Question about Nikon D50 Digital Camera
Flash out of sync
When I am taking picture in full auto mode, the flash is going off too early and the pictures are turning out very dark. There doesn't seem to be a setting to control the flash in this mode. Please help!
  • Allyn Thomas Jan 31, 2007
    I took my camera in to get it fixed by Nikon (thankfully under warranty) and was told that apparently there was a bad batch of flash circuitry that went out with some D50's. It looks like it is becoming a known issue.
Hi i did the fix and it worked thanks  i think that the problem is not the flash it is the software  and nikon dose not want to give us any FW update
Posted on Jan 18, 2009
The fix above worked for me, it just started working again. Wierd, I have an sb-600 flash on order anyway.
Cheers for the help. I am going to send this page to nikon technical support.
Paul
Posted on Dec 05, 2007
Paul
I got on to nikon with the same problem flash out of sync an auto mode they said it was a flash malfunction i would have to have it repaired they also said there was no bad batch of d50s produced ever, anyone got a comment on that
Posted on Dec 01, 2007
It is a BAD camera! send it back. Nikon will fix them. I have to send my D50 to them this week.
Posted on May 29, 2007
Tried the Manual mode, AF, AF illum, ISO fix on my D50 but it didn't make any difference. I went out and bought a Nikon SB400 flash unit. That took care of the problem. mplsman50
Posted on Apr 01, 2007
I just had mine fixed by nikon and it seems as though the problem would come back every now and then. my current solution is to switch over to Manual mode and turn AF assist, AF illumination, and ISO control to "ON" and then then shoot a few shots. Then switch metering to centerweight. take a few shots, it should work correctly, then switch back to AUTO. after that, the flash should fire as normal. I just received my body back about 2 weeks ago, so i hope my "bad batch" flash unit was replaced with a known good one. if not, i don't know what to do.
Posted on Feb 19, 2007
SOURCE:
My Canon EOS rebel t3i's flash isn't working properly. It will flash, wait a second, then take the picture, making it come out very dark or completely black since the flash happens so early and I'm at
The multiple flashes are the camera attempting to autofocus on a subject that is too dark - it is trying to compensate for underexposure. Are you taking photos outside at night? Another thing to check is your lens. It is possible you have a poor connection between your lens and the camera which may be interfering with the focus and exposure (aperture) setting by the camera. Take and alcohol pad and wipe the contacts on both the lens and the camera body and dry them thoroughly with a lint free cloth. I have seen the oils from finger prints cause problems with contacts like this, so make sure they are clean and if you are in doubt, clean them twice. You should try to pop the flash open and not use the simple exposure settings on the mode wheel. If you are using the "easy" mode - stop. Use the portrait or night exposure setting. The other possibility is the processor in the camera is bad. If you have eliminated all the possible things then the camera is the culprit. I hope you have a warranty if that is the case.
May 10, 2017 | Cameras
Canyon eos auto mode= won't take a pictuRE
Push your shutter 1/2 way down. See whats the readings in view finder.
Jul 04, 2013 | Cannon EOS 50D Digital Camera
I have dark pictures even with sb600 flash working. Anybody have suggestions? Is it my camera settings? I use iTTL and I think flash is not enough
I don't know what camera you have and I don't know which mode you are using (manual exposure, full auto, shutter or aperture priority, etc.) so I can only make a generalized guess. It may be related to your shutter speed. Although your camera may have a wide range, for example 10 to 1/2000 second, your flash will only be properly triggered and synced over a limited range. I would take a few pictures with the shutter at 1/60 second and see if that helps. Also, on more advanced SLR's you can select a rear curtain mode. See if that may be a factor.
Oct 23, 2011 | Nikon Speedlight SB-600 TTL Flash
How do i turn the flash off
Welcome to FixYa.
The FORCED OFF mode is the setting where flash is not activated in any recording condition. this mode used when taking pictures in places where the use of the flash is not permitted.
There are other 5 different mode/setting in using photo flash.
1. AUTO - flash automatically activated according to the recording condition.
2. AUTO/Red-eye reduction - flash is automatically activated according to the recording condition. It reduces the red-eye phenomenon by triggering the flash before actually recording the picture. After that, the flash is activated for actual recording again.
3. FORCED ON - use the when your subject is back-lit or under fluorescent light.
4. FORCED ON/Red-eye reduction - use this when you set the camera to PARTY MODE
5. Slow sync./Red-eye reduction - use this when you take pictures of people in front of a dark background.
I hope this solution will help you. Just send us you comments or suggestion if this solution was helpful.
Thank you for using FixYa.
Apr 08, 2011 | Panasonic Lumix DMC-FX8 Digital Camera
A630 Indoor pictures are too dark in Auto, Flash
try using night mode indoors. otherwise, simply get into setup and go back to factory settings, and use AUTO mode. hope it helps
Oct 07, 2009 | Canon PowerShot A630 Digital Camera
Same as posted - picture is way too dark when using flash. Help!
Try a camera reset. Go into the setup menu and scroll to "reset" and follow the on-screen instructions.
Sep 23, 2009 | Canon PowerShot A630 Digital Camera
Digital rebel XS - flash delay
Your camera is set to syncronize the flash on the second shutter curtain. Check your custom functions/custom settings, and disable it. It's called "second curtain sync" or "2nd curtain sync". Nikon call it "Rear Sync".
Hope this helps,
/Chris
Jan 16, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Falsh Problem with Power Shot a640
I had the exact same problem. You'll need to send it back to Canon. It'll cost you $87-94, but they'll clean it up, get the flash working, and make it new again. It's a good camera worth getting fixed.
Sep 14, 2008 | Canon PowerShot A640 Digital Camera
Dark shadow on right side of picture
sounds like a shutter leaf dropping into the image. however, they are usually horizontal and more likely to manifest when in landscape mode. (horizontal, normal)
try using flash pointed up to ceiling.
also, could need to check for auto sync speed setting. usually 1/125 to 1/60. if its off, it could be catching the shutter in the wrong place.
check manual for settings for using flash.
mark
Dec 09, 2007 | Canon EOS 400D / Rebel XTi Digital Camera
Nikon D50 Digital Camera Logo
542 people viewed this question
Top Nikon Cameras Experts
Ric Donato
pictureman4u
Geoff Hone
Are you a Nikon Camera Expert? Answer questions, earn points and help others
