Question about Acer Aspire 5600 Series 5630-6951 Laptop
Acer laptop will not turn on
My acer laptop will not turn on.....i have plugged the charger but the battery indicator does light anymore.....memory was upgraded to 2gb last august....
    Scholar:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 47 Answers
Try removing the extra RAM, if this fails, check the chaeger with a voltmeter and an oscilloscope if you have one, if this fails, check the jack on the laptop, and if that's in good shape, then it is likely the board was subject to static when the new RAM was installed or it failed of its own accord, either way, the system will probably need a new motherboard, or it may need a CPU, but even if the CPU was toast, the charging LEDs would light so it is very likely to be the mobo
Posted on Jan 26, 2013
  • 41 Answers
Don't think the memory upgrade would cause the power circuit to fault?
It might be your charger - in the transformer circuit block?
Hope this helps.
Posted on Oct 31, 2008
Acer Aspire 4830T laptop battery behaving vaguely
Do you still have the old battery. If so charge it, and see if it charges properly. If so then you have a bad battery.
Mar 18, 2017 | Acer Aspire Timeline X 4830T 14 Inch...
Having trouble keeping a charge going to Acer TravelMate 350
Remove the battery and try to run ur laptop with the charger connected to it....If it runs then it might be battery problem....
Dec 23, 2013 | Acer TravelMate 350 Laptop Charger...
I have a 4-year-old HP Compaq Presario CQ60. Last night it shut itself down, due to low power, even though the charger was plugged in. Now, when the charger is plugged in the power supply indicator light...
It looks as if the LED code would indicate a memory issue. Three blinks in a row.
Turn the laptop over, remove the panel over the RAM, remove the DIMMs (it will likely have 2 in it), place one in at a time and try powering the system on.
One of the two is likely bad although it is possible (although very unlikely) that both are bad. It should boot up when the good DIMM is in place. Once you have identified the bad one, buy a replacement or possible choose to upgrade the total amount of RAM.
Jan 04, 2013 | Computers & Internet
My acer aspire one mini laptop won't turn on when i charge it. the orange light does'nt come on and i last used it about a week ago,and it hibernated because of low battery. iv'e had my laptop for about...
Remove the main battery and power supply charger adapter from the laptop, wait a few minute to get rid of any residual charge, now install the battery, power up! if no change remove battery, next plug the power supply back in, power on, if yes! the main battery is bad and needs replacement. If no change reply to this message so I can help you further. If you having low memory issues, the ram needs to be upgraded.
Jan 12, 2011 | Acer Aspire One Netbook 8.9" Notebook
Hi i have a acer aspire 5100-5674 laptop, i was using the computer when i saw the orange light meaning low battery, my computer was plugged in however... the next minute i know everything got turned off...
The first step is to check both the charger and the battery at a shop. If both are good then it could be a connector problem where the charger plugs in
Aug 16, 2010 | Acer Aspire 5500 5570-2609 Laptop
Acer aspire laptop won't charge
First of all you have to determine whether it's the battery, charger or the laptop itself.
Remove the battery and boot the laptop on AC power only, if the laptop boots up you can rule out the charger and the laptop, you may need a new battery if that is the case.
Regards.
Sep 08, 2009 | Acer Aspire 4520-5582 Notebook
Laptop Charger will only work is laptop is turned off.
it sounds like the charger does not have sufficient wattage for your machine. i would try getting a certified acer power supply.
Aug 14, 2009 | Umax ActionBook 333T Notebook
Wont recover from sleep mode after depleted battery
plug out the batter and give the AC. turn it up. any light? if you dont have you have a problem with Mainboard that doesnt let the electircitiy goes in.
of course i am assuming your adapter is working :)
May 30, 2009 | Acer Computers & Internet
I CANNOT OPEN!!!
Hi, Try running you laptop with the battery and the AC adapter. If by plugging in your adapter there is no light indicator likewise or no powering up, then presumably there is a problem with the power supply circuitry in the motherboard. Normally the laptop should work with just the adapter, just the battery or both the battery and the adapter. If it will not perhaps your best bet is to seek professional repair service since this would require opening the motherboard. In most instances, this involves an smc fusible link, regulator transistors or even just cold solder or loose connections. Hope this be of some help/idea. post back how things turned up or should you need further information. Good luck and kind regards.
Sep 24, 2007 | Acer Aspire 5500 5570-2609 Laptop
Acer Aspire 5600 Series 5630-6951 Laptop Logo
57 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
