Question about JVC AV-48WP74 48" Rear Projection HDTV-Ready Television
Green Convergence out of wack
Model JVC AV-48WP74 48" Rear Projection Screen. First of all, thanks ahead of time for the help. I turned on the TV this morning and the screen was discolored and it looked like someone was trying to squeeze it from top to bottom. We pulled up the menu and went to the convergence setting to find the green is all out of wack. It will not allow us to select the green to put it back into place. Reading some of the other posts, I see that the IC's (don't know what those are) are major contributors to this type of problem. And by the sound of it they are not entirely difficult ro remove and replace. Please guide me in the right direction. If you need more info please ask. I have a fair bit of mechanical ability and electrical know-how and would like to do this myself vice be charged the $100.00 diagnostic and then parts and labor.
  • Jeff Morgan Sep 18, 2006
    Thanks to all who have provided input. I still have to ask......what are IC's? Harley12 isn't sure either. Maybe you can help us both out. Thanks.
  • fball Apr 12, 2008
    how to install STK392-110
    Problem Solver:
  • 9 Answers
I had a problem with my TV colors not lining up. One day I turned it on and the green was out of wack. I checked this message board and replaced the STK chips, bad soldering and all led to me just giving up on that and buying a whole new Convergence Board ($185). I replaced the missing silver box on the new board and I just plugged this in and though now my Green lines up okay, my red is out of whack. Is there something I am doing wrong? Can anyone help me? Did i miss a step? Frustrated......Bruce
Posted on Aug 18, 2007
    President:
  • 3,130 Answers
The convergence IC's must both be replaced as a pair. They have STK marked on them with a number after. They are black in color and stand up and are mounted on a metal heat sink. they are soldered into place, and if your not an experienced with soldering, you can easyly make this set landfill. You really should call up an authorized repairer and ask what they would charge to change the 2 convergence IC's. And this should be able to be donr inside the home as well, but alot of servicers do not do this as they make more money if they take the set into the shop.
Posted on Sep 18, 2006
  • Larry  Dillon
    Larry Dillon Sep 18, 2006
    IC's are Integrated Circuits and that means many circuits built into a single package. Do a search on the web on Integrated Circuits. It should open your eyes on this subject.
  • 22 Answers
You got me stumped now. IC? Usually all components that make a video card work are made in the video card itself. You usually have to replace the video card unless you are a electronic specialists and have the tools to soder certain parts in and out of the board. Check n see how much a video card is for your unit. Might be fairly inexpensive. Wish I could help you more. Let me know the outcome.
My 48'' jvc colorconvergence is out of wack how do I fix this what part needs to be replaced if any
convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK-392-120 IC's and check the surrounding resistors. Shops usually charge between $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Oct 23, 2009 | JVC AV-48WP30 48" Rear Projection...
Jvc AV-48WP74 i no its a convergen issue but..
you can get the convergence repair kit at the following link which usually fixes that issue. The kit contains the parts and detailed instructions on CD of how to do the repair.
http://www.tvrepairkits.net/
Jul 07, 2009 | JVC AV-48WP74 48" Rear Projection...
Green Tube Convergence Issue
Greetings abflex,
You definately came to the right place! Here is a link right here on FixYa with the directions on how to correct this problem.
http://www.fixya.com/support/p186391-jvc_av_48wp30_48_in_rear_projection/manual-17247/page-52
I hope this helps!
Thank you,
Dorothy
Go Ahead. Use Us.
Jun 25, 2008 | JVC AV-48WP30 48" Rear Projection...
Jvc pos
when in manual convergence hit the select bottom to change to blue. as of green i have no clue.
Apr 17, 2008 | JVC AV-56WP74 56" Rear Projection...
I have a jvc av-48wp30 rear projection widescreen
check your soldering and make sure all the pins are soldered and you don't have any solder bridges.
have you checked the resisters?
Jan 31, 2008 | JVC AV-56WP30 56" Rear Projection...
JVC I'Art. 65" projection TV. AV-65WP74 green screen sages real low.
you have bad convergence ic and or resistors
this repair usually requires a repair tech
Nov 12, 2007 | JVC AV-56WP30 56" Rear Projection...
JVC AV-48wp74 Red, Blue, Green
no you did the right move but now you align the new pc board ,try to get the service in to enter the convergence alignment section,on most jvc;s it sleep timer ,disply&video status to enter try it but if your not sure of that you can perform the alignment ask a tech to do it. on the remote certain keys do special functions and you need to know what they do or you might make it worse.
Aug 18, 2007 | JVC AV-48WP74 48" Rear Projection...
Green shadows and curved picture
the convergence apms ic"s need to be replaced
Aug 16, 2007 | JVC AV-65WP74 Rear Projection Television
JVC MODEL # AV-48WP74 48 IN. BIGSCREEN TV.
I had a problem with my TV colors not lining up. One day I turned it on and the green was out of wack. I checked this message board and replaced the STK chips, bad soldering and all led to me just giving up on that and buying a whole new Convergence Board ($185). I just plugged this in and though now my Green lines up okay, my red is out of whack. Is there something I am doing wrong? Can anyone help me? Did i miss a step? Frustrated......Bruce
Jul 29, 2007 | JVC AV-48WP74 48" Rear Projection...
JVC AV-48WP74 48 in.
The convergence circuit needs repaired. I did the same job yesterday on this model. I not only replaced the convergence ICs, but, I had to replace a couple of resistors and a coil. The convergence alignment was minor after that.
Jan 22, 2007 | JVC AV-48WP30 48" Rear Projection...
JVC AV-48WP74 48" Rear Projection HDTV-Ready Television Logo
74 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
