Question about Canon NP 6545 Copier
Replace drum cleaning blade
Hello, how do you remove the drum from the main body in order to replace the cleaning blade.
in addition where can I acquire a service manual for Canon np 6545.
thanks.
  • 168 Answers
Take the toner hopper off take dev unit out lower handle on umber one unit remove screw in drum pin remove primary charge assy remove screw lower right of drum frame remove screw upper left frame un plug connectors unit slides out
Posted on Dec 08, 2008
There is a Black line on the Ricoh Aficio 3045 Drum Help for Remove ????
if you can clean the black line with a cloth, than you need just to replace the cleaning blade, but if the black line is not removing without a cloth, then you need to replace the opc drum and the cleaning blade or both blades, some machines of this type have only one cleaning blade but some have two cleaning blade.
Sep 28, 2016 | Ricoh Aficio Office Equipment & Supplies
Model ar5516. Why is drum not cleaning?
Sir,
Did you prime the cleaning blade with toner when you installed it?, and did you ensure the new cleaning blade did not flip!!!!, re-check the new installed cleaning blade, place a small amount of toner from the toner bottle on the drum along the whole drum. and using your hands at both end of the drum DO NOT TOUCH THE DRUM" turn just a 1/4" CCW (To ensure the cleaning blade is set) then CW to see if the toner is removed. your drum might need to be replaced and or the fuser unit have a example of the copy?
Dec 28, 2015 | Sharp Office Equipment & Supplies
Error code F 26-3 on Konica 7022
Sir/mam, you might have a bad drum density sensor or it was not cleaned or was destroyed by static electricity, if a vacuum cleaner was use to remove the old developer, NEVER use a vacuum cleaner for that procedure. Remove the drum and will see a small sensor near where the cleaning blade sits need to clean it replace it. Worse case the main control board is bad that what sensor talks to .Was the L Detect procedure run after the developer was replaced, and before you replaced the developer did you clear the developer counter, to let machine know it has new developer, because clearing the counter is the only way the copier has new developer, did you clear the counter for the new drum? The machine use the counters to determine voltages for certain assemblies. If L detect was not run and copies or prints where made get new developer and start over.
Jul 12, 2014 | Konica Minolta 7020 7022 7025 Copier Drum...
Where is location of cleaning blade drum minolta 4000 copier
Remove the drum unit/cartridge once done remove the (BE CARE REMOVE DRUM BY PUSHING UNDERNEATH FROM THE END NO FIIGERS MUST TOUCH THE DRUM BE CAREFUL NO NICKING IT EITHER) drum you will see the cleaning blade on your left of just where the drum came out if it is yellow looking replace it. When you replace it make sure you prime it with some toner out of the toner bottle. use a brush on the inside of the blade entire length also prime drum area entire length that is going to make contact with blade intialiy then once the drum is in turn the drum backs wards just a little (This will prevent the blade form FLIPPING! not good then turn the drum toward the right until it comes full circle and all the toner is removed from the entire drum
Jan 29, 2014 | Minolta EP4000/5000 CS/PRO Copier
My problem is , to many black lines in image in aficio 2045
the black lines ( narrow ones ) can occure because of worn out charge roller and drum cleaning blade.
First of all You need to replace drum, drum cleaning blade and clean the charge primary roller or replace it.Also if the times was came for drum section, repace also the developer and do the preventive maintenace on copier.
Call service!
Hope that helps!
Sep 10, 2011 | Ricoh Aficio 450 Copier
Can a scratch be removed on the drum that gives a black line on the print. While cleaning the machine something touch the drum and created a line. TOSHIBA STUDIO 160
Hello
Unfortunately the scratch on the drum cannot be removed, as the drum is a organic material.
The drum and drum cleaning blade will have to be replaced.
Regards
May 09, 2011 | Toshiba e-Studio 161 Copier Copier
How to replace copier drum Cleaning Blade UCLEZ0069FCZZ
Improper installation may damage the copier. Before disassembly, be sure to disconnect the power cord for safety. 1) Remove the drum cover. (4 Lock Tabs.)
2) Remove the drum fixing plate and the photo conductor drum.
•Dispose the drum fixing plate which was removed.
3) Check the cleaning blade and the red felt for damage.
•If there is damage, go to step 5
•If there is no damage, go to step 12
4) Remove the main charger. (Cleaning the screen grid and the sawteeth.)
5) Remove the cleaning blade.
•Dispose the cleaning blade which was removed.
6) Clean the cleaning section and the waste toner pipe to remove waste toner completely with a vacuum cleaner.
7) Remove the felt and duplex tape completely.
•Be careful not to scratch or bend the sub blade.
8) Attach the cleaning blade.
•Securely insert the plate section of the cleaning blade into the unit and fix it with a screw.
•Do not touch the cleaning blade rubber with your hand.
•When attaching the cleaning blade, press the cleaning blade in the arrow direction and attach.
9) Attach the felt.
•Attach the mocket with slightly pressing section A of the cleaning blade.
•Do not touch the tip of the cleaning blade.
•Do not put the mocket under the cleaning blade.
•Do not put the mocket on the sub blade.
•Do not press the sub blade with the mocket.
10) Attach the main charger.
•Securely set the MC holder on the projection of the process frame.
•Securely insert two projections of the MC holder into the groove in the process frame.
•When attaching the MC holder assembly, be careful not to make contact with the cleaning blade.
11) attach the drum fixing plate and the photoconductor drum. Apply grease to the inside of the photoconductor drum. (Diagram 2)
•Attach the drum from (b). (Prevention against the sub blade edge breakage)
•Attach the drum so that its position with the sub blade shown
12) Attach the detection gear.
•The detection gear is not installed to the drum cartridge package with the main body. Add a new one.
13) Attach the drum cover.
•After attaching the drum cover, do no make a copy
•When attaching the drum cover, engage the detection gear 20T rib with the 30T gear rib, and attach the drum to the process frame.)
14) Important.
•Insure proper drum rotation by rotating the drum counter-clockwise (as viewed from the front)
•If the drum does not rotate with reasonable effort the drum blade may need to be re-positioned or lubricated with a small amount of toner.
Dec 16, 2010 | Sharp Office Equipment & Supplies
NEW DRUM
joe, to replace the drum, you need to remove the cover from the front of the drum unit it has three locking tabs,one removed,take main charger/grid unit out,located on the top of drum unit,two screws one on each end. the drum is held in with a cam lock shaft located on the front of the drum unit,turn it couter clockwise,your drum can now be removed,it's recomended that you replace the cleaning blade also,two scews. you'll have to coat the new drum with toner and manually turn it against the new cleanig blade,if you dont the blade may flip and ruin your new drum.reassemble
May 01, 2008 | Toshiba e-Studio162D Copier
Need to replace the drum cleaning brush how do I get it out????
The drum cleaning blade removal is pretty straight forward.
1. Remove the charge unit above the drum.
2. Remove the cover that sits above the cleaning blade.
3. Release the pressure spring at front of drum unit.
4. Remove 1 screw (front side of blade at top) holding blade in place.
I noticed that you had also had a E3-40 code previously. If toner is dropping on to your copies, the toner support blade will also have to be replaced.
Jan 31, 2008 | Panasonic FP-7735 Black and White Copier
Canon NP 6545 Copier Logo
295 people viewed this question
old marine
old marine
