Back to:
Tags:
Vtech 8870KL ATX Mid-Tower PC Micro ATX Mid-Tower Case
Fan noise
posted by clockwise on Sep 18, 2006
I find that the side mounted fan is noisy in my new PC with 8870LK case.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Nov 26, 2006
Helpful (85)
tomj23
Rank:Guru Guru
Rating: 86%, 1561 votes
Generally fans on lower end cases are fairly cheap. I've had several new ones that make lots of noise new. You can call the manufacturers tech support and mess around tryig to get a replacemet or you can just order an inexpensive replacement fan. Cyberguys is where I typically buy my replacements.
http://www.cyberguys.com/templates/searc...
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Fan noise:
I don't want to Accept this solution
Solution #2
posted on Apr 30, 2008
Not Rated (0)
gaucherre
Rank:Apprentice Apprentice
Rating: 89%, 4 votes
Make sure the computer is sitting perfectly level. Wife's Dell computer was a bit noisy. I noticed it was on a shelf that was leaning a bit sideways. So I moved it and checked it with a small spirit level. Now it is running very quietly.
Thank You!
Solution #3
posted on May 04, 2007
Not Rated (0)
begbennett
Rank:Guide Guide
Rating: 81%, 20 votes
is it the fan or do the fan just raddle in the case
Thank You!
Can you Help with these PC Cases problems?
PC Cases
LED would indicate activity previously.Now only power LED...
PC Cases
my computer screen is flashing,it does not show at all.so...
PC Cases
EHT & EHT cable is sparking
PC Cases
need driver can you help?
PC Cases
The user will enter a number using forloop then it will...
Loading problems.
Repair Service
Find PC Case Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
