There is no horizontal oscillator IC. The horizontal oscillation is generated and outputted by the main system control IC LA76810 itself. Refer some circuit diagrams using LA76810 to get more details about the horizontal oscillation output from the IC. Measure the frequency at that output pin. It should be some ever near 15.62KHz.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Type in the IC number, in the search box [at the top right] of the display window, and press enter to get all related posts. It will make surf easy.
Jan 31, 2015 | Televison & Video
Do not power on
Can you please inform us the model and brand of this unit..if the unit wont power on this can be a problem with the power supply or the power adapter ...
Aug 26, 2008 | Televison & Video
Why come white vertical line on my t.v screen in center?
You said "I checked vertical output line from main ic pin 23 found correct"
But the problem is "Horizontal Output Line" Try that.
Jan 29, 2015 | LG Televison & Video
UndefinedI've checked a Panasonic crt color tv model TC-21fj20p, and I find a hard way to discover the cause of the problem until now.. The set has a good primary voltage supply. No problem with the IC...
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Any short circuit at the horizontal output section circuit will shut down all the secondary SMPS voltages, as there is short circuit protection circuit to all Sony TVs.
Oct 28, 2014 | Televison & Video
I have a Alesis Model SR-16. It turns on for about 1 min. and then turns off .
I suspect that that part MAY be a three terminal power regulator. If it is, then there is probably a near short on the buss it supplies. A common problem is a shorted bypass cap. Without a schematic this can be hard to find.
y procedure is to reduce the power inout so nothing burns, then check power at each IC on the pins and find one that is near zero then look for shorted bypass cap nearby.
Nov 18, 2011 | Alesis Sr 16 Stereo Drum Machine
No vertical deflection, only a thin horizontal line.
Hi and welcome to FixYa,
A few ideas you may want to consider/explore;
  • While it is true that capacitors do dry out, the values that you posted (22uF & 32uF) are relatively low for the pump/boost capacitor which is responsible for the "top of the picture was a couple of inches short". Normally this should be around 100uF connected between pin8 & pin 12 of LA7836;
  • agree that the Vertical IC LA7836 is busted hence the single line;
  • in most vertical designs, there would be a diode from pin7 that goes to pin12 that needs looking into for a leak;
  • pin7 is the Vert B+ ~ 24VDC while pin1 is secondary B+ 9 ~ 12 VDC. In some designs to accomplish this, there is a dropping resistor from pin 7 to pin 1 and sometimes a zener diode from pin1 to GND parallel with a filter capacitor;
  • pin11 is the vertical output that goes to the yoke. From the yoke some design uses another capacitor (about 1000uF) before going to the ground through a low resistor (~ 1 ohm);
  • above mentioned parts need to be checked out of ciruit preferable and special attention to possible leaks of the diode when testing in reverse bias mode.
Good luck and thank you for using FixYa.
Jan 30, 2009 | Panasonic CT25G7 25" TV
Phillips Magnavox 60" model ptv835
Recently had same issue and after EXTENSIVE SEARCHING found all three ICs and replaced them. TV works perfectly, also, replaced convergence ICs at same time. The one 16-pin IC for the regulation ckt. is $49.95 the other 16-pin IC is $19.95 and the 8-pin opto is about $10. This price is for a minimum qty. and must have a business for quote.
Aug 29, 2008 | Philips Magnavox 9P6034C 60" Rear...
ABOUT PHILIPS TELEVISION
The 8V at pin 36 won't show unless there is oscillation, the primary voltage pin is pin 10, 8v. Don't mind me asking, you have checked the B+, right? Because the blinking LED is often because of power supply problems. And if that's okay, desolder the horizontal driver output legs and connect an LED to find if it is oscillating, if it does, forget the ic part and move on with the FBT and things. Good luck.
Jan 31, 2008 | Televison & Video
Sony dav-sc5 power problem
it is power regulator ic and must be changed.
you must check around ic pins for short capacitor or burnt resistor to complete your job
Nov 01, 2007 | Sony DAV-SC5 System
Help on monitor repair
Have you checked the horizontal output transistor for a short or leakage?? most of these sets will not start up unless the horizontal sweep sends the pulse to the power supply and says start me up!! I would look at bthe drive as well on the horiz. curcuit. If theres a pulsating voltage that means its waiting for something to signal it to work or its missing something.. Good luck
Apr 17, 2006 | AcerView 78ie 17" CRT Monitor
Panasonic TX-15AT1 15" TV Logo
227 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
