Question about Power Acoustik A3000DB Car Audio Amplifier
Internal capacitors keep burning
Had the amp approx. 1year from new, recently about 2weeks ago, internal capacitors burned but amp was still working, replaced capacitors but it occurred again. Want to know what other components i should check for damage and cause.
  • 67 Answers
Youre overloading the output reduce to at least 4 ohms impedence speakers
Posted on Oct 31, 2008
I have a Yamaha RX-V630 Amp/Tuner. It recently blew or burned up another capacitor. Second time in about 4 years. What coukd possibly be making this amp do that. It was professionally installed. Both...
Electrolytic capacitors are known to fail due to heat over time, as they will dry out. Depending upon cost of replacement, and if you are happy with the amp (repaired), consider repair. Repair service should check voltages to ensure circuit is working properly.
If a ceramic or tantalum capacitor, look at the circuit parameters. Check the other capacitors nearby for signs of failure.
Mar 21, 2015 | Yamaha Audio Players & Recorders
Hayward 3/4 hp pool pump keeps burning up
check wiring if ok check voltage if capacitors keep blowing high draw on motor replace whole pump
Apr 07, 2014 | Hayward Pool & Spa
Model number is JVM1740SP1SS is not heating the food
If the magnetron was making louder noises prior then replace the magnetron. While the cabinet is open make sure to look for burned wires, check the continuity of thermal cutoffs, and check the main circuit-board for burned traces or components. The relays in most electronics are known for arcing (spot welding) and staying in the wrong position. Tap them hard with the back end of a screwdriver. During all of this use safe electrical practices by having the power cord unplugged. The capacitor could still have a high charge on it so be careful.
Nov 29, 2013 | GE XL1800 1100 Watts Microwave Oven
I have an Ingersoll Rand 80 gallon, 5 hp compressor. The motor recently burned up and I replaced it with a new one about 1 1/2 weeks ago. The new motor now has burned up also. Could there be a problem with...
Yes it could be running (turning) hard which will make the motor pull high amps. If you installa new motor make sure to check the amps while running to be sure that the draw is not over the name plate spec. Could also be that you just got a bad motor... believe me it happens more often then you would think...
I am assuming that you have checked the oil in the compressor and that the level is okay...
Heatman101
Feb 26, 2010 | Ingersoll Rand Compressors 5-HP,...
Weatherking 3 ton Run Capacitor
Could be; age,lightning,power surge,defective wire,loose wire,tight compressor. Capacitors fail sooner or later. They are like batteries they do not last for ever.
Aug 04, 2009 | Weather King Heating & Cooling
Lasko 3723 burnt motor
sorry but you need to purchase a new fan.
some times the motor is not aline correctly and the rotor "part that spins the blade" rubs on the stator "the part with the copper wire:" the motor
over heat with the friction, then smoke followed by the coil burning.
Jun 14, 2009 | Lasko 3723 Floor / Box Fan
Sony xm
internal heat capacitor or even a bad connection indside amp is bad giving you a hi output load wich the amp has an auto matic sensor to send it into this offset you speak of so it does not burn up
Sep 22, 2008 | Sony XM-1502SX Car Audio Amplifier
Hp dvd writer 640c
hai it is not drivers problem. while burning normal cd you should select cd in the check box given on the top the screen .you should select the option cd or cd/dvd then you try burn it will work
Aug 31, 2007 | HP Media Center m7250n (ED842AA) PC...
Power Acoustik A3000DB Car Audio Amplifier Logo
208 people viewed this question
Top Power Acoustik Car Audio & Video Experts
Tygh Duval
Tygh Duval
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
