Question about OKI MICROLINE 320 Turbo Matrix Printer
Printhead needs replacing
Where can i find a service manual on how to replace
Thank you so much. I used these instructions to replace the printhead on our microline 521.
Posted on Feb 02, 2009
  • 161 Answers
The printhead is completely user replaceable and need no complicated instructions.
1. Remove the ink ribbon.
2. Looking from above, find a small shiny lever to the right of the printhead.
3. Lift the lever with your hand and remove the printhead by pulling it upwards (make sure the printer is cold).
4. Reverse the procedure to install the new printhead.
Be blessed.
Posted on Nov 07, 2008
HP 1055cm+ Plotter: System Error 060308 00000008. How do you access the printheads when the plotter has this error? None of the console buttons respond.
This is an APA regulation failure. Not a good error. First you need to remove all the printheads and clean the contacts on the printheads and the contacts on the flex connector inside the carriage assembly that mate with the contacts on printheads. If no joy you need to perform the electronics test contained in the service manual link below. If still no joy then you need to replace all the printheads.
Aug 22, 2017 | HP Office Equipment & Supplies
I have a 07,010.43:45789 error code pop up. Any ideas?
7,010.43: The Printhead is stuck in the tilted position,
or is not able to tilt forward to the print position, due to problems.
Reboot the printer.
Repair or replace the Printhead Restraints.
Has ink spilled ink around the Printhead that prevents the Printhead from moving to its center position? You should be able to push the Printhead right to left. Clean the Printhead area.
Is the Printhead stuck to the Wiper Blade? Start the printer in diagnostics mode and run idiags test Exercise Heater - toggle Printhead heaters to soften the ink. Manual separate the wiper and Printhead. Set them in their home positions.
5
Does the X-Axis Motor drive the Printhead to its center position (so it can tilt forward)?
6
Check the Process Drive for obstructions or damaged.
Ensure the gears are correctly aligned and homed.
Verify the process shaft and drive module shaft are at their home positions.
7
Has ink spilled on the Head Tilt Gear on its drive train (near left side of the Printhead)?
8
Use Service Diagnostics to run the Head Maintenance Wiper Clutch test. If the test fails replace the Head Maintenance Clutch.
9
Align the Wiper Assembly. Use Service Diagnostics to run the Wiper Drive Test. If the test fails replace the Exit Module.
10
Use Service Diagnostics to run the Load Maintenance Clutch test.
If the test fails inspect the maintenance drive system, replace any defective parts.
11
Verify the Head Tilt Gear engages. You can manually set the Head Tilt Gear.
12
Use Service Diagnostics to run the Tilt Axis Drive test.
If the test fails replace the Process Drive.
13
Use Service Diagnostics to run the Process Motor test.
Aug 13, 2014 | Xerox Phaser 8560MFP Laser Printer
Print head
The carriage does not accept one or more of the printheads. Typical causes are dirty contacts on the printheads or carriage, defective printhead(s), or a defective carriage.
If parts are replaced or fixed in any of the steps listed below, attempt to verify printer functionality by turning the printer on and printing internal test prints. If functionality is verified, no additional parts should be replaced.
  1. Turn the printer on.
  2. Allow printer to complete initialization.
  3. With the printhead icon highlighted, press ENTER.
  4. Select Replace Printheads and press ENTER.
  5. If the message "Printheads still functional" appears, select Yes to continue testing the printheads.
  6. Open the top cover.
  7. Open the carriage cover and remove all of the printheads.
  8. Turn the printer off.
  9. Clean the electrical contacts on the carriage and the printheads using a lint-free cloth dampened with water.
  10. (for this step I suggest using the erraser on the back of a regular pencil instead of a cloth and water)
  11. Allow the contacts to dry.
  12. Reinstall the printheads and close the carriage cover.
  13. Close the top cover.
  14. Turn the printer on and attempt to verify functionality, as instructed in Step 19.
  15. If the error reappears, replace the affected printhead(s).
    NOTE: If the printhead error icon is a question mark, each printhead will have to be tested separately, as the printer is not sure which printhead is causing the problem.
    1. Following replacement of the suspect printhead(s), attempt to verify functionality (Step 19).
    2. If the problem persists following, replace the carriage and trailing cable (refer to pages 8-36 to 8-46 of the service manual).
    3. Following replacement, turn the printer on.
    4. Make sure the printhead alignment completes successfully and that no error messages appear on the front panel.
    5. Print a troubleshooting plot (as instructed below) to ensure the print quality is acceptable.
      1. On the front panel, select the printer icon and press ENTER.
      2. Select Utilities and press ENTER.
      3. Press the UP and ENTER buttons simultaneously.
      4. Select Yes to enter the Service Menu.
      5. Select Service Utilities and press ENTER.
      6. Print pages 1, 2, 3, 4 and 5 to prove printer functionality.
Mar 25, 2014 | HP DesignJet 5500PS InkJet Printer
Service printhead error 114.02
You are correct, Below is that section from the manual. Before you follow this, i've found in the past that the cable connector is not seated properly on the rip board, so check this first.
If you require any of the instructions on replacing the printhead or board let me know.
Yellow Printhead Lost Hsync
Check for the correct installation of the all the cables to the RIP
Board assembly and to the Printhead assembly; J2, J3, and J4 on
the RIP Board. Go to "RIP Board" on page 5-11. If the cables are
connected correctly to the RIP Board and to the Printhead
assembly, replace the following FRU:
"RIP Board" on page 4-11 If this does not fix the problem replace:
Yellow Printhead Assembly - Go to "Printheads" on page 4-33.
Note: Whenever a printhead assembly is replaced, it is necessary
to perform the "Printhead Adjustments" on page 4-1.
Feb 15, 2014 | Office Equipment & Supplies
Printhead needs replacing in my kodak 5300 printer how can i get one
Hi..
Try here
http://www.kodak.com/global/plugins/acrobat/en/service/manuals/AiOPrinters/printhead/AUR1780-9_UE_RevC.pdf
You can find illustrated instructions on how to remove the old printhead, as well as on how to put the new printhead back in place.
You can easily go to that website by going to:
www.kodak.com/go/printheadsupport
and selecting the second option "installing new printhead".
Good Luck:-)
Jul 07, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
Error 5200 on start up of Cannon MP830 printer
Error 5200 on the MP830 is for a printhead temperature warning. The Canon service manual suggests two causes of action. Firstly replace the printhead or secondly the logic board. Printhead can be replaced at a cost (Part number QY6-0061-010 about £50) but if you know someone with the same model try their printhead first because it might be the logic board.
Thanks
Jan 04, 2010 | Canon PIXMA MP830 All-In-One InkJet...
I recently replaced the belt in my HP 450C plotter. I hadn't used it in about a year but I put new ink in too. I got one really light test page and now nothing. The print head tries to do the job and there...
it is possible that all the printheads have dried up .try dabbing a wet tissue on the bottom of the printhead,if this does not solve the problem then you need to replace the printheads
Dec 21, 2009 | HP DesignJet 450c InkJet Printer
Printer error 07,010.43:722 on phaser 8560 xerox printer
Hi eduardo580:
This your problem.
7,010.43: The printhead is stuck in the tilted position, or is not able to tilt forward to the print position, due to problems.
1 1.
Reboot the printer.
2. Did this correct the problem? Complete. Go to Step 2.
2 1. Do the printhead lock arms rotate correctly? Go to Step 3. Repair/replace
the lock arms.
3 1. Has ink spilled ink around the printhead that
prevents the printhead from moving to its
manually push the printhead right to left.
Clean the printhead area. Go to Step 4.
4 1. Does the X-axis motor drive the printhead to
it’s center position (so it can tilt forward)?
Go to step 5. Troubleshoot the X-axis drive.
5 1. Check the process gearbox for obstructions or damaged.
2. Ensure the gears are correctly aligned and homed.
3. Verify the process shaft and drive module shaft are at their home positions.
4. Did this correct the problem? Complete. Go to Step 6.
6 1. Has ink spilled on the head tilt gear on its
drive train (near left side of the printhead).
Clean the gears. Go to Step 7.
7 1. Use service diagnostics to run the Head Maintenance Wiper Clutch test.
2. Did the test fail?
Replace the wiper drive clutch. Go to Step 8.
8 1. Ensure the wiper is properly aligned.
2. Use service diagnostics to run the Wiper Drive Test.
3. Did the test fail?
Replace the exit module assembly. Go to Step 9.
9 1. Use service diagnostics to run the Load Maintenance Clutch test.
Inspect the maintenance drive system,
replace any defective parts. Go to step 10.
10 1. Verify the headtilt gear will engage. You can
manually set the headtilt gear.
2. Is the gear engaged properly?
Go to Step 11. Set the headtilt gear.
11 1. Use service diagnostics to run the Tilt Axis Drive test.
Replace the process gearbox.
Go to Step12.
12 1. Use service diagnostics to run the Process Motor test.
2. Did the test fail? Replace the process motor.
Hope this helps
Jul 25, 2009 | Xerox Phaser 8500/DN Printer
Error code 07,010.43:59833. Service said I have to replace print head for 900$!
Hi jo47628:
Here is your problem:
1. Reboot the printer.
the lock arms.
Clean the
printhead area.
Go to Step 4.
the X-axis
drive.
or damaged.
homed.
Clean the
gears.
Go to Step 7.
test.
Replace the
wiper drive
clutch.
Go to Step 8.
Drive
Test.
Replace the exit
module
assembly.
Go to Step 9.
Maintenance Clutch
test.
Inspect the
maintenance
drive system,
replace any
defective parts.
1.
gear.
Drive
test.
Replace the
process
gearbox.
Go to Step12.
Motor
test.
Hope this helps
Apr 22, 2009 | Xerox Phaser 8550DP Printer
Lexmark Colour C752 108 service printhead error
the RIP Board. Go to “RIP Board” on page 5-11. If the cables are
“RIP Board” on page 4-11
Yellow Printhead Assembly - Go to “Printheads” on page 4-33.
to perform the “Printhead Adjustments” on page 4-1.
Jun 03, 2008 | Lexmark C762 Laser Printer
OKI MICROLINE 320 Turbo Matrix Printer Logo
281 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
