I have a whirlpool gold quiet partner IV and it is four yrs old. About a week ago, it was no longer 'quiet'. It is running really loud. Could the motor be burning out already??
Could be something as simple as something caught in the food disposer blades. Remove the lower spray arm and filter assembly. There is a cover inside the sump that is removed and once you remove it, you will have access to the food disposer blades and pump impeller.
hello. I have a whirlpool gu1500xtlq2. the console is replaced and still doing the same thing. I...
(More)
hello. I have a whirlpool gu1500xtlq2. the console is replaced and still doing the same thing. I reset the power and it starts for 10 seconds and shuts off flashing the '' - - '' sign. My repairman seems baffled and thinks it's probably the motor and too expensive to replace. I think I could do it but how can I troubleshoot for sure? Do you have any links to help me replace this motor?
wont start. double dashes in display. checked switches and they are good. the rinse only light...
(More)
wont start. double dashes in display. checked switches and they are good. the rinse only light blinks too. tripped breaker for 30 min. same results. Number is actuatly GU1500XTL83. Serial# FR1011628
Dishwasher does not come on. Light next to "normal" wash button is flashing and 2...
(More)
Dishwasher does not come on. Light next to "normal" wash button is flashing and 2 horizontal lines light up in "time remaining". Pressing any other buttons, including the cancel button does not change the situation. I even tried flipping the circuit breaker off and then back on again to reset it. Normal light still flashes and d/w does not work.
I have a Whirlpool dishwasher GU1500XTL53 that has a sensing problem. When I start in...
(More)
I have a Whirlpool dishwasher GU1500XTL53 that has a sensing problem. When I start in "normal" or "antibacterial" the sensing light turns on and the unit constantly runs without a number showing up on the time left. Is there any fix to this? Thank you
