Question about NEC Versa FX Notebook
Need a repair menu on Versa FX
Need to do a self repair on the broken screen. Not too sure how to take off the lid case and screen. Anyone has the repair manual?
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 19 Answers
Here is an article from ComputerShopper magazine that will be of help to you. http://computershopper.com/howto/200701_replace_your_laptop_screen Best regards, torgo
Posted on May 11, 2007
When i open laptop screen beyond 70 degree angle screen blanks out i then have to close d completly then re open lid making sure ot to exceed 70 degree angle
I suspect a broken wire feeding the screen.
Either take it to a computer repair centre or remove the case and check it out for yourself as it may be a plug not making good contact.
Be careful if you do!
Jan 16, 2011 | Advent Computers & Internet
My nec versa e6300 is shutting off every time im watching a streaming vide from the net, i guess its due to overheating. i think it needs cleaning at the cpu fan but i cant open the casing despite having...
im having this same problem, its also happens when im playing new games such as dead rising 2, 007 Bloodstone, Prince Of Persia 4 etc.. if anyone knows where to find a manual or instructions for step by step dis-assembly, can they email it to me please? juggaluggaroney@hotmail.com
Nov 03, 2010 | NEC Versa FX Notebook
L can't boot xp from my cd rom in nec versa 680
need to change the boot seq in BIOS....
u need to press one of the foll...
DEL, F1, Esc, key etc as the case may be...immediatly after switching on the PC....
once u r in BIOS screen look for "Boot Seq" in one of the BIOS setup screens....
change the boot seq to CD ROM as 1st boot device...and HDD to 2nd boot device...
press F10 or choose BIOS "save and exit " option....
insert the XP cd...switch off and switch on...it should now boot from CD....
all the best....pls revert back...pls give a rating and feedback for this advice....thanks
Sep 27, 2010 | NEC Versa FX Notebook
The machine now stops before spin cycle and it needs to be shaken in order to start it back up - is the macine off balance or does it need a new part?
The most common cause of the problem you just described is a lid switch malfunction or lid strike (actuator) problem. Symptoms may include, filling and stopping on the intial fill cycle, stopping right after the wash cycle, not advancing to rinse or spin cycles, and a wash tub that will not drain.
NOTE: If the washer works intermittently by shaking it, it sounds like you have a loose or broken switch.
The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike" or "Actuator") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
On some models, the lid switch is located under the top casing by one of the lid hinges. You will know if you if you have this type of switch, because it does NOT have a lid strike (actuator) and the small hole on the right hand side of the wash tub will not be present. This type of switch is actuated (toggled) by a rod on the lid hinge. With this type of switch, if you locate it and it can be toggled by hand, you may only need to adjust the actuator rod by bending it slightly.
NOTE: You do not have to drain or bail the water from the washer tub to perform this repair. Once a defective lid switch is replaced, the washer should drain normally.
Replacement parts (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The average price of a replacement lid switch for this model washer is about $15 - $20 if you perform the repair yourself. Prices will vary between sites so shop and compare. If you have questions, or need additional assistance, please post back and let me know. This is a very simple repair that you can easily perform without the assistance of a repairman.
NOTE: Whirlpool manufactured washers have a self-leveling assembly for the rear feet that can become unleveled if the washer is shaken violently. The process to re-level the washer is simple. The following link explains how:
http://www.fixya.com/support/r3868923-level_whirlpool_top_loading_washer
If this advice does not help you enough, repairclinic.com has a Repair Manual you can order to assist you with all your repairs. The part number is 1170635 and is priced at about $20.
Searspartsdirect.com also has a repair manual for about the same price. Part number 4314044L. I hope this information is helpful to you.
Jul 12, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore elite not spinning
This issue is caused by:
- Lid open. Be sure the lid is correctly closed
- Lid switch broken. It may need to be replaced.
- Motor broken. QUite expensive repair, the motor needs to be replaced.
- Timer broken.
Check the lid is correctly closed, perhaps the lid switch is having some failures.
Nov 05, 2009 | Kenmore Washing Machines
I lost all my driver for nec versa e680...anyone can help me???
Simple, search google for "nec versa e680 drivers download", you should be able to find it!
Jul 03, 2009 | NEC Versa FX Notebook
Perect phone/broken plexi screen
If you can't get a replacement under warranty there is both an T-Mobile G1 Repair Guide and a third party T-Mobile G1 Repair Service, If you try a self-repair make sure you feel comfortable with opening devices like that.
Jan 07, 2009 | HTC G1 Smartphone
Machine stops mid cycle and does not drain. machine is whirlpool AWM6100/S
If your symptoms are:
1. Washer fills
2. Washer agitates.
3. When washer gets to spin cycle, it stops.
This is a common symptom of a defective lid switch. If you try opening and closing the lid and do not hear a distinctive "clicking" sound, your lid switch may need to be replaced. Some lid switches are located on the right-hand side of the lid opening with a small slot. It is activated by a plastic piece called a “lid strike” on the lid itself. Make sure the lid strike is not broken off. This will keep the switch from not working. On some model washers the lid switch is located on the left-hand side, in the rear, mounted under the casing near the lid hinge. It is activated by a rod on the lid hinge. Sometimes the rod can be adjusted if it is not making good contact with the switch. In either case, if the switch is not activated, it will allow the washer to fill and maybe agitate, but will not start the rinse or drain cycles. If you diagnose it and wish to attempt the repair yourself, the switch costs about $35 and can usually be found at either repairclinic.com, or searspartsdirect.com. Just type in your COMPLETE model number (located around the lid opening) in the Search menu.
I hope you find this helpful. If you have any questions please let me know by posting comments.
Apr 17, 2008 | Washing Machines
Lcd screen broken C530
I FOUND A GUY THAT USES NAME BRAND LCDS AND REPAIRS OR SELLS YOU THE LCDS NEW, AND THERE CHEAPER THEN ANYONE IVE FOUND, HE HAS REPAIR 3 FOR ME SO FAR. IF YOU CAN DO IT YOUR SELF YOU CAN SAVE 20-30 CAUSE THATS WHAT HIS LABOR COST IS PLUS FREE SHIPPING. http://j2agent.googlepages.com
Oct 27, 2007 | Kodak EasyShare C315 Digital Camera
Dell inspiron 1100 booting problem
Motherboard or power supply is toast. A factory authorized repair center should look at it. Good lUck
Sep 09, 2007 | NEC Versa (808-895500-001A) Drive Case
NEC Versa FX Notebook Logo
73 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
