Question about Kenmore 62702 Microwave Oven
Microwave turntable makes noise
Microwave turntable makes rumbling noise. I wonder if turn table motor is bad.
Is it hard to replace the motor?
  • p25829 Nov 01, 2008
    Thanks very much for your reply.
    Can I find the motor at Home depot or Lowes?
    Where is a good place to find the part?
  • 67 Answers
Yes motor may be bad or something is stuck . its not difficult to change .it is located at the bottom and has a wire connector with 2 spade clips
Posted on Oct 31, 2008
  • 2 more comments
  • raj anthony persaud Nov 01, 2008
    almost any electrical or electronic store should sell this motor.i forgot to mention only one screw holds the motor in should also check that ring with three wheels that the platter rolls on for wearing.
  • Mirko Jun 16, 2013
    I replaced motor to eliminate rumbling noise but turn table does not turn?
    Everithing else is working good except turn table.
    what is the problem?
GE Spacemaker XL1800 Microwave
see for the turn table obstacle of any screw or something else.
Aug 04, 2008 | Samsung MW1030WA Microwave Oven
Turn table wont turn
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
In some brands, you have to cut the motor cover off with snips, then use a screw when reassembling it.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Dec 05, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
Change Motor but turn table does not turning?
test the following steps and fix it. God bless you
Turntable Motor
If the microwave turntable doesn't turn the turntable motor might be worn out. This is a common problem and relatively easy to replace.
Touchpad and Control Panel
If the microwave turntable doesn't turn the touchpad and control panel might be defective. This is not common. Test the turntable motor first.
If the microwave turntable doesn't turn and the touchpad has a button to turn the turntable on and off the touchpad might be defective. Check the turntable motor first, that is more likely.
User Control and Display Board
If the microwave turntable doesn't turn the turntable motor might be worn out. This is a common problem and relatively easy to replace. If the motor is good, the user control and display board may be defective.
Main Control Board
If the microwave turntable doesn't turn the turntable motor is usually the problem. If the motor is good the main control board might be defective
Jun 16, 2013 | Microwave Ovens
Turn table makes grinding noise
Hi, The motor that turns the turntable is bad...Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
Sep 25, 2011 | Magic Chef MCD1311ST Microwave Oven
Maytag Microwave 1150 Help
Check first the motor coupling under the turntable, if that is not the problem , then test and eventually replace the turntable motor.
Click here and select model to get parts and diagrams.
Apr 05, 2009 | Maytag MMV4205 Microwave Oven
Microwave turntable makes a noise
Just dont listen to Mr Miller. He rambles way off subject and will say anything to feel like he is special.
All it takes is very fist sentence where he suggests it could be magnetron bad. Geee, if that were the case your microwave wouldnt heat/cook so you wouldnt be here having a noise problem would you? Its kinda like the mechanic saying your noisy brakes could be caused by a empty gas tank.
Cause? - could be motor that operates turntable going bad, food or something lodged anywhere in moving parts of turntable operation which includes unseen area, or moving part that is been somehow bent or moved (unlikely without impact to microwave or previous work done possibly leaving something loose).
Solution? - I am ignorant of specific assembly of your microwave but on many you can access motor from bottom (unplug microwave first) and replace motor yourself if you are somewhat mechanical. The cheapest easiest 1st step would be clean very well around all parts and even clean any debris you find when taken apart, then recover and turn on to see. Not the likliest but its cheap and easy and you have to take apart bottom to replace motor anyway so not really much extra work.
Mar 30, 2009 | Kenmore 62702 Microwave Oven
Turntables doesn't work and makes horrible noise
Replace turntable motor. Not really that hard to replace or expensive. Remove all screws holding bottom panel (usually three across each side and one to three in front) to gain access to the turntable motor. The panel will hinge in the back.
Jun 01, 2008 | Frigidaire PLMV168 Microwave Oven
GE Spacemaker XL 1800 - turntable issues
check capacitor and motor drive of turn table.
Jan 03, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Kenmore 62702 Microwave Oven Logo
1,736 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
