Question about Canon PIXMA MP160 All-In-One InkJet Printer
Belt on mp 160 came loose
Do you have a diagram or can you tell me how or where to attach the printer belt came off when checking cartridges on an E 5 error
  • 1 more comment
  • joel4o5 Nov 01, 2008
    same problem
  • ecwathen Nov 10, 2008
    I added new ink cartridges and the ink belt came loose too. Help!
  • duckygerr146 May 11, 2010
    the belt which makes ink headsmove
Don't have a diagram
Posted on Nov 15, 2008
    Problem Solver:
  • 18 Answers
Fiend your solution direct from Canon. Here is your solution...
http://www.canon.com/printer/prob676ijt65/solution
293
Posted on Mar 16, 2009
How do i rest my cannon pixma mp 220
I would imagine the error message is asking you to hold down the reset button of your printer for 5 seconds due to a low ink estimate with these refilled cartridges. If this is the case the STOP/RESET/RESUME button is represented by an upside-down triangle in a circle and is normally red or grey.
More information on this error message can be found here.
Hope this helps.
Sep 12, 2012 | Office Equipment & Supplies
How to make Canon pixma MP-220 to recognise refilled ink.
Read the manual.
Get online and got to www.google.com In the google search box type: "Canon Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operating system when requested. Look for manuals on the site.
An Error Message Is Displayed on the LCD (MP220 series)
Message
Action
CHECK INK
U051/U052/U053/U059
The FINE Cartridge may not be installed properly, or the Cartridge may not be compatible with this machine. Open the Scanning Unit (Printer Cover) and install the appropriate FINE Cartridge.
If the error is not resolved, the FINE Cartridge may be damaged. Contact your Canon Service representative.
Jun 02, 2012 | Office Equipment & Supplies
Belt repair for lexmark p3150 print trio multi-function
If you need lexmark customer support number 1866-877-0191.We are always here with tech team for your help. For further Info Click On Me:https://goo.gl/hvj3MK
Mar 11, 2012 | Lexmark P3150 All-In-One InkJet Printer
My treadmill turned on but the belt will not run
Dear Sir:
If the treadmill is turned On, you must check the follow:
1) the belt drive motor is faulty. 2) loose tension in walk belt, tight it.
3)Roller bearing from walk belt is faulty(lack of lubrication) both extreme.4) Walk belt is faulty and NEED LUBRICATION.
Please RUN the software calibration, under the Hood of motor and see the steps, for diagnose and troubleshooting.
See the block diagram attached. for help in troubleshooting.
2_16_2012_9_40_01_pm.gifsincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a.
Feb 13, 2012 | Exercise & Fitness
Error code E 5 for pixma MP 160
E 5 error is the Fine print cartridge going bad. Try replacing it.
Jul 06, 2010 | Canon PIXMA iP2000 InkJet Printer
DELL AIO 966 Carrier belt detached from printer
The belt goes through the back of the ink carrier.
There is a spring somewhere that keeps tension on the belt with the white roller.
The belt itself hooks into the frame of the machine.
Jun 21, 2009 | Dell 966 All-In-One InkJet Printer
MP 160 Canon printer, error code E5. I just want to use this machine as a scanner. Do I still need to load the cartirages?
Yes, the unit will not operate without the cartridges.
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 29, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Hp printer cartridges not moving
just finished taking mine apart 3hrs!!! ok cartridge not moving cause there's a little clip that's attached to a biger clip that's attached to the metal long rod in which the cartridge moves on top of got loose from the belt or just came of from the bigger clip.
now the little clip on mine came of and luckily i found it inside the printer.
steps:
1-took out about 10 screws to take cover off.(some sides snap off after removing screws)
2- remove 4-5 screws on top which holds a metal long slim frame on TOP of cartridge.
3- remove 2-3 screws from left side (facing back of printer) from the metal thin "ROD" on which the cartridges slide on top of.
4- lift up that rod and slide cartridge to left, mine didn't came out completely but enough to be able to work behind it.
5- if the little clip came off (and hopefully u found it)then reattach it to the belt.
6- take out the belt from right side, connect it again to the little clip, reconnect the little clip to the big clip, put back belt, big clip etc.
7- u have to play around a little to figure out how the clips go together and where exactly the belt goes.
GOOD LUCK cause i had 2 figure it out solo but finally finished w/ hands full of ink!!!
eddie kc
Nov 25, 2008 | Office Equipment & Supplies
E16
press stop reset button for few seconds and you can use your black cartridge for printing,but do remember to put use black only setting in ur printer cartridge settings.
Nov 09, 2007 | Canon PIXMA MP150 All-In-One InkJet...
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
332 people viewed this question
old marine
old marine
