Question about HP Compaq nx5000 Notebook
Hp compaq nx5000 pc notebook - screen problems
The problem I have is that the computer goes on, the screen lights up but nothing else. I plugged in the monitor of my desktop and still nothing. This makes me think that the problem is not the screen but something else. Through what mechanism are the images transferred from where in the hard drive to the screen. Maybe that is what is faulty. If that is so, how else do I test it and how do I fix it. Thank you very much, Baronise
My screen is black. But I can see the desktop if I look very closely any ideas? how to fix this
LCDs have a light that illuminates the screen. You need a new LCD as the bulbs are not replaceable. I'd buy a new computer instead.
Aug 12, 2010 | HP Compaq nx5000 Notebook
Compaq nx5000 PC Notebook: my compaq nx5000 is notpowering up when i power it...
First check to ensure the battery is properly seated. If it's in good, then this is probably a power supply issue or a problem with the motherboard.
May 06, 2010 | HP Compaq nx5000 Notebook
Compaq nx5000 with new battery and new power
Dear,
Try pressing the CAPS LOCK. If CAPS LOCK is responding then it is surely your inverter.
It is a known problem with the nx5000 series laptop.
The FAN switches off because Intel SpeedStep which is absolutely normal.
I faced and solved at least 6 - 7 such problems on different nx5000 laptops
If CAPS LOCK is not responding then its your motherboard.
Good Luck and Regards
Nov 25, 2009 | HP Compaq nx5000 Notebook
Problem turning on/keeping on computer
has the ram been upgraded?
sometimes the wrong ram will do that ,
if not, could be motherboard issue
Jul 19, 2009 | HP Compaq nx5000 Notebook
Compaq nx5000 - will not power up. DIsk spins, green lights for a second , then powers down to only yellow light. SOmetimes - seems after long periods of no use - -powers up and runs. Have sourced new...
I just got my nx5000 up and running again. The memory needed to be reseated in the socket (got this tip of the HP site) All I did was open it up and reseat the ram - just took it out and put it back in again. Problem solved. I also took the opportunity to vacuum a little bit of dust out, but I don't think this was anything to do with the problem.
Get a copy of the service manual (Just google "hp service manual nx5000") it has easy instructions at how to get to the memory - it is just under the keyboard.
Hope this helps!
Dec 10, 2008 | HP Compaq nx5000 Notebook
Problem of VGA for my pc Hp compaq nx5000
run the setup of vga driver present on your cd
Oct 13, 2008 | HP Compaq nx5000 Notebook
HP Compaq nx5000 PC Notebook Problem
go to www.hp.com and get the required driver after selecting your model.
Apr 18, 2008 | HP Compaq nx5000 Notebook
HP Compaq nx5000
Here are your drivers
Please vote if you found this information helpful.
Thank You
Compaq nx5000 startup trouble
Atleast you need a dummy battery on it,put the battery on it and check , one more way is remove the ram and fix
Mar 13, 2008 | HP Compaq nx5000 Notebook
HP Compaq nx5000 Notebook Logo
156 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
